Question about Gateway Computers & Internet
I'm trying to install Windows Vista on a new hard drive. While installing, an error comes up (0x800706F8) and I cannot complete installation of Vista. I'm on a Gateway MT6711 which is equipped with a HL-DT-ST DVDram GSA-T20n DVD drive. Any suggestions on how I can install windows on this new hard drive? Thanks!
  • 497 Answers
This problem may occur if the DVD drive's firmware is either out of date or defective.
Check the link given below for detail information:
http://support.microsoft.com/kb/930984
To resolve this issue, obtain the appropriate firmware update for the computer's DVD drive.
Good Luck!!!!!!!!!!!!!!!!!!!!
Posted on Sep 07, 2009
Samsung r530 laptop hard disk warning
Error message when you try to install Windows Vista on computer that has...
This problem occurs because Windows Vista cannot distinguish between ambiguous hard disks.
In versions of Microsoft Windows Setup that are earlier than Windows Vista Setup, hard disks are marked with distinct values to distinguish them. However, this method of distinguishing hard disks is no longer supported because of the potential for data corruption on hard disks.
Do you have more than one hard drive connected to your computer?
If you have two hard drives, remove the second hard drive and continue with the installation.
If that does not work, try to format the C: drive while installing the Vista operating system.
You need to select the "format" option from "advanced" within Vista installation.
Click on the link below for more information.
Error message when you try to install Windows Vista on a computer that has uninitialized hard disks: "This computer's hardware may not support booting to this disk"
http://support.microsoft.com/kb/925481
Dec 02, 2014 | Samsung R530 Notebook
Tip
How to Install Window XP with Vista
If you wish to install Windows XP on a computer that comes with Windows Vista already installed then you will have to create a separate partition on your hard drive to install Windows XP onto. This effectively splits the hard drive into two, and keeps the different versions of Windows separate. To do this you need to open up the Computer Management screen by going to the Start menu and then right-clicking on Computer and selecting Manage.
From the Computer Management screen select Disk Management, right-click on your main hard disk where Windows Vista is installed and then select Shrink Volume. This opens up a window where you can choose how large you want the new drive partition for Windows XP to be. You need to select the size of the new partition carefully, as you will need enough space to be able to install Windows XP successfully (around 10 gigabytes) whilst leaving enough space for Windows Vista. After you have selected the appropriate amount of space click on the Shrink button to begin the process, and once that has completed you should be able to right-click on the new partition (which should be labelled “Unallocated free space”) and select New Simple Volume.
Follow the on-screen instructions to configure the partition, set a drive letter (such as E:\), give it a meaningful name such as “XP”, and then restart your computer. Whilst your computer reboots, access the BIOS and change to boot sequence to boot from your CD/DVD Drive before any other device, insert your Windows XP installation disc and then save and exit from BIOS. You will then be taken to the Windows XP installation program where you should follow the instructions until you come to the screen asking you which partition to install Windows XP to.
Make sure you select the new partition and not the one with Windows Vista installed, as this will cause problems. Once Windows XP has finished installing, you will notice that Windows XP loads up automatically, rather than giving you the choice of which operating system to use. To rectify this insert your Windows Vista installation disc and restart the computer to access the Windows Vista installation program. From the Install Now screen select Repair My Computer, and then select your Windows Vista installation and then Startup Repair. You will now be able to choose which operating system to use when your computer starts up.
on Dec 07, 2009 | Computers & Internet
On windows install winsetup.dll error
Even with a complete fdisk, thorough format, and chkdsk /f/r ? If so, there is a bad sector(s). Don't think they are repairable.
Nov 29, 2012 | Computers & Internet
02-07 Fail HP Pavilion dv9000 Installed a brand new hard drive, Same error.
get all your information you need off of the HD and reinstall windows see if that will get rid of the problem.
Dec 13, 2011 | Computers & Internet
I installed system mechanic professional and hit the drive scrubber button and wiped out my hard drive completely. i tried to install widows vista and i it won't allow it to install. i get a file error...
In that case it affects the file system of your hard drive that's why it fails the windows vista installation. In order to fix it you need to delete the partition of your hard drive and create a new one using a partition manager software.
If you can connect your hard drive into another computer you can perform a disk partition using the Disk Management (In Windows XP: Control Panel > Administrative Tools > Computer Management > Storage > Disk Management)
To help you with the procedure on "How to use Disk Management."
http://support.microsoft.com/kb/309000
Using Disk Management, after creating a partition in your drive, proceed to formatting.
Feb 04, 2010 | Compaq Presario 5000 PC Desktop
Hard drive not seen in dell latitude d600 after upgrade to vista
Your hard drive may need reseating.
If it still gives error hard disk not found then you have a faulty hard drive.
You need a new hard drive and then install Windows Vista
Mar 23, 2009 | Dell Lattitude D600 Notebook
Installation
The hard drive will automatically install you do not need to install a driver. I'm guessing this is a hard drive in addition to the hard drive that vista is running on? If so you probably need to format the hard drive to gain access to it. Click the windows button, and in the search field type compmgmt.msc and hit enter. Click continue when the UAC pops up. Now inside the Computer Management Console find and click on Storage and then Disk Management. On the bottom portion look for your new hard drive. Most likely it will have a black colored stripe and say UNALLOCATED. This will explain how to do the rest Yes that article is for XP but the one in Vista is pretty much the same.
May 16, 2008 | Western Digital Caviar SE16 (WD5000KS)...
External hard disk installation
plz check your usb port if other device read ...........then your external hard disk so error. or if ex hard ok...you install windows vista .
Jan 19, 2008 | Computers & Internet
Computers & Internet Logo
90 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
