Question about HP Compaq nx9420 Notebook
The sound on my compaqnx9420 does not work at all. When I am under the control panel to look at sound and devices, the audio is not even an option. How do I fix it?
  • HP Master
  • 32,281 Answers
You need to download the audio driver from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the XP or Vista Windows version of the drivers you require and install them. Use this link to download the drivers
http://h18000.www1.hp.com/cpq-country/cpq_support.html
Posted on Sep 06, 2009
The speaker test works on realtek speakers but otherwise no sound can be heard (even when un-muted)
- Click on the "Start" button
- Click on "Control Panel"
- With the Control Panel in "Control Panel Home" view please click on "Hardware and Sound"
- Where it says "Sound" in green letters there are three options below that are in blue click on "Manage Audio Devices"
- This will bring up a window labeled "Sound"
- On the "Playback" tab there is listed the sound options available to you. One should read "Speakers HD Audio Device" Click on that.
- There should now be a check mark on that option.
- The Sound should then play through your Speakers
May 02, 2011 | Acer Aspire 5610-4648 Notebook
My microphone is built in to the computer but will not even show up in my recording devices. it used to work fine and now it doesnt say it even exists on the computer.
See last paragraph of instructions below re unlisted devices.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 19, 2011 | Compaq Audio Players & Recorders
How do I unmute my computer?
Go to Start, then select Control Panel. In the Control Panel window, select Sounds and Audio Devices and the option will be under the Volume tab of the Sounds and Audio Devices Properties window that opened. If you're using Category view of Control Panel, click on the Hardware and Sound category and then click on Adjust System Volume under the Sound option.
Hope this helps!
Dec 16, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Hello i have a tsoshiba tecra laptop and i wanted to find out if i have sound or not and were is it located to see if i need a sound card or not
Hello
Dear Friend...
You can check your Device Manager under My Computer / Right Click / Properties / Hardware Tab / Device Mgr
You need to check the Control Panel / Sound and Audio Devices / Audio Tab / Sound Playback option.....
if it's greyed out then u dont have a Sound card or the card is corrupt....
if no internal sound card is present or if it's not working then u have this alternative....buy a " USB Sound Adaptor" and connect it to the USB port and connect the speaker sound jack to the sound port in this adaptor....u will get back the sound....also keep in mind that u " may " have to disable onboard sound in BIOS, u may also have to make changes in the Control Panel / Sound and Audio Devices / Audio Tab / Sound Playback option... Click the drop down button and select the "USB Audio Devices/Headset"
You can get this in Ebay for $1 to $4 or google it to locate a place near u......
This is the one i am refering to(I bought it in Ebay for 1$)....u can buy something similar also....there are many available, all of them are made in China, as it's USB enabled plug and play, connect it to your PCs USB port....you will not need any software or driver to install it....Winodws will auto install it and show it under the Device Manager / Sound Audio and Games Ctrlr as told above and will also show it under Control Panel / Sound and Audio Devices
If you find this solution useful please leave a feedback and rating to this solution.
Regards....
Mar 03, 2010 | Toshiba (4CH-VOUT) Sound Card
My microphone isn't working. I've checked the control panel, and I have the microphone not muted and set at medium level. This happens a lot, and I can never remember what it is I am doing wrong.
Hi ,
Test the record function on the notebook PC
  1. Click Start , then Programs , Accessories , Entertainment , and then Sound Recorder .
  2. Click Record (the red dot) and speak into the microphone.
  3. When you are finished recording, click Stop (the gray rectangle).
  4. To play back the recording, click Play (the gray arrow pointing to the right).
  5. If the recording does not play back, continue to the next section of this document.
Step 2: Checking microphone settings
  1. Click Start , then Programs , Accessories , Entertainment , and then Volume Control .A Volume Control or Master Volume window opens.
  2. Click Options , and then Properties .
  3. Select Recording , and make sure Microphone is selected.
  4. Click OK . The Volume Control window should change to a Recording Gain Control window.
  5. Click Options again and then click Advanced Controls . If Advanced Controls is unavailable, then an alternate microphone is not available. Proceed to the next series of steps.
