Question about Nextar X3-03 Car GPS Receiver
It is stuck and i can't get it to do anything
    Brigadier General:
  • 4,090 Answers
"Stuck" Doesn't quite tell me enough information to offer a definte clue as to what is happening.
1) If it does not navigate and just stays on a previous map the it is not locking onto satellites.
There are a e few reasons this might happen.
a) The battery is not charged enough
Use the AC charger
b) The unit is not set up to the right baud rate or the correcyt port
Go to settings and either use the AUTO to get it right or enter the correct parameters from the manual
c) The unit does not have a clear view of the sky
d) The SIIRF chip is damaged from having the unit plugged in when starting the engine
The unit turns on and shows the menu, you select navigate and it commeneces to load and then stops and does not proceed.
a) The maps are corrupted
b) The battery is low
CHARGE then RESET THE UNIT Hold power button and use a paper clip to push reset button.
Posted on Sep 07, 2009
My maytag jetclean dishwasher quiet pack makes a grinding noise and the sprayer doesnt spin
Take apart the sump filter area and check to see if anything is stuck in the impellers for the wash motor.
Jan 01, 2015 | Maytag Dishwashers
My camera isnt working, its not doing anything, stuck with the lens open and wont do a thing
This is not a do it yourself problem. Go to the Nikon USA webpage and find the Nikon Repair Depot nearest you. They will give you a repair estimate. You can then determine if it pays to fix your camera or replace it.
Oct 12, 2012 | Nikon Coolpix L22 Digital Camera
Hi I have a cannon mp470 and it will not pull paper through to print. It either doesn't catch at all, or it will jam to one side.
Hi
There is something stopping the paper feed process. Try the following
1. Check and make sure nothing is fallen inside the paper tray
2. Remove anything stuck
3. Even if you are not able to see anything stuck tray to use a air blower and blow air in the tray this will remove anything stuck.
Jul 15, 2011 | Canon PIXMA MP470 All-in-One Printer
Camera won't show anything but black in the screen ... Or looking through the eye piece (canon S3 power shot) think the cold weather caused it
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 14, 2010 | Canon PowerShot S2 IS Digital Camera
It would appear to be permanently stuck on the
Reformat it using a computer, probable cause disk error. If the problem is persist try to contact service center.
Jan 30, 2010 | Sony Network Walkman NW-A1200 MP3 Player
Cannot take picture, no film advance, new battery
The shutter could be stuck or the mirror could be stuck. (Guessing you have an SLR.)
The film advancing is normal; means it is cocked and ready to go but something is stuck.
Take off the lens and see if anything is keeping the mirrors/shutters from returning.
Oct 23, 2009 | Canon EOS-AE-1 35mm SLR Camera
4F unable to print
I have a similar problem, nothing stuck in the printer. It needs a new print head (costs more than a new printer).
May 31, 2009 | Brother Office Equipment & Supplies
Stuck on park
sounds like a neatral safety switch problem
Nov 11, 2008 | 1992 Buick Park Avenue
Cant get the paper jam paper to turn off and work again
1- either there is something stuck on the sensor or
2- the sensor is bad or out of place
Aug 19, 2008 | Sharp AL 800 Copier
Nextar X3-03 Car GPS Receiver Logo
125 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
