Question about Magic Chef 31000 Gas Kitchen Range
F3 error on magic chef electrical range
I keep getting a F3 error
  • 794 Answers
Hi glrecu,
The F3 fault code description is a shorted or open oven temperature sensor (RTD). Please check the sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Hope it helps.
Thank you for using FixYa.
Posted on Sep 19, 2011
Oven wont come on f3 code magic chef gas range
Hi hardcaseone,
Hope it helps.
Oct 28, 2010 | Magic Chef 31000 Gas Kitchen Range
Magic Chef oven displays F3 everytime the bake or broil button is pushed. Not sure what the model # is. Electrical range.
this could be a an open probe or shorted probe connection.you need to check your temp probe harness to your main board.
there is a chance that you need to replace your temp probe.
last thing would be to replace the EOC
Feb 12, 2010 | Magic Chef Ovens
Magic Chef Elec. Oven F3 error code
check temperature probe , if connection is good at connector then replace sensor
Nov 18, 2008 | Magic Chef CER3760 Electric Kitchen Range
F3 error code
I keep getting an error code of F3 for my Magic Chef stove model CER3520AAL does anyone know what that means and how to fix it?
Help!!!
Dec 12, 2007 | Kitchen Ranges
MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Nov 18, 2007 | Maytag MGR5751AD Gas Kitchen Range
Magic chef electric range model 38HK-6TXW
MAGIC CHEF
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad F6 means no ac signal and will need to replace the oven control.
Oct 18, 2007 | Magic Chef CER3725AA Electric Kitchen...
Magic Chef 31000 Gas Kitchen Range Logo
378 people viewed this question
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
