Question about HP PhotoSmart 1115 InkJet Printer
Cant install printer drives for HP photosmart 1115 using Max OS 5. Error message: Generic Class: waiting for device connecting but it never connects.
What color and black and white cartridges should I use for a HP Photosmart 1115 printer?
It looks like your Photosmart 1115 printer uses an HP45 black ink cartridge and an HP78 tri-color cartridge. Some HP printers will accept re-manufactured ink carts, while other HP printers will not...just so you know. I've always bought genuine HP ink cartridges on eBay to save $$$.
Jun 23, 2014 | HP Photosmart 2610 All-In-One InkJet...
Printer flashes error "replace color cartridge"
Try unplugging the machine and removing all the ink cartridges.
Now plug the power back in. Wait a minute or two and then reinsert the ink cartridges.
If you get the same message, the machine's ink sensors are probably finished.
Thanks,
Pat
Nov 08, 2010 | HP PhotoSmart 1115 InkJet Printer
INSTALLED NEW HARD DRIVE AND LOST MY PHOTOSMART 4180 DRIVER FOR THE SCANNER TO WORK ON MY COMPUTER
You can download the full software from http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=tr&cc=us&product=1141647& for supported OS versions. Select your OS and click Next. (That link also includes an option to order a new CD.)
Most likely, you had the all-in-one connected to the computer such that a generic driver installed instead when the OS recognized the drive when you booted with the new drive. Uninstall that driver, disconnect the data cable and install the full software.
I hope this helps.
Jul 09, 2010 | HP Photosmart 4180 All-in-One Printer
I need to connect my hp 1115 printer to my windows 7 computer and I don't have disc to install it. Please help!
We can use generic drive of deskjet 550c to install this printer. Just follow the below simple steps to fix the problem.
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers,select HP deskjet 550c and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Thanks and Regards,
Rizwan
Feb 01, 2010 | HP PhotoSmart 1115 InkJet Printer
When I install the D7260 printer using the CD-Rom supplied it works fine. Then after a few days only the top two or three lines of the first page are printed and, after a long pause, the sheet comes out....
Many issues are caused when the HP Photosmart is connected to computer using a USB cable before the HP Photosmart software is installed on the computer. IF you connected the HP Photo smart to your computer before the software installation screen prompts you to do so, you must follow these steps.
Troubleshooting common setup issues :
1) Discoonect the USB cable from the computer.
2) Uninstall the software (if you have already installed it.)
3) Restart you computer.
4) Turn off the HP Photosmartm wait one minute then turn it on.
5) Reinstall the HP Photosmart software.
If your installation is incomplete, or if you connected the USB cable to the computer before prompted by the software installation screen, you might need to uninstall and reinstall the software. Do not simply delete the Hp Photosmart application files from your computer. Make sure to remove them properly using the uninstall utility provided when you installed the software that came with the HP Photosmart.
To uninstall from a Window computer and then reinstall
1) On the Windows taskbar, click Start, Settings, Control Panel (or just Control Panel).
2) Double-click Add/Remove Programs (or click Uninstall a program).
3) Select HP Photosmart Driver Software, and then click Change/ Remove.
Follow the onscreen instructions.
4) Disconnect the HP Photosmart from your computer.
5) Restart your computer.
Note : It is important to that you disconnect the HP Photosmart before restaring your computer. Do not connect the HP Photosmart to your computer untill after you have reinstalled the software.
6) Insert the HP Photosmart CD-ROM into your computer's CD-ROM drive and then start the Setup program,
7) Follow the onscreen instructions and the instructions provided in the Setup Guide that came with the HP Photosmart.
Nov 09, 2009 | HP Photosmart D7260 Printer
Photosmart 1115 will not connect with a USB port
Was the printer new? Try it in another pc to make sure it's all right. Then try another usb cable. When you attach the cable, the pc should recognize when the printer is on.
Oct 23, 2009 | HP PhotoSmart 1115 InkJet Printer
HP PhotoSmart 1115 InkJet Printer Logo
97 people viewed this question
Seeker5211
Seeker5211
