Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega kv-32hs510
The stand by light blinks 6 times but never turns on
    Problem Solver:
  • 17 Answers
Place blow dryer on heat setting to rear of tv and try to turn on set after 5 mins...humidity sensor in board
Posted on Sep 09, 2009
  • joey wassilyn
    joey wassilyn Sep 09, 2009
    humidity sensor in rear of tv, try placing blow dryer for 5 mins to remove humidity
Why does my sony weta model KV-32HS510 stand by indicator blinks 6 times?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 31, 2014 | Sony FD Trinitron WEGA KV-32HS510 32" TV
What is the life span for the Sony Wega KV-32HS510?
10,000 continous woking hours is calculated to most of the CRT based TVs.
It is only calculation, but the life span might be much more that that. I've repaired a Sony TV recently, which was released by Sony Corporation Japan. The model is KV1820, an 18" Trinitron TV, still works perfectly. Just see, it is an '80 model one.
Tv will not turn on. front light will blink 4-6 times
4 blinks is No Vertical and 6 blinks is No Horizontal and that will happen if you have a power supply fault as the vertical is sensed first.
Mar 01, 2011 | Sony FD Trinitron WEGA KV-32HS510 32" TV
I have the same Problem with my sony KV-32HS510
Your set needs two regulator ICs replaced and a capacitor . I recommend taking it to a sony authorized servicer.
Oct 06, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
May 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony kv-32hs510 stand by blinks 6 times not abe to turn on the tv
It an over voltage or over current problem.....Turning the TV on and off or unplugging the TV may allow you to start the TV. Once started the TV may run for days until you turn it off.
The TV will require a new board to correct the problem...
Apr 05, 2009 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
My sony TV wont turn on.
Un plug and let stand for one minute. If it still does blink then use the reset on the remote and press it while pressing the power button on the TV.
Jan 19, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Kv-32hs510 6 blinks
This just happened to me. I was all set to send it out but there's a snowstorm right now. Thank goodness I checked another thread on Sony.com. Hold the setup button on the original remote while pushing the ON/OFF button on the TV at the same time. This worked for me. Here's the link I got this from: Good luck! http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=http--esupportsonycom-perl-tutorial-displaypltutid297templateid1regionid1KSMFlag7370&sliceId=&docTypeID=DT_TUTORIALS_1_1&dialogID=53101564&stateId=0%200%2053105132
Nov 04, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
426 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
