Question about Philips GOGEAR SA6045 MP3 Player
Won't charge i have connected it into my computer for about 14 hours, and the quick start manual only said that it needed to be charged for 5 hours to be fully charged, but after i took it out of my computer it was still on empty battery!!! why is my mp3 not charging???
  • Anonymous Dec 23, 2007
    1gb mp3/vedie wont charge
  • Anonymous Jan 24, 2008
    charger it for about 8hours an the battery was still dead it only charges on a wall charger
I'm having this problem also. I have had it "charging" for at least 12 hours, and the screen still shows the battery filling up.
Posted on Jan 03, 2008
Why did weed eater just stop working?
Take note: The battery pack will not reach full charge capacity on the first few charges. The break-in period requires 4 to 5 charging cycles, where the battery pack is completely discharged ( no motor sound or tool motion) and then fully recharged. During the break-in period the battery needs to be charged 5 or more hours continuously. The green LED light on the charger will come on in 3-5 hours,this is normal, Continue to leave the battery pack chargingvfor a total of 5 hours or more. After the break-in period, a full recharge is indicated on the charger when the green LED light is lit. Note: Do not charge battery in areas lower than 50 degrees or higher than 80 degrees. Looks like this will need to be charged in the house. I found all this information on page 14 in your manual.
Jul 18, 2015 | Garden
HOW DO YOU CHANGE THE BATTERYS
Depends on what battery. car battery I charge with i 10 means with a current 1 / 10 of the capacity in Ampere hours for 14 hours. So a 80 Ah battery with 8 A for 14 hours.
A camera battery in the charger I got with the camera. Or a good universal charger from GP. A NiMH AA or AAA battery, with a quick charger that at least needs 2 hours to charge. The quick chargers I have that can charge in less than 2 hours (one can manage in 15 minutes) all kill batteries after a few charge cycles. Hope this helps.
Mar 15, 2015 | Cameras
What is the charging time for agfaphoto 800 1.2v
Charging a battery depends on the battery capacity and the current you use to charge.
The best for a rechargeable battery is to charge it with 10 to 20 % of its capacity. If you choose 10%, you charge for 14 hours and 20 % you charge 7 hours.
Most chargers, charge on a higher current. (quick chargers), but just try to calculate what it takes to get 140% into the battery. That is the maximum time needed to charge.
If after that time the battery is still not "full" or at least the chargere light does not indicate it is finished charging, it could be the battery is defect.
Dec 31, 2014 | Cameras
Acer Aspire 4830T laptop battery behaving vaguely
Do you still have the old battery. If so charge it, and see if it charges properly. If so then you have a bad battery.
Mar 18, 2017 | Acer Aspire Timeline X 4830T 14 Inch...
Electric blade clutch won't work and battery went dead
If you have a new battery and it went dead that quickly I would check the charging system on the mower engine. Many of them use a voltage regulator and if it goes bad it will not properly charge the battery. Get the engine running (do not engage the PTO) and use a multimeter set on DC voltage. Place the multimeter leads on the battery and you should see approximately 13-14 volts DC at the battery terminals when it is running. If less then that then it's a problem with the charging system and further tests would be needed to figure out if it is a bad regulator or charging coil.
Aug 23, 2012 | Husqvarna Garden
When riding in 5th gear starting losing cylinders. and bike dies? then bike won't start electrical start. can' roll bump start bike if i let sit for an hour. thn bike dies quickly. is my m
More likely to be your ignition coils. They heat up and expand this can cause an open circuit which will close up again when it has cooled down. Although, a bad charging system may cause this problem. Check the battery voltage with engine switched off ( approx 12 volts) and with the engine running (approx 14 volts) If you are getting 14 volts then your battery is dead, if you aren't, then your charging system has a fault.
May 06, 2012 | Honda CB 750 Motorcycles
1999 bmw 323i wouldn't jumpstart
No danger involved, just useless. If ONE vehicle won't jump it, there's something drastically wrong with the engine. A charging system will only charge a max of 14 volts when charging a low or dead battery. Over that will hurt something. If you have two vehicles connected to your low battery, there's still only 14 volts going out from them and into yours. There is no reason why one jump vehicle won't charge and start your vehicle. Unless of course the jumped battery is really bad or has a bad/dirty connection. So clean your terminals before a jump. You may not need a jump.
Nov 28, 2017 | 1999 BMW 323 Series
Why won't my car start without getting a jump? Once I get it jumped it runs really good but when I turn it off and try to start it again, it won't start. I have a new battery and a new alternator...
Buy yourself a volt meter and check the batter voltage before and after it starts. You should read 12 volts before starting and around 14 volts once it starts and the alternator is charging the battery. Also check for loose connections between the alternator and battery. Check that the ground wire from the battery is secured to the vehicles frame. Good luck!
Oct 18, 2011 | 1987 Audi 5000 CS
Why do you send usb connection to charge jwin jb-th130, why not receptical plug. do i plug into computer and how long to charge?
The standard connection is a USB plug (mini or micro USB style). You can plug it into your computer or any wall plug that has a USB connector on it (the bigger rectangle shaped plug like your computer has). The USB standard is 5 volts so if it comes from your computer or a wall adapter or your car charger - as long as it is a USB connector and likely says 5 volts, they will all work the same way.
Every headset I have worked with seems to charge about 50 to 75% in 2 hours (it is ok to do a quick, partial charge). Leave it plugged in overnight for full charge (8 to 12 hours).
Jun 14, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
Unit will not turn on
Your battery is recharged when connected to your computer. Turn the player off and connect it to your computer via the USB cord. The computer must be turned on. Initial charge should be for 10 hours with subsequent charges 3 to 4 hours for a full charge. A quick charge of 1-1/2 hours will give you a 70 percent charge. A fully charged battery will last up to 15 hours under normal use.
Dec 09, 2008 | GPX MW3837 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
309 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
