Question about Samsung LN32A330 32 in. LCD TV
I have the same exact problem with my LN T375HA - W
About how much should i expect to pay for this repair? who do you call for repair? samsung, or any local tv repair place?
  • Anonymous Mar 28, 2014
    LN-T375HA
  • 585 Answers
Hi my name is Eric,
I hope I can help you with your issue ,
The TV not starting properly you should hear the tone noise (bleep bleep) not a ticking noise or no sound .
These Samsung LCDs have problems with the power supply capacitors going bad, a servicer will charge between $200 and $450 to repair it replacing either the capacitors or the whole board.
here is a DIY (do it yourself) solution:
It could be just a few bad capacitors on the power supply, if you want to attempt the repair yourself you can do a visual of the power board caps will appear swollen on to.
We do not recommend do it yourself, but depending on your knowledge and technical ability you may be able to.
with the back removed you will usually see two circuit boards the upper one is the power supply, it has a few capacitors on it (cylindrical standing straight up soldered in mark on the sides with the positive/negative sides and MF and Volts values)
Samsung uses mostly 1000Mfd at 16Volts rating capacitors, they cost about $1 each (680mfd will also work fine)
usually I replace about four of them (or all the bulged on top ones) .
The power board and back unscrew with a medium philips screwdriver, if you do not know how to desolder and resolder then do not attempt this as you may damage the TV more than fix it.
Im am posting a photo of some swollen caps on a board so you know what they look like;
best of luck to you
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Posted on Sep 07, 2009
Samsung TV LN-T375HA, has audio but as we were watching the screen went blank. The audio is still on and can here the show. Any ideas?
Hello Ken Churley,
Your power board...!!
Verify the number YOURSELF (but likely)
BN44-00157a (Very popular: about $36 & up)...
If you (REMOVE ALL POWER) ... take PICTURES...
FORCE NOTHING and
put EVERY wire & fastener EXACTLY back where
you found it you too...
can join the LEGIONS of happy & accomplished
SAMSUNG owners who have repaired their own equipment...
The STATIC WRIST strap is VITAL to you success
(see below)...
THE PARTS PLACE is SHOPJIMMY.COM
(see below)
Also: Sears... eBay... even AMAZON
Search results for SAMSUNG ln t375ha power
http://www.shopjimmy.com/samsung-bn44-00157a-power-supply-unit.htm
Amazon com Rosewill ESD Anti Static Wrist Strap Components RTK 002 Black...
Jul 20, 2017 | Samsung Televison & Video
When I turn TV on with either the remote or push button on front, it automatically switches on and off several times before "catching" and staying on
yes ,, the problem on ur tv is the power supply , u have bad capacitor , now this problem is under recall by samsung , u may want to call 1-800-samsung that way u dont has to pay for repair
Nov 30, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
My Samsung LN S3238D won't turn on. It suddenly went out one day for no reason. I've checked the capacitors in the back and they are fine. No clue what it could be and I don't want to pay someone hundreds...
hello, Normally the power supply board has to be replaced. It is cheap if you do it yourself since you only pay for the board. These sites normally sell them, shopjimmy.com or discount-merchant.com
hope this helps
Aug 26, 2010 | Samsung LN-S3238D 32 in. LCD HDTV
Picture on Samsung lcd LNT5271F is blurred sometimes lines color distortion double images then goes away and will come back. Part of the screen will go completely lines then come back. Starting to happen...
Had this exact problem diagnosed by a local repair shop as a bad LCD panel. According to the technician there's a loose ribbon cable on the panel and it would cost as much to replace/repair as a new TV.
May 12, 2010 | Samsung LN-T5271F 52 in. LCD Television
I have a Samsung LCD (LN-T5271F) about 2 years old and lately when I turn it on, it clicks on and off several times before it actually stays and the tv comes onI have a Samsung LCD (LN-T5271F) about 2...
Call Samung customer service, they are doing this repair for free. I had the same problem at 11 months, they replaced the power supply board under warranty. At 2 years I had the exact same problem again and this time they replaced 2 - 50 cent capacitors on the power supply board. It took the repair man less than an hour and he had the replacement capacitors on hand. The original board and the replacement board they gave me had capacitors that were faulty. Hopefully these new capacitors will last. I have to say that I was thinking (no more samsung products for me) but I got excellent customer service and they admit that they had a faulty product and they accepted responsibility.
Apr 26, 2010 | Samsung LN-T5271F 52 in. LCD Television
I have a samsung ln-t375ha my screen blacked out but i still have backlighting and a on power light but no screen
The T-Con bd or the Main bd is bad. Have a tech check it out. There is no way to check these bds with a meter.
Apr 15, 2010 | Samsung LN-T375H 37 in. LCD Television
About how much should I expect to pay to have the power supply board replaced by a tech. or repair shop. Again, the TV is a Samsung LN-T4053H.
The power supply module can be from $179 plus tax and shipping from
http://www.discount-merchant.com/ProductDetails.asp?ProductCode=1040332-SAMSUNG&Click=35
The labor can be up to 2 hours. Do you have pictures of the bad power supply and the symptom?
Please post back what you find.
Nov 13, 2009 | Samsung LN-T4053H 40 in. LCD Television
Vertical multi-color lines in center of flat screen (samsung) I just want to know if it is worth repairing
$150 in repaires if done at a shop and if you did it way under that all you neeed to do is replace the inverter onthis and you will be set for a couple more years!
Jul 18, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung power-up problem
two 2200uF capacitor, two 1000uF capacitors on powersupply board.
Replace it! you will save $300.
Jun 19, 2009 | Samsung LN-T5271F 52 in. LCD Television
My Samsung LN-S4692D
before you give up..call samsung directly, they are very consumer oriented and if it is only a couple months out of warranty you might get them to repair it,, 1 800 samsung
Nov 20, 2007 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN32A330 32 in. LCD TV Logo
512 people viewed this question
Henry  Thomas
Henry Thomas
