The carriage will not stay fixed in one place. It slides to the end every time I move it back. Sometimes it will stay in place, but as soon as a button is pushed it slides all the way to the end of the row.
  • admiralhawke Sep 08, 2009
    It is a (presumed 1952) Royal Quiet De Luxe manual typewriter.
  • 328 Answers
What is the model or brand?
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Sep 07, 2009
  • Jay Blair
    Jay Blair Sep 08, 2009
    Can you depress the silver leversbehind either of the knobs? Are they spring loaded? If so, then their is a problem with the escapement. Turn it upside down and while you are hitting the spacebar, look up through the bottom middle area and see if you notice a movement of the escapement latch. It also has a spring loaded lever. maybe gummy or broken spring. Spray some lubricant in that area and try it. Good luck.
Beaters will not stay up in my Oster stand mixmaster. The eject lever will not lock them in. Can it be fixed? Or could it be that I need new beaters because they are worn out and don't fit
They need to be replaced or the locking mechanism does, but in the meantime, wind some thread around the beater end and this may keep them in temporarily.
Dec 21, 2014 | Oster Food Mixers
Olympia SM3 carriage gripping problem: my aunt asked me to look at a 50-year old Olympia SM3 that hadn't been used in years. The initial problem was the carriage would never "catch", but acted as if the...
I really am confused by your question, the starwheel you talk about is most likly on the end of the platen (rubber Roller) the star that you talk about is held in a set position by deten roller or wire that falls between the teeth. Usually a lever to release that roller so you can align the paper properly. May the roller or detent is missing, also make sure when you turn the "star" the rubber platen will move also. On the end of the knob there is usually a pin or knob you push in or pull out to allow you to turn the platen freely with no detent. Make sure it is in the correct position, Olympia are excellen machines. Remember do not look to deep, usually simple fix....
Sep 24, 2013 | Office Equipment & Supplies
Remove print head
There is no easy way to remove Epson print head, you have to completely dismantle the printer, to remove the print head, if you see any lever beside the print head, then you can use that to loose it.
Aug 28, 2012 | Epson Stylus Photo 1290 InkJet Printer
Dc07 model, cannot get it to stand fully vertical upright. It is as if something is not sliding back into position right. Don't want to force it in case something breaks. The upright of the cleaner has...
Try this quick repair and see if this fixes your Dyson in terms of not going in the upright position: This is a frequent problem that we see come in on Dysons. If this doesn't fix it, please feel free to just use the clarification request and let me know this didn't fix it.
Step 1.
Turn power off and unplug the machine.
Tilt the machine backward to a 45° angle.
Step 2.
  • Hold the section under the airway inspection pipe.
  • The black forward lock button must be held down simultaneously, otherwise the valve carriage will not move.
  • Pivot this section upwards until it clicks into place.
  • Release the black button once the valve pipe carriage is moved up into place.
    Step 3.
    • Tilt the machine forward.
    • The cleaner head should now slide underneath the part you have just clicked into place.
    • The machine should now stand upright.
    May 02, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    It won't print.
    It sounds like the print head is clogged.
    Turn it on with the cover open, as soon as the carriage moves unplug it. Slide the carriage to the left, you should see a pad on the right side of the printer. Saturate the pad with water, slide the carriage all the way back to the right, let it sit overnight.
    You may have to run it through a few cleaning cycles, but it should print better.
    Aug 12, 2009 | Epson Stylus Color 740 InkJet Printer
    When I turn on the power to the printer, the print carriage cycles to the right as normal then carriage sticks and begins to continually chatter.....at the same time the light bar on the scanner trys to...
    There is usually a sensor on one side or the other of the carriage. When you power up the machine, the carriage will be moved to that end, setting off the sensor. Then it will move back and forth to test carriage motion. If the end sensor is faulty, the carriage will still attempt to move until it triggers the sensor, but when it gets to the extreme end, the motor will continue to attempt to move it, causing the chatter. After a time, it will stop with an error message.
    Look at the carriage where the cartridges are, and you should see some kind of tab or ear on it. If it's broken, then you may get the symptoms I mentioned above. Also if you can see the sensor, make sure that it's not broken or moved out of place.
    Mar 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    HP Officejet 7310 carriage jam
    I'll start by explaining some of the components you need to understand to troubleshoot the carriage system.
    The Carriage is the thing the cartridges are mounted in, it slides on the carriage rail, the bushings in most newer carriages are made of plastic, (or maybe it would actually be called a polymer, or composite material). The bushings are the pieces that wrap around the carriage rail.
    The carriage rail is a shiny round rod that the carriage rides on, it is driven across the rod by the carriage belt, by the carriage motor, at the opposite end of the belt there is an idler pulley, ".
