Question about Samsung MJ 4500C InkJet Printer
Installed new black cartridge...says check cartridge
I have error 1200 on my lexmark x4270 fax machine after installing new black cartridge.
The 1200 error code indicates that the cartridge carrier has stalled. It could be due to the new black cartridge installed in the printer. Make sure you are using the correct version of black cartridge for your model and it's properly inserted in the cartridge carrier.
To remedy the problem, try to remove the black cartridge from the carrier > close the cover > unplug and re-plug the printer into the power source to reset it > when the printer turns on, re-insert the new black cartridge > check for any errors. If problem continues, try to insert a different known working black cartridge to determine if the new one is faulty.
For further troubleshooting, you may also refer to this article found in the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
Jul 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
Installed new black cartridge yesterday,now today when I go to print it says cartridge error check documentaion,which Im not sure what they mean ? please help
Hi! Please remove the black cartridge and shake it a little. You need to do this when installing a new set of cartridges. Hope this helps and thank you for using FixYa!
Aug 31, 2010 | HP Officejet 5610 All-In-One InkJet...
Office jet 5510 keeps saying wrong black cartridge.
Look on the right side where the cartridge goes, if the spring on the right is hanging loose it might have poked a hole in the ribbon cable at the rear near the contacts. If so it's time for a new printer, if OK, check the exp. date on the ink cartridge and if it's been refilled or a generic ink you may just need another one.
Jan 30, 2010 | Office Equipment & Supplies
Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Oct 15, 2009 | HP LaserJet 4600dn Color Printer
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
Printer keeps saying "INSTALL BLACK CARTRIDGE".
If you are using Windows.
Go into "Start", "Printers and Faxes".
Right click on the printer icon.
Click properties.
Look for reset cartridge.
Or something similar.
That should fix the problem.
May 29, 2009 | HP LASERJET P1006 Printer
Canon ip 1880 - colour cartridge problem
no if ur filling the catridge more times the printer going to damage
May 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Installed new black ink cartridge on Kodak ESP7. Cannot get rid of Error Message (saying need to install black cartridge!). Help!
Kodak had a batch of bad cartridges, I got 3 of them. All come from China. I used the online chat to describe the problem. They promised to send me new cartridges.
Jack
May 11, 2009 | Office Equipment & Supplies
The black ink cannot be
Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed? Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred? Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If not, do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then there are other things we can try - assuming other solutions haven't worked either. Report back on my queries etc.
Feb 10, 2009 | Epson Stylus C43SX InkJet Printer
Cannot print
It seems that another cart is empty. Check all cartridges when printer is off. And yes, you do need the color ones to print in bk.
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Samsung MJ 4500C InkJet Printer Logo
15 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
