Question about Samsung Instinct Cell Phone
I seem to have gotton moisture inside while
I seem to have gotten moisture inside while talking and sweating phone works but touchscreen does not.anyway to get rid of moisture bubble and repair?
Keeps carboning up had to replace two cap and rotors in 3 years. had wires and plugs changed about a year ago. boot looks wet right now.
I take it you are talking about the distributor cap and rotor. I get the impression that moisture is getting into the housing and it is sweating there. I would say, run it wothour the boot so that there is a breathing space, and for now spray the inside of the distributor with a water repelant spray.
Apr 26, 2011 | Chevrolet S 10 Cars & Trucks
Tank sweats profusly
Sweating tank can cause moisture problems inside bathroom.
Sweating is caused when incoming water temperature is hotter or colder than air temperature inside bathroom.
You can verify this by not flushing tank for several hours and notice that sweating stops once water inside tank warms or cools to same temperature inside bathroom.
Problem can also be cause when there is not enough ventilation inside bathroom and water on tank does not evaporate.
To solve problem:
1) Increase bathroom ventilation and add dehumidifier or fan so condensation drys.
2) Insulate interior of tank. Empty water and let tank dry. Tape off moveable parts. Use can of spray foam and insulate inside of tank. Let foam dry and cut away excess foam.
3) Add tempering tank or staging tank inside room to pre-heat/cool water before it enters tank
http://waterheatertimer.org/Tempering-tank.html
Mar 22, 2011 | Eljer & Titan Elongated Toilet Bowl
The touchscreen us not working at all, the other buttons work
Hello
Do not put lotion on your hands and do not touch the screen if your hands are wet. Any kind of moisture can affect the way the touchscreen operates. Moisture sometimes slows the response time from the screen to the operating system.
Check for a protective sheet on the screen. If there is some kind of a film or sheet on the touchscreen, the screen is likely not able to react to all of the sensitivities of the touch of a finger as it normally would.
If there is an application open and the touchscreen seems to not be working, simply close the application and retry it. A frozen application can usually be closed by pressing and holding on the circular button located just below the touchscreen.
Completely reset the phone by holding the "Home" button and the "Reset" button for a full 10 seconds until the phone resets.
THANK YOU FOR VISITING FIXYA
Mar 07, 2011 | Cell Phones
Hi, when i pickup the phone to make a call, after i press 1 number 4 numbers are dialed? how can i fix this?
there could be moisture/ sweat logged inside the keypad. open the phone carefully , be careful not to damage the phone connections, open the pad side and use a air heater to warm up , this will clear the pad contacts.
Jun 30, 2010 | Cell Phones
Some of my buttons stopped working what can I do?
Most of the time when the buttons stop working on a cell phone it's because either, the user does a LOT of texting or liquid (like water, sweat or moisture) has gotten into the phone. Or, it's been dropped. Either way, it will need to be repaired.
If it was a liquid - like sweet tea (sugar) or sweat (salt) - you may never get it to work right again.
If it's from a small amount of water, a lot of texting, or has been dropped it will need to be sent to a repair facility to have the keypad repaired or replaced. - if there is no other internal damage that has been done to the phone.
Also, you need to consider the real possibility that repairing this phone will not guarantee that the same problem will not re-occur. In my experience, it usually does in a short period of time.
My advice is to get an estimate from a repair facility and then decide for yourself if your money would be better spent purchasing a new phone after learning the cost of the repair.
As a final note, the non-working buttons may also be caused from an issue with the phone's software. You won't know for sure what the problem really is - or how to correct it if it can even be corrected - until the phone is checked by a qualified technician.
Apr 07, 2010 | LG Neon GT365 Cell Phone
My domectic roof top air con is getting condensation on the plastic cover inside the van
Hi; Is the drain for the condensate draining. You will have to check the top unit to see if water is present. You can also check the air filter to see if it needs to be cleaned. Please only use a household cleaner and hot water on the filter screen. Also what is the inside temp. when You notice the sweating. If Your in a very humid climit some times the unit will sweat until it can remove excessive moisture from the inside space. Also does the tstat seem to be working normally and holding temp. ...alpharome416
Feb 22, 2010 | Dometic Rooftop RV Air Conditioner
Moisture Indicator location question Samsung Gleam
Samsung's have 2 indicators now. One inside the battery compartment and one attached to the side of the battery.
The moisture indicator inside the battery compartment will turn pink if exposed to any moisture (including sweat, steam, etc.).
The moisture indicator attached to the battery will show up with pink/red + signs.
Hope this helps.
I am replacing mine right now so I can get a legitimate warranty problem handled.
Aug 07, 2008 | Verizon Communications Samsung Gleam Cell...
Kep pad is not working
sir you have to send it to your nearest shop to clean the keypad membrane maybe its been damage by corrosion sometimes our hands gets sweat or talking someone for an hour our ears get sweat. you don't know that the sweat goes through the keypads.
peace!
Nov 27, 2007 | Samsung C417 Cellular Phone
Samsung Instinct Cell Phone Logo
69 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