    In a HP printer the device where the carriage parks, (sits at), when the machine is not printing is called the service station, it is responsible for cleaning the print heads, and for capping the heads when you are not printing, (so they won't dry up). The bottom of the service station is the "Spittoon Base", ink is spayed into the base before printing to prime the heads, there is an absorbent pad in the base to soak up the ink. Note that the pad does not always soak up all the ink, so if you tilt an HP printer you can spill the ink out of the service station, (especially if it is a heavily used printer). The piece that moves back and forth in the service station is the "Sled", it was wipers to clean the heads on it, and the caps that keep the heads from drying out are also part of this assembly. The sled is moved back and forth before the carriage leaves the service statio to wipe the heads, this happens after the heads are primed, then the carriage is moved off the service station and the sled is again moved back and forth to clean the wipers.
    The encoder strip is a plastic timing fence that looks clear at first glance, but has black lines painted on it. The strip is threaded through an optical sensor on the back of the carriage.
    When the printer initializes the carriage has to leave the service station, or, if the machine was powered off when the carriage was somewhere else, whatever spot it is sitting in, and travel the way to the other side of the printer, and then return to it's home position which is the service station.
    When the carriage reaches the side of the printer away from the service station it sets that as a reference, then it counts lines on the encoder strip as it travels home, if it doesn't see enough lines before it gets all the way to the other side and can't move any more then the printer decides the carriage must have something blocking it.
    Sometimes a service station will fail in a way where the sled does not retract fully, if that failure happens when the carriage is parked then the carriage will usually not be able to leave the service station. If the service station binds when the carriage is off of the station, then the station may not be able to move all the way to that side, and will detect a carriage jam. When the service station binds you might hear a grinding noise as it's motor tries to drive the sled back and forth.
    If the encoder strip is dirty the printer may not see all the lines and detect an error, often when the strip is dirty the carriage will move too fast and slam to one side of the printer.
    I use water to clean the encoder strips in HP printers, water works well on water based inks, if your printer uses ink with another base you might use alcohol, but "ONLY" if the ink is not water based.
    One end of the encoder strip is attached to a spring mount, if you wipe the strip starting at the end that is attached to the frame, and wipe only towards the spring mount, then the strip will stay attached to the printer.
    A dry carriage rail will cause the carriage to bind, if the carriage does not move fast enough a carriage jam will be detected. Some newer HP printers use grease on the carriage rail, many models use a liquid lubricant, Use "ONLY" light synthetic or silicone based lubricants on printers that use a liquid lubricant, Petroleoum based products may melt the plastic bushings and ruin the carriage. (YES, Petroleoum based means WD-40)
    some HP printers have a timing disc on the service station, and if the service station binds, or the timing sensor fails they report a carriage jam, but as far as I've seen that jam always occurs before the carriage moves.
    You can use a synthetic lubricant on the carriage rail :hope this helps
    Jan 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
    Printer says low level color ink fitted new ink printed ok at first but still said low ink order now and will not let me print or scan
    Dear customer,
    The most common solution is to follow the steps as follows
    1. unplug the power cord
    2. press and hold down the <ON/OFF> button and reconnect the power cord
    3. press the <STOP/RESET> button 2 times and then release the <ON/OFF> button
    4. Display LED show "0" press the <+> button 1 time Display LED show "1"
    5. press the <Start Color > button 2 times and then press the <ON/OFF> button waitng for testing out 2 pages
    6. Open the cover. The carriage that holds the ink will move to the left hand side. and then unplug the power to the printer
    7. Push down on the end of the black cartridge. A clicking noise will be heard.
    8. Slide the cartridge out of the holder towards you.
    9. Push down on the end of the color cartridge. A clicking noise will be heard.
    10. Slide the cartridge out of the holder towards you.
    11. Once both cartridges are removed, unplug the power to the printer (without turning it off).
    12. Reconnect the power cord.
    13. Turn on the printer.
    14. Open the cover. The carriage that holds the ink will move to the left hand side.
    15. Place the black cartridge in the bottom of the printer.
    16. Slide the black cartridge back until is cannot go back any further.
    17. Push up on the end of the black cartridge, a clicking noise should
    be heard.
    18. Place the color cartridge in the bottom of the printer.
    19 Slide the color cartridge back until is cannot go back any further.
    20. Push up on the end of the color cartridge, a clicking noise should
    be heard.
    hope its udeful. thank you.
    Jul 09, 2008 | Office Equipment & Supplies
    Canon Pixma ip3000
    the code strip is the plastic strip that runs across the printer and through the head
    carriage, it is supported at each end (one end under spring tension).
    If it has become dislodged it will cause this problem. carefully try to place it back into place
    Oct 11, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
    61 people viewed this question
    k24674
    jasbo
    jasbo
