Question about HP OfficeJet 6310 All-in-One Printer (Printer/Scanner/Copier/Fax) w/USB Printer Cable , Retail
How do I print a fax report on an HP Officejet 6310 All-In-One?
  • 30 Answers
Visit the following link to obtain the manual for your All-in-One. Hope this helps!
http://www.retrevo.com/support/HP-6310-Multifunction-Printers-manual/id/260dj484/t/2/
Posted on Sep 07, 2009
I recieved a fax a few months back that i cannot find it , does the the hp 6310 all in one have a memmory log so i can access the document again?
You can give it a try, hopefully the printer should be able to print the fax log if it hasn't erased it.
Press Setup Button on printer front panel
Scroll to Print Report - Press OK
Scroll to Fax Log - Press OK
Check the fax that you had received on the date and press ok or it may print the fax log present in the printer.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 19, 2011 | HP Officejet 6310 All-In-One InkJet...
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
I have an HP officejet 6310xi all-in-one,how do i access the fax log ?????
* Press Setup menu (setup button) on the printer.
* Go to the second option print Report.
* Select the 6th option Fax log. Press Ok.
* The fax log will print now.
Verify the result.
:) Dr Tony
Apr 15, 2010 | HP Officejet 6310 All-In-One InkJet...
HP 6310 print problem-prints first 10 lines OK then next 10 are on a new page etc. Re-booting PC fixes problem.
Please check the Page selecton
check the page setup click on file -click on pagesetup
Press Ctrl+P
Check the layout settings
Check print priver if print privew is ok then its software issue
Check the printer drivers
DRIVERS HP Officejet 6310 All-in-One Printer
Jan 05, 2010 | HP OfficeJet 6310 All-in-One Printer...
How do you get a fax confirmation on this machine
please perform the steps below:
1. Press Setup on the front panel of the All-in-One.
2. Press 2 to enter in to Print Report.
3. Press 1 to enter in to Fax Confirmation.
4. Press 1 to turn on Fax confirmation
Jul 08, 2009 | HP Officejet 6310 All-In-One InkJet...
When I attempt to print on 6310, it goes to fax mode
go to control panel >printers andfaxes and see which printer is set as he default printer....it is the fax rgt now.....rgt click on the pirnter icon and change it to the default printer.....should work....
Jun 24, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp officejet 6310 all-in-one send fax configure
5. Press 2 to enter in to Image on Fax Send Report
6. Press 1 to turn on Image on Fax Send Report
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
Running a report
Press "Setup" button, then "2. Print Report", then "6. Fax Log", then Ok.
Dec 11, 2008 | HP Officejet 6310 All-In-One InkJet...
Cannot receive faxes
1-are you sure it is in the correct jack? there are two in the back of the printer
2-when you did the install it should have done a fax line check
Sep 20, 2008 | HP Officejet 6310 All-In-One InkJet...
Open Questions:
See all HP OfficeJet 6310 All-in-One Printer Questions
105 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
