Question about Boss Rc 50
Is it possible to upload my own Rhythm Guide Patterns (drum loops) instead of the factory presets in the boss rc50 loopstation? if yes, how, in wav files or midi or how? thx
  • 24 Answers
USB port for data/audio backup, import/export of loops as WAV files http://www.bossus.com/gear/productdetails.php?ProductId=772
Posted on Sep 10, 2009
How to do a factory reset on a alesis s r 16 drummer
Power up while holding play-erase. BUT...when performing a re-initialization, this will erase all existing patterns, songs, and drum assignments. This will not erase the factory preset patterns or kits.
http://community.alesis.com/alesis/topics/sr-16-factory-default-reset-question
Sep 27, 2017 | Alesis Music
Boss DR-3 Dr. rhythm LED screen lights up by does not show any information. what can I do to fix problem?
take it appart. there is a conductive rubber between lcd pannel and the pcb use widow washer fluid without amonia to clean it
Jul 20, 2016 | Roland Boss Dr. Rhythm DR-3 Drum Machine
I have a 1990 Alesis SR16 drum machine which has not been switched on for over 10 years. I now wish to use it again but all data including factory presets have been lost. How do I re instate them
How do I reinitialize SR-16?
Power on while holding: "ERASE" and "PLAY".
Evidence: All User songs and patterns will be empty.
Note: Clears memory
Clears the SR-16's User Songs and Patterns, but leaves the Preset Songs and Patterns intact.
Feb 15, 2015 | Alesis Sr 16 Stereo Drum Machine
Can i add more memory to the rc50 loop pedal
You can make a backup on your pc and load back Default settings or restore to default settings. Normally you should have I quote ' with up to 49 minutes of mono recording time (or 24 minutes in stereo), the RC-50 can function as a song recorder as well as a looper'
I have the RC300 which has 3 hrs recording time. But when i reach the limit. I make a backup and load back in a initial default setup which I have downloaded somewhere. But you can also restore to default from the unit itself. Hope this helps
Apr 14, 2017 | Boss Rc 50
How to save loops on the rc50
http://www.roland.com/support/article/index.cfm?q=manuals&p=RC-50
I tried to look at this and get the valuable information but it requires a few steps. This is a link for the product manual, what you are looking for is on page 20 I think
May 21, 2012 | Boss Rc 50
My Boss RC-50 has stopped working. I used the power chord for my RC 50 in my Boss OC 3 pedal and then tried using the chord in my RC 50 again and it won't work. It won't even work with other power...
CHeck the voltage out of the adapter. It should be around 9 to 11 volts. If it is not, it is possible that the OC3 has reversed polarity AND a protector that put a short on an incorrect supply. If so, it could have damaged the RC50 adapter. If the RC50 adapter is putting out correct voltage, then I suspect the inout connector on the RC50 may be damaged or not quite seated. Visually inspect the connector first.
Dec 04, 2010 | Boss Rc 50
How do I delete a track that has been 'written',
You didn't mention which model loop station you have so I'll direct you to the link:http://www.bossus.com/gear/productdetails.php?ProductId=477 The RC20XL for instance has an undo function.The RC50 has an update to ver.1.01 also that you can dowload. I hope this info helps.
Nov 23, 2009 | Boss Micro BR Digital Recorder
I bought an Alesis SR-16 drum machine from an online seller advertised as "new". I plugged it in, and it appears that my "new" machine has had all the factory preset patterns erased! Is there a way to...
Hi.
The SR-16 has 50 preset patterns that are built in, I do not think they can be deleted, if there are no patterns the unit may be defective, even if patterns can be reinstalled using an rmidi file or re-flashing the unit.
To reset an Alesis drum machine you have to hold down both Play and Erase buttons while you power on the machine at the same time.
If that does not work, the presets are held into an rmidi file , the Rmidi file is not available for download. I think it can be purchased contacting Alesis or Rmidi.
I quote from Alesis Rmidi page:
"A rMidi Import/Export File named 'Sr16PresetKits.xml' containing the Sr16 Preset Kits has been installed within the folder named 'Sr16' within the directory in which you installed the rMidi FrameWork software. You can Import these Kits into the rMidi Drums Control if you wish. "
Check if you have the file in the folder.
If not the Sr16 will allows you to export your User Drum patterns, but I do not think you can export factory patterns.
Nov 20, 2009 | Alesis Sr 16 Stereo Drum Machine
Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Mar 03, 2009 | Boss Micro BR Digital Recorder
RC-50: Importing wav. files from computer to loop station.
Hi I just got a RC 50 and I face the same problem but looking the content of the data in the Roland folder (after you connect the USB) , I notice the format of the label of each sound's and I understood the problem. So , here it is . Before you connect to USB , you have to choose a patch , let say n.16 OK, now the audio file that you want to import into the data folder must be named in this way "016_1.WAV" ,the 16 refer to the patch number and 1 is the phrase number (if you want to put the audio file into the phrase 1 ,or 2 if 2 ecc.) now disconnect the USB .At this point you just have to increase or decrease the patch number just one time and go back to 16 (it has to refresh the patch info) and you'll find your audio file ready to use in whatever phrase you put it.
have fun
Paolo
Jan 19, 2009 | Boss Rc 50
Boss Rc 50 Logo
345 people viewed this question
Top Boss Music Experts
Michial Gueffroy
Darial Jr Lasaria
Darial Jr Lasaria
Vito Vacirca Jr.
Are you a Boss Music Expert? Answer questions, earn points and help others
