Question about Elna Sewing Machines
Cant bring up bottom thred even after we read how to
    Scholar:
  • 76 Answers
Re thread the upper and lower threads
make sure the bobbin is in the correct way (check manual for the correct spin on the bobbin clockwise or counter clockwise
change needle or check that it is in correct, if it has a flat side goes to the back, the long groove on the needle when goes down should just meet with the hook in the bobbin area to pick up the thread
Posted on Sep 07, 2009
HOW DO I THRED MY SINGER 29K58
Hi i found this link posted on this site March 29 2013 hope it helps
http://www.fixya.com/support/t17401898-thread_singer_29k58_sewing_machine
Also this one is a link to Utube video instructions Good Luck...
https://www.youtube.com/results?search_query=HOW+DO+I+THRED+MY+SINGER+29K58
Mar 14, 2016 | Singer Sewing Machines
On a singer solid state 93220 the bottom bobbin thred is to tight how do I adjust it?
If the bottom seems too tight you must loosen the top tension. If this doesn't seem to work to well then tighten the bobbin some. I've attached a guide on how to adjust tension.
Jun 04, 2015 | Singer Sewing Machines
The needle dose not catch the thred at the bottom
Try a new needle inserted flat side away from you. If that doesn't work, it may be your timing messed up. I hope it is just the needle for you. Good luck
Mar 06, 2011 | Sewing Machines
I am not able thred the thred from the bobbin. The thred got jammed up when I was sewing, and I removed the bobbin and now I can't get the thred back in.
What is blocking the hook and shuttle? I am not too sure what you are asking, where are you trying to put the thread? Please, be more clear.
Nov 20, 2010 | Brother CS-6000
Why dose the thred keep breaking even when im useing heavy dudy thred
try rethreading the machine
the thread tenison may be to tight
the needle could be damaged
needle & thread may not be compatable--here's how to tell
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 11, 2010 | Brother LS-2125 Mechanical Sewing Machine
My thread keeps breaking. I got this machine
Thred breaking is one of the following: tention to tight, wrong thred, wrong needles - use jersey baal point 80/12 needles for all material and thred, bobbin tention too tight. wcbotha@yahoo.com
May 10, 2010 | Sewing Machines
The bottom thred is bunching up when sewing
Usually when the bottom thread is bunching or looping it means the top tension is too loose or the thread may not be in the take-up lever. If you're top tension is set between 4 and 5 and it's still bunching, there may be a piece of thread or lint caught between the tension disks.
Feb 24, 2010 | Sewing Machines
I have a juki sewing machine and the nittle
the problem of your juki sewing machine is your bobbin. adjust your bobbin to the right place.
Feb 16, 2010 | Juki MO-655 Mechanical Sewing Machine
When I sew the back of the material thread is big loops. Is this because my bobbin is not set right?
well errr???? im a man talking to you !!!! how would i know whats wrong here???? i cant stich a button on???? but ???? me thinks its not so much the bobbin thats not set right its the needle thred tensions that are wrong there far to slack, whats happening is the needle is stiching but the bobbin is not pulling up all the exess slack, you have missed threded the sewing machine? missing out the thred tenshion bit,,that or it's just not tight,,, crank it up tighter and see if this helps pull it up more under the stiching ? if im wrong slap me !
Oct 24, 2009 | Singer Sewing Machines
Sewing Machines Logo
93 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
