Question about Dryers
HOW TO REPLACE TO HEATER ELEMENT - Dryers
    President:
  • 1,776 Answers
Check out the video at the link I am providing. It should assist you in replacing the heating element. Sure hope so, anyway! Best wishes.
http://www.youtube.com/watch?v=f1rebeCMVsk&feature=fvw
Posted on Sep 06, 2009
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Have power at top element but not bottom
1) Copy following links:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/How-to-replace-water-heater-element.html
2) Upper element is good because you have some hot water.
Circuit breaker and power to water heater are probably good.
Step 1: Test lower element. Replace if needed.
Next step, If lower element is good: Replace upper and lower thermostats.
Jan 06, 2013 | Water Heaters
I need to replace the lower element on my Bradford White Electric Water Heater. Where can I find the element and directions to replace it?
1) Copy following link for testing steps, and clear steps how to replace water heater element on residential water heater.
http://waterheatertimer.org/images/element-wrench-on-element.jpg
2) Your Bradford White most likely uses screw-in type element
Older models use flat flange type element.
3) Buy elements at local hardware.
Match wattage of new element to wattage that shows on label on side of tank
Jan 03, 2013 | Water Heaters
Hot water element
Make sure wires are removed from element when ohm-testing.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Watt and voltage rating of element appears on end of each element.
Volts squared divided by watts = correct ohm testing.
Two-element water heaters are rated for 240Volts, but can be wired for 120Volts.
Check that water heater is receiving power from circuit breaker box.
So if breaker is 2-pole 240Volt, then check that heater is receiving 240 V across top two screws on upper element.
Replace upper element.
Other resources.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Oct 02, 2012 | Water Heaters
My water heater has power at top element but not bottom...however the top element will not turn on either
Yes, the reset probably is tripped...push in the red button hard
Then turn it on and try it...
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Jan 28, 2011 | Rheem Water Heaters
It has cold water comign out no hot
heatman101
Jan 18, 2011 | RELIANCE ELECTRIC WATER HEATER
My water heater wont heat up
You posted under Marathon electric heater.
If you have tankless or tank-type gas heater, information below does not apply.
Absence of hot water say upper element is not working.
1) This can be caused by tripped reset button located on upper thermostat. Open upper cover and push in reset button. Put ear against tank to hear bubbly fizzing sound. Put insulation and cover back over thermostat. Continue reading information below because reset button trips when thermostats are bad or element is shorted.
2) Upper thermostat is bad. Replace upper thermostat. I usually replace both upper and lower thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) Electricity going to water heater from breaker box is interrupted.
4) Upper element is bad. Test element. Replace element if needed.
5) Add a comment for more free help.
6) Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 17, 2011 | Rheem MR105245 Marathon Electric Water...
We installed a brand new Reliance Electric Hot Water Heater, but no hot water, only lukewarm! Replaced top heating element and still no hot water!! Any suggestions as to what we need to do now?
If you have some hot water from dual-element water heater, then that tells us:
Water heater is 240Volt.
Upper element is working. If upper element is not working, then heater has NO hot water.
Reset button is not tripped.
Electricity and breaker to water heater are delivering 240Volts to heater.
Remaining suspects are:
1) Bad upper or lower thermostat: Solution: replace both thermostats for 28$.
2) Bad lower element: Solution test and replace element:
3) Loose wire or loose connection: Solution: open both covers and inspect for burning. Tighten all screws very tight.
4) Bad wire: Solution: Buy cheap multimeter from Home Center and do a 30 minute troubleshoot of entire water heater before replacing any parts:
When testing for voltage, rotate multimeter dial to 240-250-277VAC
When testing elements or continuity, rotate multimeter dial to Ohms.
Jan 10, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a Reliance 501 water heater, when I take a shower now I only get about 5 min. of hot water is there something on the heater I have to reset? Thnx Mike
Electric water heater is fully repairable by homeowner.
Following information will tell you how.
1) Background on your heater:
Reliance is AO Smith company.
http://www.aosmith.com/OperatingUnits/Detail.aspx?id=138&ekmensel=c580fa7b_12_0_138_3
Age of water heater is shown in serial number. First character is letter. Second 2 characters are numbers, which are year of manufacture. For example 05 is year 2005.
The 501 manual is not shown on Reliance website:
http://www.reliancewaterheaters.com/prod/elec.html
2) Two things known for sure:
- electricity is OK
- upper element is working because there is some hot water.
3) Three things can cause problem you describe:
- Loose wire located from upper thermostat to lower element and thermostat.
- Upper or lower thermostat is bad
- Lower element is burned out
4) How to troubleshoot and repair
- Turn off power, open covers and look for loose and burned wiring, especially on lower element.
- When finished, put back insulation and covers so thermostat not exposed to cooler temperatures.
- Burned wire on lower element is evidence that lower element is burned out.
- If you do not want to follow testing steps below, next step is to replace both upper and lower thermostat for about 25$ and see if problem persists.
- If problem persists, replace lower element.
5) Test lower element, before replacing anything
6) Troubleshoot electric water heater
7) How to replace lower element and clean sediment out of tank:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
Nov 17, 2010 | Reliance Water Heater #6-50-DJRT 50GAL...
Replace Heater Element for Whirlpool Model GU 1200XTLB1 Dishwashr
Look inside the dishwasher to see where the heating element terminals are. If they are in front you might be able to change it but if the element is in back, you will need to have the dishwasher pulled out to install the element.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Dryers Logo
91 people viewed this question
Top Dryers Experts
