Question about Garden
What kind of grease or oil do you use to lubricate the front wheel drive? I have the left wheel locked, it will not turn.
  • 305 Answers
Try releasing it first with WD40, then just use normal 3-in-1 oil
Posted on Sep 07, 2009
Replace front hub assembly 2002 Suzuki XL7
the front wheel bearing hub?
XL-7 (the dash matters)
my wild guess, is the questions was
what are all steps to do this job. and tools.
that?
RTM?
https://suzukipitstopplus.com/Products/10056-2002-grand-vitara-xl-7-service-manual.aspx
http://www.fixkick.com/hubs/FW_BEARINGS.html#newer
the link shows all years, and variances.
here is a photo review, that is accurate up to
1998, and beyond , if you skip the bearing service parts. as yours are INTEGRATED
and NON-serviceable.
the photo 6a and B
shows removing the hub,
so do that , buy a new hub and put it back
the same way, using the tool stated
at the stated ranges of torque
123-180 ft/lbs.
this range allows you to get the screws into the locking rings.
Dec 11, 2016 | 2002 Suzuki XL-7
Tip
Front Hub Locks Lubrication
Avoid getting stock into drive, lubricate your 4WD hub locks with gear oil SAE 140, no grease please.
on Nov 19, 2008 | 1995 Suzuki Samurai
How to fit front wheel bearings Which brand to use for quality
If the car is front wheel drive a puller is required to dismantle the hub a rather involved job better left to a mechanic .If rear wheel drive do the following. ( Applies to front wheel drive also.) Chock rear wheels,loosen front wheel nuts, jack up car, fit safety stands,remove wheel , remove grease cap from axle. remove split pin or locking nut on axle ,Remove hub, with a punch drive out the grease seal ,the tapered cone bearings can now be removed, the 2 bearing cups still in the housing will have to be pressed out ,all old grease has to be cleaned out. the new cones must be repacked with high temp bearing grease . tap in the seal with the lip facing inwards , slide on the hub fit the outer cone to the axle , the spacer and nut goes on next, tighten the nut to seat the bearings , spin the hub make sure its free to spin, back off the nut one eighth of a turn fit a new split pin or lock tab. fit grease cap and road wheel.
Jul 27, 2014 | Cars & Trucks
Tension to tight on bike won't losen
Step 1:
please follow the instruction and fix it. God bless you.
Pedal Arms
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Step 2:
LUBRICATION
Prepare to oil by filling a grease gun with lithium grease. Check your owner's manual for the exact type of grease for your unit.
Locate where it is you need to lubricate. Focus on the bearings, free-moving joints and attachments with moving parts such as handle bars, wheels, pedals arms and guide rails. Go to each location one by one when greasing.
Unfasten the bolts or screws that hold the joint or attachment that you wish to lubricate.
Grease each bolt and screw liberally. Tighten each bolt and screw back into its place when finished.
5
Wipe away any excess greas
Step 3:
Drive Belt
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use
Jan 04, 2013 | Weslo Pursuit R 3.8 Upright Exerise Bike...
What kind of lubricant do I use for a Bachmann EMD GP40
A light- plastic compatible oil for the wheel bearings, (a drop on a tooth pick)
grease for the gears- a very small amount, a plastic compatible grease
DO NOT USE 3 in 1 oil or WD-40.
lubrication kits are available at your local hobby shop
or online train dealer...
Labelle, Bachmann, Atlas all offer lube kits.
Oct 09, 2011 | Bachmann 63598 Alaska Emd Gp40 Diesel...
What is required to get done on a 60k mile maintenance schedule?
60,000 Mile Service Schedule
  • Inspect 4x2 front wheel bearings; replace grease and grease seals, and adjust bearings
  • Change automatic transmission fluid
  • Inspect automatic transmission fluid level (if equipped with underhood dipstick)
  • Replace fuel filter
  • Perform multi-point inspection
  • Inspect and lubricate all non-sealed steering linkage,ball joints,suspension joints,half and drive-shafts and u-joints
  • Inspect brake pads/shoes/rotors/drums, brake lines and hoses, and parking brake system
  • Inspect complete exhaust system and heat shields
  • Inspect engine cooling system and hoses
  • Replace engine air filter
  • Change engine oil and replace oil filter (Up to 5 quarts of oil. Perform at specified mileage interval or every 6 months, whichever occurs first)
  • Rotate and inspect tires; check wheel end play and turning noise
Sep 14, 2010 | 2004 Ford F150
What is needed to remedy right hand front wheel bearing play on a 1990 d21 4X4 ute
replace the bearing or wheel hub assembly.
REMOVAL & INSTALLATION 2wd Models NOTE: Refer to wheel bearing service and bearing preload adjustment procedures found in Section 1.
