Samsung 226bw screen flickers/shuts off
Samsung 226bw screen was working fine for a year it started a while after i began switching the dvi chord from my pc to my mac so it flickers slowly for a while, after a while it's coming back to life could be in an hour could be in a day when i finally get a picture on the screen if i turn off the computer it's the same story all over again...sucks....
    Master:
    Sergeant:
  • 460 Answers
It is a hardware problem. you can checked it from computer store.
Posted on Sep 07, 2009
Testimonial: "thanx "
My Samsung 226 BW 22"
Look for bad caps as shown in my pictures here first:
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG%20226w/
Make sure to replace them in a set with correct type.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 29, 2011 | Samsung 226BW Monitor
My monitor has been flickering from switch on for about a month. After re-starting 3-4 times it would clear. Then it took up to 8 times then it is just sometimes blank when I switch on. When it is plugged...
its power to the pixels causing the flickering the eletronics controlling which to use may be on its last legs,sorry but it sounds terminal for its use
Jun 22, 2010 | Samsung 226BW Monitor
Samsung LCD 226BW is flickering
Yes,
The power inverter is the problem but you can repair it yourself. Check out our web site at: www.ccl-la.com We have a step by step repair guide for this model, its the same as the 214T. The repair requires replacing 5 small parts that will need to be soldered. If you don't want to do the repair yourself we do offer a repair service for $30 plus shipping. If you have any questions or need service contact us at tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 07, 2009 | Samsung 226BW Monitor
My 3 yr old Samsung 226bw strobes when switched on
colinfaver, I think a visit to YOUTUBE and conduct a search for longer vid clips of "lcd monitor disassembly" and "lcd monitor repair" for monitors that suffer from the "black screen of death" syndrome and what internal electronic components fail and how to visually locate them on a "switch-mode-power-supply" and possibly replace them with new good ones and with a little luck end up with a working monitor. Your 226BW is SICK, and will probably do same if connected to a different PC with same ambient room temperature. Yes, problem with SMPS/CCFL inverter supply getting a bit tired!! If this was of help to you, please rate on fixya, and do return comment. 12fixlouie Bye for now.
Nov 17, 2009 | Samsung 226BW Monitor
Samsung 226bw visible flickers just after it is turned on
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 31, 2009 | Samsung 226BW Monitor
Samsung SyncMaster 226bw 22inch flickers/blinks on startup
Solution = Sledgehammer. My 226BW has been taking ages to warm up for a while and now it is a permanent dull flicker.
Aug 26, 2009 | Computers & Internet
Flicker, even when no signal cable
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 03, 2009 | Samsung 226BW Monitor
Samsung 226BW 22" LCD wont turn on and flickers a blue light
Hello cstafford35,
Your monitor has a very common problem. The internal power supply has blown a part called a capacitor. If you are comfortable working with electronics and with soldering I can talk you thru the diag/repair. If you are not ready to tackle that we also offer a repair service, about $30 plus shipping for your model. Let me know if you want to try fixing it yourself and we can go from there. The repair will require opening the monitor case and replacing from 2 - 5 parts. You can call me at 318-447-9040 if you have questions.
Buddy
Corporate Computer
Jun 17, 2009 | Samsung 226BW Monitor
SAMSUNG LNT3232H LCD TV FLICKERING BACKLIGHT
I have a ln-s4092d that had the same problem after a little more than a year of service. Replacing the main board seemed to fix the problem. But about a year later, the same problem has reappeared. I'm getting ready to replace the main board once again, but I don't really want to do this on an annual basis/
Nov 12, 2008 | Televison & Video
What about the blue circle LED on the power button ? still blinking or not ?
For the record I've had some problems with this screen too, sometime I had to unplug and replug my Video Card (and the DVI Cable) and everything was back to normal
Hope it helped you
Nov 07, 2008 | Samsung 226BW Monitor
Computers & Internet Logo
619 people viewed this question
David Payne
David Payne