  6. Remove the check next to Alternate microphone , click Close , and test the microphone. If there is still no sound, continue to the next step.
Step 3: Ensuring the correct recording device is selected
  1. Access sound properties:
    • In Windows XP, to access the sound control panel applet, click Start , then Control Panel . Click Sounds, Speech, and Audio Devices , and then click Sounds and Audio Devices .
    • In Windows 95, 98, and Me, click Start , Settings , and Control Panel . Double-click Sounds and Multimedia , or Multimedia . The Sounds and Multimedia Properties window opens.
  2. Click the Audio tab.
  3. Under Sound Playback , select the audio device that is installed on the computer (there should be only one).
  4. Under Sound Recording , select the audio device that is installed on the computer. It should be the same as the listing under Sound Playback .
  5. Click OK .
  6. Close the Sound and Multimedia Properties window and test the recording. If there is still no sound, continue to the next step.
Kindly send me you valuable Feedback.
Jan 29, 2010 | Sony ACID Music Studio 7
Recently installed binatone S1545 onto computer running xp home. works well but unable to stream music (mostly from Spotify) whilst it is plugged in. Get message on Soyify '' There is a problem with your...
On windows got to "START"
Control Panel/Sounds and Audio Devices.
Audio tab select sound card as Sound playback default device
Voice tab select sound playback default device
Open Skype got to tools/options/audio settings.Select USB device under Microphone and speakers section.
Save all settings. Works well.
Dec 27, 2009 | Computers & Internet
Hdmi audio not working when conected to tv
Follow these steps to change the audio output settings for the HDMI option.
  1. Follow steps 1 through 8 above.
  2. From the Windows Vista™ default Start menu, click Control Panel.
    View Picture
  3. In Control Panel, using the default Control Panel Home setting, click Hardware and Sound.
    View Picture
  4. In the Hardware and Sound window, under Sound click Manage audio devices.
    View Picture
  5. In the Sound dialog box, click to select Digital Output Devices (HDMI).
    View Picture
  6. Click Set Default, and then click OK
    View Picture
Note: The default audio setting for your notebook is Speakers / Headphones.
You must change the audio output back to the Speakers / Headphones option for the computer to once again be able to use the internal speakers and headphone jack.
Sep 24, 2009 | Gateway T-1620 Notebook
I want to download conexant hd audio 221 xp c770tu diver how can
The headphones would not be the issue unless they came with an actual software cd included. If your audio Drivers are not the correct ones for your audio device on your computer, download the proper ones. Best way to find out what you have is to look under Device Manager which is in Control Panel, Under the System>Hardware Option in the Control Panel Folder.
Verify that your device is working properly. If it is working properly. and All other audio options, like Speakers work, then the Headphones are malfunctioning and you will need to contact the manufacturer.
If no audo works at all but the Device is listed as working properly, then you possibly have a damage audio jack port
Jan 20, 2009 | Audio Players & Recorders
Sound system
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
or else put the model number and brand name followed by drivers search in ww.google.com
Sep 21, 2008 | Sony VAIO TR1MP Notebook
Microphone
  • START
  • Control panel
  • Sounds and audio devices
  • Advanced (Under "Device Volume")
  • Options
  • Check Advanced controls
  • On same drop down menu click Properties
  • Under "Show following volume controls" check Microphone
  • Microphone volume control should appear
  • Uncheck "Mute" below mic volume control
  • Move slider up
Now also do this:
  • START
  • Control Panel
  • Audio
  • Under "Sound recording" select device in which you've plugged in your microphone
  • Voice
  • Under "Voice recording" select device in which you've plugged in your microphone
  • *If you're not sure in what you've plugged in your mic than select "Test Hardware" under "Voice recording".*
  • Click Apply, click OK
May 10, 2008 | Plantronics Audio™ 350 Headset
HP Compaq nx9420 Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
