Question about Refrigerators
My freezer isn't freezing things anymore. The fan is running but everything is defrosting.
    Problem Solver:
  • 5 Answers
Check that the door fully closes. Clean/vacume the condenser coils (could be on back or bottom owners manual should show). check thermostat setting. Can you hear or feel the compressor comming on? If not than it could be wiring to the coolant pressure switches, or bad swicthes or out of coolant or bad compressor motor. If the compressor comes on than check that the condenser coils get warm. If not warm than compressor is bad or low on coolant.
Posted on Sep 07, 2009
  • 115 Answers
Turn your freezer of and let it defrost for 2days,then turn it on should be working good,if that dosent fix it your compressor is bad will need to be replaced.if my info is of any help to you please leave a comment,vote,note,thankyou.
Posted on Sep 06, 2009
Whirlpool freezer won't freeze
you need to send the model number so i can see what fridge you have,is it a side by side freezer on top or bottom.check the back inside wall of the freezer to see if any ice or like snow is on the back inside wall of the freezer,if so you have a defrost problem,if it's a top freezer is there any water leaking into the fridge section,check under the crisper draws,if water is there you could have a blocked drain in the freezer,the water that's from the defrost mode leaks into the air ducts and freezes,or you could have a freon leak in the sealed system,remove the inside back wall of the freezer and check the frost pattern on the evap coil,if there's frost just on the top of the coil and nowhere else on the coil you have a freon leak,one more thing you could have a bad evap fan motor,open the freezer door,you should hear the fan blowing around,open the freezer door and push and hold the door or light switch in for a minute and then let it out,if the fan doesn't run it could be bad.the last thing is the compressor isn't running and you're hearing the condenser fan running and not the compressor,the start device on the compressor could be bad,feel the compressor,is it hot and feel it to make sure it's running.so bad start device,freon leak,defrost problem or bad evap fan motor or condenser motor.if you get back to me and let me know what you find and send the model number i can help you better.
Nov 02, 2011 | Refrigerators
I have a kenmore refrigerator side by side. my problem is that my freezer is not freezing the top where the ice is. everything was melting and defrosting inside the freezer except the lower part. i need to...
If lower section of the freezer is working but upper not the most likely problem is going be the fan in the freezer isn't running. Do you hear that fan running? if fan is not running it also wont circulate air into the fresh food(ref) compartment. If it isn't running you can possibly jump start it by removing back and flinging the fan blade with your finger to get it going till you can get replacement
Good luck,i hope this helps
Gene
Aug 01, 2011 | Refrigerators
I've recently been having trouble with my american fridge freezer. The freezer isn't freezing and the fridge is barely cold. The motor is working and there is some cold coming from somewhere but...
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food
As for the fridge, the same solution but for more details. If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover. 2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover. 3. Disconnect the defrost thermostat wiring connector. 4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Good luck.
Jul 10, 2011 | Refrigerators
My kenmore refrigerator model # 363.9771611 runs but is not cooling and the freezer is not freezing
Fan Problems
One of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food.
Other Causes
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
Have a good day! : )
May 04, 2011 | Kenmore Refrigerators
My chest freezer (10 years old) won't freeze. Motor is running and the red indicator light remains on, but neither the amber or green lights are working.
Regards.
May 01, 2011 | Whirlpool 10 cu. ft. Chest Freezer...
Wont freeze
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food........
Take care.
Apr 30, 2011 | Turbo Air Freezers
Freezer not freezing .. It's cold..
I hope this helps........
Take care.
Apr 12, 2011 | Northland Panel Ready Upright Built In...
My whirlpool chest freezer runs but does not freeze?
Best regards.
Apr 07, 2011 | Whirlpool Freezers
Freezer is not getting cool
Hello.
The first thing you need to do is take out the bottom drawer in the freezer and look into the slots in the back panel. Make sure that you can see silver coils, and not a bunch of frost. If there is, then you need a new defrost timer, defrost heater, or defrost terminator.
If this checks out ok, make sure that the coils underneath are clean and the fan is also turning (underneath the unit).
If all looks ok then make sure the fan in the freezer is running. (You may have to push the door switch if yours has one.) If the freezer fan isn’t blowing however, the freezer will be warm at the top and cool at the bottom, and you fresh food compartment will be warm.
Another thing to make sure is that the light it turning off when the door is closed. Again you would have to push on the door switch. I was amazed to learn when I first started this line of work, that even a little light bulb can make enough heat to cause a problem.
Let me know if everything looks ok and I will go over some other things, as the list of things that can go wrong with a refrigerator is fairly long.
Dec 07, 2008 | Kenmore 53642 / 53644 Side by Side...
My frigidaire refrigerator does not get cold, but the freezer is really cold and freezes up. there is huge sheets of ice that form in the freezer and the food in the refer goes bad.
My problem also is that freezer is cold but fridge gets warm. When I turn the whole thing off for a sort time it works again.
How would I know which part needs to be replaced to repair this?
Rod
rodbutler@psci.net
Jul 07, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
