Connection hook up problem
I bought a LG Flatron L1720L from a friend. I connected the power cable correctly and I had to buy a new monitor cable to connect to the computer and the monitor, the cable is a VGA/SVGA, is this the right cable? Also, when I connected and turn the power on I get a blue box that says '' Analog'' out of range. What am I doing wrong? I also updated and downloaded drivers for this monitor.
  • 3,153 Answers
Set the resolution lower.
It is telling you that the resolution you want is beyond its normal operating range.
just drop it to lets say 800 x 600
Then bump it up one resolution at a time until you get the message again, then drop it back one.
Running monitors above the acceptable range can drastically shorten their lifespan.
With lcd monitors you are much better using the DVI cable if yout video card supports it.
Posted on Sep 07, 2009
Lg flatron L1919S is blinking when I connected it as a second monitor
If it works as your first monitor, then it is either the cable/connection issue or the graphics software is not seeing it correctly or the second graphics card is not in correct or a combination somewhere.
You will need to do a bit of fault analysis to determine what is causing the issue.
Dec 30, 2013 | LG Flatron 915FT 19" CRT Monitor
I have a LG Flatron EW224 computer monitor. It was working great but one day the screen went blank and reads in the center of screen: D-Sub out of range 68.5Khz/85Hz. Does anyone know how to correct this...
This is usually due to your computer Video resolution being set to a setting out of the supported range of your monitor, Lowering the computer video resolution should solve this issue.
Oct 01, 2013 | LG Flatron 22" Super Led Ew224 1080p High...
Lg logo appears then goes in to power saving mode LG Flatron Wide Monitor
Hello davidhague99 ,
Check your VGA cable if connected properly to your CPU or Video Accelerator Card,if connected properly,try another VGA cable and if the problem persist you need to try another source.
hope it helps thanks
Jun 11, 2011 | LG FLATRON L1919S-SF 19 inch LCD Monitor
Problem for LG 22" FLATRON Widescreen LCD Monitor LCD Monitor My monitor says analog power save and shuts off. Day before Yesterday I bought a new computer. I got the above mention problem on by...
The monitor is going itself to the Power Saver mode.It is not a problem of the monitor.This happens when there is no signal on the monitor.The monitor will display properly when there is an output signal on it.Please connect it to the computer and check that the output signals from the motherboard are proper.Also check both DVI (Digital Visual Interface) and VGA (Video Graphics Array)cables on the monitor.
Feb 23, 2010 | LG 22" FLATRON LCD Monitor
My monitor won't turn back on after a reboot, no on light, worked fine prior
check with the power cable or the video cable is connected correctly in the motherboard VGA or if you have graphics card connect the video cable of the monitor to the graphics card VGA slot.
Oct 20, 2009 | LG Flatron L1710S 17" LCD Monitor
Flatron monitor
You need to check the monitor cable if it is correctly connected to the motherboard port. If the analog display or no signal it means the monitor cable should bot connected. If you have a video card in your motherboard you can plug your monitor cable to the external video card.
Oct 03, 2009 | LG Flatron F700P 17" CRT Monitor
Brand New LG Computer Monitor Flickers/Goes Into Power Save Mode
well right click on your desktop and goto properties and then goto screen saver and then goto power and then on the monitor setting goto never.
Sep 20, 2009 | LG Flatron L2320A 23" LCD Monitor
Analog power save mode
Are you connect via Analog (Blue VGA connection) or DVI (White Digital connection?
If you are connected via DVI, then you have to change the input select button to DVI
If you are Connected VGA, make sure the system doesn't have 2 VGA ports. If it does, connect to the other port.
May 02, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Flatron LG monitor safe mode
Your monitor goes to Power Saving Mode when the signal it is receiving is not correct. In all probability this is not a problem of the monitor itself, rather you should check the connections and the computer the monitor it's connected to. For example you could try a different RGB cable and try it in a different computer.
Apr 13, 2007 | LG Flatron L1951S 19" LCD Flat Panel...
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
