I have a Philips Plasma 50PF9431D/37 shuts off/red light blinking
I've searched around and most say something is wrong with the Y Main or the Buffer. I opened the TV and I found 2 blown caps on the Power Supply Board. So, I'm wondering if that is the issue and not the Y Main like everyone is saying. I would appreciate the help, thanks!
  • SD Tech
    SD Tech May 11, 2010
    power supply problems can cause other problems--replace the caps---the boards for this set are very expensive--if you found buldged up caps on the power board you may have found your trouble.
    Habit-Forming:
  • 108 Answers
If the caps you are talking are numbers C8059 & 8060 rated at 3300uF @ 10v then yes that can be the problem. You can use a higher voltage rating( 16v,20v,) but DO NOT change the micro farad (uF) rating. You can do a search for the caps but www.mcmelectronics.com has alot of parts. Go to service parts and components in thier website and then search under capacitors.
Posted on Sep 07, 2009
Philips 50PF9630A/37 plasma TV will not power on and has a red blinking light - 6 slow flashes then 3 quick flashes . I've been having the issue on and off for about 2 weeks. seems like when I ...
Hi.
The TV is forced in standby because an internal fault has been detected. 6 blinks slow and three fast blinks points at defective Ysus board or defective buffer. The power supply must also be tested. Till now the TV was starting because when you disconnect power you discharge internal components. Some of the components have the role of storing charge (the capacitors). If a capacitor is defective the TV may still work as other components will compensate the function of the faulty part. After a while more components will fail and the TV will not start anymore. To fix the problem the TV must be tested at component level. Testing will start from PSU voltages to YSus and buffer boards.
Regards.
Ginko
Aug 04, 2011 | Philips 50PF7220A Television
Philips 50pfp5332d/37, 16 months old, sound but no picture. I am not seeing the blinking red lights as others have mentioned. After removing the back I do not see any bad capacitors. Tried both hard reset...
The Y-buffer could be bad..Or worse the Main Y-board needs replaced and you will have replace the top or lower Y-buffer board..see a Philips Tech in your area. These sets are still new for me and at best this is my current knowlege as I have not repaired one yet! Hope I gave you a good lead!
Nov 20, 2009 | Philips 50PFP5332D 50 in. Plasma...
7 red blinking lights on tv
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Jun 06, 2009 | Philips Magnavox 27MS343S 27" TV
System will not power up
Remove the back from the set and look at the power board in the center of the TV. It will probably have one of more capacitors with the tops bulging out. Replace them with the same value part. Available from radio shack and almost any electronic suppliers.
May 16, 2009 | Philips 50PF9731D/37 50 in. Plasma...
42 Philips Plasma 42pf5321d/37 green light on no AV no Menu nothi
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
May 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Tv red blink no start42 plasma philips
May 07, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
My 50PFP5332D/37 Philips plasma tv stopped working. The TV turned off while I was watching it and now there is no power coming into the tv. I unplugged it for a few hours and tried plugging it back in...
You may need to replace the Y-buffer to say the least. And if this is not the problem, you will need to replace theY-main board. If the Y-main board is bad you will also change the Y-buffer. Please see a Philips Tech!!!
Mar 11, 2009 | Philips 50PFP5332D 50 in. Plasma...
I have a 50" philips plasma , shuts off and blinks red light 2 and 7 times Y main board module problem?
this web site has a philips service manual that might help. I have to say, you have to be somewhat technically inclind to understand it. http://www.scribd.com/doc/6528782/Philips-42pf7320
Nov 07, 2008 | Philips Magnavox 42MF521D/37 Television
Keeps turning off-Philips 50PF9431D
63 inch samsung plasma turn off then back on buy its self
Nov 14, 2007 | Philips 50PF9431D Television
Televison & Video Logo
625 people viewed this question
Top Televison & Video Experts
Electro Med Services...
