Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi WS55859 power turns on green light but then turns off
I did the diagnostic menu/devie and got a series of 10 double blinks seperated by pauses
  • jward5150 Sep 07, 2009
    blinks twice (1), pauses, blinks twice (2), pauses, blinks twice (3), pauses, blinks twice(4), pauses, blinks twice (5), pauses, blinks twice (6), pauses, blinks twice (7), pauses, blinks twice (8), pauses, blinks twice (9), pauses, blinks twice (10) then ends
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
2 blinks and pause and 2 blinks?
Posted on Sep 07, 2009
Testimonial: "Quick response, easy to understand, asked the clarifying questions to see what the issue was likely to be and then gave a good diagnosis with personar"
  • SD Tech
    SD Tech Sep 07, 2009
    The two blink and two blink code is short protection. The most common reason for this is one or both of the fuses that protect the chip in the convergence circuit are bad--set detects no voltage to the chip and shuts down. The set will repeat the error code several times and then you need to unplug it and turn on again for it to repeat the codes.
    WS-55859 model uses a single convergence IC that you can buy on Ebay for about 14 dollars plus shipping. This chip is a STK-393-110. I have detailed step by step from start to finish instructions for this repair on this set. I also have photos that will show you where the pico fuses are and what they look like----set also has several resistors protecting the chip--I have photos of them also.
    If you want the photos and instructions email me and I will send them to you----IF after you look at them you are not able to do this repair yourself I will tell you how to proceed--I have one set here exactly like yours and another coming tomorrow---I have done hundreds of these sets----once the chip and any bad parts are replaced the set will not have the same trouble again for 5-8 years.
    etower.766@netzero.net
    I do this here for free so if this helps you take a minute and give me a vote here. You cannot replace this set for what this repair will cost you and these sets are not like LCD OR PLASMA---they keep going-----over 80% of PLASMA and LCD SETS fail in the first 3 years.
    REGARDS, SD TECH
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
Blinking green light on my mitsubishi tv....model ws-65869
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
Jul 14, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS55859 turns on for 3 sec. then turns off
Ic's went out again. Did you check all the bias resistors? Must always look the board over for cold solder joints also.
Oct 22, 2009 | Televison & Video
Mitsubishi ws-55859 reset light flashing won't reset
You have blown capacators in your DM board. Here is a video that I used that guides you step by step video instructions for repairing TV. Bought the capacators at Radio shack for appx. $2/each.
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
Jun 18, 2009 | Mitsubishi WD-62725 62" Rear Projection...
2001 Mitsubishi 65 inch HD1080 rear projection. When I turn it on, green light comes on for 2 seconds then it turns itself off. No flashing green light like others I read about.
Ok, try this first. After attempting to turn on set after it shuts off push and hold the MENU and INPUT buttons at the same time on the front of the set for 10 seconds. This should acccuate the self diagnostics function in the micro and the power LED should start blinking a two sequence code. That code will narrow things down.
Jun 03, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
May 31, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Apr 03, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Blinking Green Light
Video Instructions for repairing TV blinking light WS-55589:
I repaired mine using this and I am certainly not "handy". Good luck!
Jan 26, 2009 | Mitsubishi WS-55859 55" Rear Projection...
I have a Mitsubishi 55 inch rear projection tv model ws55859. As soon as you turn on the power, the tv shuts down (either by remote or front of panel). The green light comes on for about 1 second and you...
Have you tried holding the input and menu buttons on the set both in together for 8 seconds to see if it will blink a 2 digit error code? Try that and let me know what code if any flashes from the Led.
Mar 30, 2008 | Televison & Video
Mitsubishi WS-55809 55" Rear Projection Television Logo
189 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