  1. Raise the front of the truck and support it with safety stands. Remove the wheels.
  2. Remove the brake caliper and suspend it with wire, out of the way. Remove the caliper torque plate if equipped.
  3. Remove the dust cap and then remove the cotter pin, lock washer (if equipped) nut lock and nut.
  4. Pull the hub/disc assembly off the spindle with the outer bearing. Don't let the bearing fall out.
  5. Pry the inner oil seal out and remove the inner bearing. To install:
  6. Clean and inspect the bearings and outer races.
  7. Using a brass drift and a hammer, drive out the bearing outer race. Press a new one into position.
  8. Pack the bearings with grease until it oozes out the other side. Coat the inside of the hub and cap with grease.
  9. Position the inner bearing into the hub, coat the oil seal with grease and press it into the hub.
  10. Press the hub assembly onto the spindle and install the outer bearing and thrust washer.
  11. Install the hub nut. Turn the hub a few times to seat the bearings and then loosen the nut until there is 0mm axial play. Using a spring tension gauge, check that the preload (with new grease seal installed) is 2.2–6.4 lbs. (9.8–28.4N)
  12. Install the lock-nut, new cotter pin and hub grease cap.
  13. Install the brake torque plate. Install the brake caliper.
  14. Install the wheels and lower the truck.
4wd Models The hub and bearing service procedures for a 4wd models are basically the same as those for a 2wd version, with the exception of removing the free running hub assembly and the bearing preload adjustment. Refer to Sections 1 and 7 for additional information. Adjust the preload after the wheel bearing is replaced or the front axle assembly is reassembled. BEARING PRELOAD ADJUSTMENT
  1. Thoroughly clean all parts and pack the wheel bearings.
  2. Apply grease to threaded portions of the spindle, grease seal lip and wheel hub.
  3. Tighten the wheel bearing lock-nut with a socket and torque wrench to 58–72 ft. lbs. (78–98 Nm).
  4. Rotate the hub in both directions a few times to seat the bearings. Loosen wheel bearing lock-nut.
  5. Retighten the lock-nut to 0.4–1.1 ft. lbs. (0.5–1.5 Nm).
  6. Turn wheel hub several times in both directions.
  7. Retighten the lock-nut to 0.4–1.1 ft. lbs. (0.5–1.5 Nm). Fig. 1: Exploded view of the front axle assembly — 2wd models 86718030.gif
    Fig. 2: Removing the bearing outer races 86718032.gif
    Fig. 3: Packing the wheel bearing with grease 86718033.gif
    Fig. 4: Pack the lip cavity of grease seal with grease 86718034.gif
    Fig. 5: Exploded view of the front axle assembly — 4wd models 86718031.gif
  8. Measure wheel bearing axial end-play. The wheel bearing end-play specification is 0.
  9. Install lock washer by tightening the lock-nut within 15–30 degrees.
  10. Turn wheel hub several times in both directions. Wheel bearing should be seated correctly.
  11. If necessary, measure wheel bearing preload. NOTE: Measure wheel bearing preload with a spring-type gauge; measure at wheel hub bolt, with tire removed. The hub assembly should rotate with 1.6–4.7 lbs. (0.73–2.13 kg) of pressure.
Jul 28, 2010 | 1991 Nissan Pickup
On left turns there's a clicking or rubbing sound coming from left front wheel?
Without seeing and hearing the noise in person I can only speculate as to the actual cause of the problem. The issue is more than likely caused by one of the two following failures: 1. A failed CV axle boot on the drivers side nearest the wheel. 2. (less likely) A failing drivers side hub bearing. To me, however, your complaint describes to a "T" a bad CV axle. CV stands for constant velocity. This type of drive axle was designed for front wheel drive applications in order to allow the axles driving the front wheels to not only adapt to uneven road surfaces but also pivot with the steering knuckles to steer the vehicle while maintaining rotational speed. To achieve this CV axles use special joints at either end called trunions. These joints are lubricated with a thick grease which is contained by rubber boots. In your case the boot closest to the driver's front wheel has torn open allowing the grease to be thrown from the joint during driving. This joint, now unlubricated, has dried out and collected debris from the road. Making otherwise silent operation a disturbing load affair, especially when it is put under maximum stress ie a left hand turn.
Oct 23, 2009 | 2002 Audi A4
94 4Runner 4WD Question
1. I would suggest that you engage your 4WD while you are in full stop and/or safe range of 5mph, however as claimed by the local dealers your vehicle is capable of engaging even while driving. Engage your 4WD while moving only when necessity requires.
2. That clicking noise while turning extreme right or left would be the birfield of your axle and would only mean your front hub is still engage even though you have disengaged transfer case.
Have your front hubs cleaned of old lubricants or grease due to non usage. dont use grease as lubricants, use thick oil such as gear oil or silicone oil. and use your 4WD every now and then.
Do this first then check if you still feel somtehing is loose on your suspension and others.
Dec 10, 2008 | 1994 Toyota 4Runner
1995 toyota land cruiser
Your front "ball & socket" joints are in dire need of lubrication. You need to do this:
Take the tires off, and look for a fill plug behind the hub, on the housing, above the ball & socket. Remove the plug, and fill it up with 80-90 gear oil. Replace the plug, do the other side.
What you have is a dry joint, and the clicking noise is coming from the u-joint (actually called a "Rzeppa" joint), inside the ball/socket/hub...a good lubrication will eliminate your condition. Hope this answers your question, please feel free to comment back with any other questions...And, thanks for choosing FixYa.
Oct 30, 2008 | 1995 Toyota Land Cruiser
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
