Question about Hitachi 43UWX10B 43" Rear Projection Television
Double image I am finding that allof a sudden there seems tobe a swrling effect of red on the top and bottom of the screen. The red appears to be a duplicate of that is on the screen.
  • SD Tech
    SD Tech May 11, 2010
    Hitachi? 43uwx10B? I just fixed one yesterday--is it 3d looking picture?
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
1.)This kind of trouble happens for a reason. The two convergence chipshave a metal back and are bolted to either one large or two smallerheat sinks to keep them cool---a white grease is applied to the back ofeach chip to move heat fast---after some years the grease dries out anda chip reaches a point where it cannot move the heat fast enough and itgoes.
2.) You can locate the chips inside the set--they areblack, 2 1/2 inches wide and about 1 1/2 inches tall with the STKnumber printed on them in white--most of these sets use eitherSTK-392-110 OR STK-392-150 CHIPS---the 150 chip is a higher current andlonger lasting version of the 110 chip. You can buy a pair of thesechips on Ebay for less than 13 dollars plus shipping.
3.)Thechips have 18 pins each and need to be unsoldered to replacethem----Most of the time you just need to replace both chips and adjustthe set with a remote control---I did two Friday---takes about a hourto do this repair.
4.) I do not know what level of skill youhave but if you can do this yourself--you will save some realmoney--once the chips are replaced and the set adjusted--it will nothave this problem again for 5-8 years---about the only problem thiskind of set has.
5.) If you cannot do this look for someone inyour area who can do this---some shops will TRY to charge 300-400 to dothis repair--I have done hundreds of these sets and here I charge200-250 total cost.
6.) If you call and they say it "has to go to the shop" keep looking as any good tech can do this repair right in your home.
7.) Now is the slow time of year for TVDouble image - 2.gifrepair shops--shop around and make SURE WHOEVER DOES THIS REPAIRCHANGES BOTH OF THE CHIPS---if only one gets replaced you will have thesame problem again and soon.
8.) Yes, sometimes there will be abad resistor or two damaged by one of the chips---no big deal--any goodtech will be prepared for this.
9.) If you have ANY QUESTIONS OR NEED HELP LET ME KNOW- I am here to help people.
10.)I do this here for free so if this information has helped you take aminute and give me a vote here. Remember, IF you have questions justreply to this post here and I will try to help or advise you.
Regards, SD TECH
Posted on Sep 08, 2009
    Problem Solver:
  • 11 Answers
Easy fix, you need to replace the two convergence chips, there are two black chips on a heat sink with a lot of legs on them.
don`t forget to buy thermal paste.
Double image and colour
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 07, 2009 | Sony KP-53HS30 53" Rear Projection...
Color seems off possible bowing of the image at top and bottom
that's right my friend, you have a convergence problem, you need to replace the stk's and it is possible that you have some burned resistors. if can't do it yourself  you are looking $250.00 repair
good luck
Jun 07, 2009 | Samsung PCL5415RB 54" Rear Projection...
Screen has double image in red
This is a convergence problem that is either poor solder connections at the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Update this if you wish to attempt the repair and I'll provide additional details and instructions.
Dan
Mar 24, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Phillips Model 60pp920217f
I expect the answer to your question is YES! The convergence amplifiers are a common problem in many projection sets. When you search for the replacements you should find that the originals have been superceded by improved parts. Also be aware that when these parts fail, they will usually damage a resistor in the convergence yoke return path. The resistor must be replaced with one of the correct value or the convergence, though responsive, will be out of range.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 29, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Double image w/horseshoe shape top and bottom
sounds like the convergence amplifiers need to be replaced
Dec 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
Colors and Images
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 25, 2007 | Toshiba 65HX81 65" Rear Projection...
WS55711 mitsubishi RPS - Dec 2002
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
Oct 15, 2007 | Mitsubishi WS-55711 55" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
391 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
