Question about Broan-NuTone N-8664RP Combination Light Fan Exhaust Fan
Noisey fan The fan is making a lot of noise. I can't see anything loose or rubbing. Is ther something I can lubricate to stop this. Wher exactly do I spray the lubricant and what kind shoul I use? Another person had a similar problem and you suggested to remove the 'net' and lubricate motor. What is the 'net'?
In my case noise was coming from the plastic blade rubbing against the sheet metal housing. I removed the motor and added 2 washers to the mounting screws. The washers acted as spacers and lifted up the motor/blade assembly with respect to the sheet metal housing. The blade no longer rubbed against the housing and the noise stopped.
Posted on Nov 15, 2008
I had the exact same problem and repaired in a similar way than Solution #2 posted on Nov 15, 2008
I added a steal o-ring on the shaft to prevent the blade from going to low and rubbing against the metal casing! The key is to prevent it from lowering on the shaft.
Posted on Jul 18, 2009
  • 640 Answers
The bearings in the motor are probably failing/or dry.Locate the shaft of the motor going into it and spray wd-40 on it and see if this helps.
Posted on Dec 11, 2007
How do I stop the squeaking noise when pedaling the bike or using the elliptical option? I've tried lubrication. Only getting worse.
Have you lubricated all moving parts. Wheel bearings Chain and sprockets? Are there fenders if so are they a little loose?. Anything that is loose will vibrate and make a noise. Even dry pedals will make a noise. Crank also.Just a thought.
Dec 23, 2016 | Exercise & Fitness
Oscillating tower fan makes a rubbing noise when turned on, can this be fixed?
Lubricate bearings. Check for rubbing and adjust to stop same.
Feb 19, 2015 | Tower Dryers
Unit makes a lot of noise when cooking.
The exhaust fan may be loose, {check mounts} also, the turnable motor that rotates the plate often gets noisey before seizing, {remove plate to see if noise goes away} and finally the magnetron gets very loud near end of life.
May 16, 2012 | Magic Chef MCD1311ST Microwave Oven
Very loud during operation sounds like something got loose during gentle dusting of blades and base
It is possible that the cover must have pushed down or changed the fitting position and moved off to touch when in motion. All what you need is to use a good lader to access the fan-- put the power off and use a tester to see for any leak in voltage to the fan before you touch- now move the blades and listen to the rubbing,if so check the cover and tighten it up. If ther is any bearing noise from the fan use a goos spray from the outside along the shaft( WD40) to wash off any dirt and apply some good lubrication oil, allow it to run and reapply. I hope you try this out. Good day
Aug 15, 2010 | Casablanca Fan (3845T) Brushed Nickel...
Dehumidifier works fine but every now and then the fan is very noisy, as if it is loose or hitting something. Is there a way of checking to see what is happening?
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Good luck.
Jul 31, 2010 | Maytag M7DH65B2A Dehumidifier
When I turn on the tv it sounds like a fan has started up. The sound stays there whike th tv is on. When I turn it of it sounds like a fan windind down. I have a 50 inch LG plasma.
ther are at least 2 fans in them some models even more you however should not be hear them loud ther are all running at half power if it is noisey then it will need to be rplaced before it quits altogether then you will loose something else in the set
Dec 03, 2009 | Televison & Video
Hampton bay fan makes squeeking noise
If the fan is fairly new, remove it and return it to Home Depot. It is almost certainly something that has fallen down into the motor and is rubbing loudly enough to make a squeak as the fan runs faster.
The fan itself has sealed lubrication and you don't have to lubricate it.
Apr 07, 2009 | Hampton Bay 24750 Huntington III Ceiling...
I have model # RS2630WW Samsung regrigerator making a lot of noise that seems to be coming from the back panel area. When I remove the 8 screws, it's seems to be coming from the fan. (I disconnected the...
fan can not be lubricated and they can get noisy.
however, a common reason is the fan blades hitting ice that has built up. check for this
Sep 06, 2008 | Refrigerators
Compaq presario sr2019uk noisey fan
Most likely un related. Make sure their are not wires coming near the fan to make the noise.
If its a 'grindy' sound it could just be the ball bearings wearing out. But if you just worked in their, maybe something is rubbing near it.
Oct 10, 2007 | Computers & Internet
Lous Noise
It could be the blower fan is loose and needs to be tightened. If so, and you're handy, shouldn't be too difficult. Depends on the specific design.
Jun 16, 2007 | Kenmore 72175 Air Conditioner
Dryers Logo
887 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
