Question about Whirlpool Duet GHW9150P Front Load Washer
Spin cycle wont work
What does it mean when it keeps flashing "F" and "DL"
  • 5,911 Answers
"Fdl" is a door latch error code. This indicates that you have a failure of the door latch, the latch pin on the door, interconnecting wiring, or the Central Control Unit (CCU). A physcial inspection of the door latch should be done first to determine, if there is any physical damage to any of the latch components. Next, unplug the washer and remove the top panel of the washer by locating and loosening the three screws that hold the panel n place in the rear of the washer. With the screws removed, the panel will slide back then lift off. Perform a physical inspection of all the electrical connections on the latch and trace them to the CCU and do the same. Often, simply diconnecting each connector plug one at a time and reseating them can clear this problem. If you determine that you need to replace the door latch, the following link explains how:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
You can purchase replacements at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites offer great service, so shop them all for the best price.
If you need further assistance in troubleshooting this problem, there is a technical data sheet included with you washer. The tech sheet is located behind the bottom panel directly below the door. If not located behind the panel, it will be affixed to one of the interior cabinet walls. The sheet lists all the fault codes, diagnostics procedures and troubleshooting tips.
If the door latch checks out good, the CCU will require replacement.
If you have questions, or need additional assistance, please let me know. I hope this helps you.
Posted on Sep 07, 2009
  • 220 Answers
It is a Door lock issue,but not necessarily the door lock it's self, a quick temp fix (Believe it or not)is too take your fist and give it a whack on the top right rear corner not hard enough to dent it,just a jar,if that works you have a loose pin on the main control board under the top panel you can also remove the top panel and check all the connections going to the board. If no luck with the control then start looking at the locking mechanism.Here is a link to the service manual for the duet.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Kemore Elite Front Load washer was flashing F11 and i repeated the drain, spin cycle several times. now flashing dL and F . The door is locked so I am unable to remove wet clothing.
Try lowering the drain hose onto the ground and see if the water comes out. Turn off at the wall and then back on again a few minutes later. See if the door unlocks this time. Most front loaders wont let you open the door if it thinks its still full of water.
Mar 21, 2017 | Washing Machines
What does flashing code mean on a Kenmore elite 110.4597 front load washer?
DL is a door lock code. Did the door feel firm when closed?
Feb 29, 2016 | Kenmore Washing Machines
Can you tell me what e6 on the display means as the machine wont work when this shows
Not sure of the make/model, but with Samsung washing machines that usually means 2 things. If you get it when entering the spin mode and the system stops and displays the code, the water heater is heating too quickly. Press the power button once to clear the code and finish the cycle before repair.
If you get the E6 during the spin cycle that can mean a problem with the main controller board.
You can keep resetting to get past that code but if you continue to get it during a spin cycle or part of the laundry where hot water isn't used, then usually that controller board is bad.
Good luck.
Apr 08, 2015 | Washing Machines
What does F7 mean, why has it become very noisy on spin cycle and leaks occasionally?
THAT MEANS IT REQUIRE ANEW BEARINGS AND OILSEAL......THAT MEANS U NEED A SPECIALIST TO REPLACE THEM.
Feb 24, 2012 | Washing Machines
What does F DL means i opened the door to add something then t came up F DL and wont start again, the cycle had just started I pressed cancel all it does is beep and flash F DL
Hello and welcome to FixYa
FDL is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Sep 14, 2011 | Whirlpool GHW9400 Duet Washer
At the end of the cycle when the machine goes to spin the machine stops saying DL. I looked it up in my manuel and that means door won't lock. But it was locked the whole cycle until the end. I emptied...
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Aug 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Our Kenmore Elite HE3 Model prefix is 110 stops during the rince and spin cycle,beeps, and desplays F dL or F 11. The door light is not on, but the door is locked. We were able to start and complete the...
wash another load and see what happens the f-dl code means door lock problem and f-11 means communication error between top control board and the bottom control board if you can wash a load completly everything will be ok but you can't let me know and we see where to go from there
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
Keeps flashing SE
I recently had this happen but with no error message on my model, the rinse symbol just kept flashing and nothing was happening. I tried running a spin cycle or rinse and spin. The rinse & spin started but stopped when it got to spin. I finally determined that the water was not draining out. I ended up emptying a bucket and a half of water out of the emergency valve near the floor (which spills water everywhere) and found a lint ball that was plugging it. After this I tried running just a spin cycle and it worked.
Mar 30, 2009 | Samsung Washing Machines
Starts bleeping 10mins into cycle
http://www.manualnguide.com/dl/12334/ Check on the troubleshooting page as to what certain flashing sequences mean and that may help
Jan 08, 2009 | Baumatic 23 in. BDW5 Built-in Dishwasher
Whirlpool Duet GHW9150P Front Load Washer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
