By this do you mean you want to increase the RAM on your computer?
I suggest you use PC2100 DDR RAM (same speed) and increase the total RAM to what your require but use the same RAM manufacturer if possible.
If you want to install more than 2Gb of RAM, check the motherboard specification for the maximum RAM that the motherboard can support.
Your motherboards may support more RAM with a BIOS upgrade.
no it wont here are the list that HD ram will work: The following list comprises
most of the motherboards stated to work with non-ECC High Density
PC3200 memory. Though bear in mind that whether your particular board
works with High Density RAM, and if it does, whether it will work with
all slots filled with High Density RAM will always be something of a
punt:
INTEL
915; NVIDIA NFORCE3 250GB; NVIDIA NFORCE4 SLI; SIS 645; SIS 648; SIS
648FX; SIS 650; SIS 650GX; SIS 655; SIS 661FX; SIS 746FX; ULI CHIPSETS;
VIA K8T800; VIA KM333; VIA KM400; VIA KT266; VIA KT333; VIA KT333A; VIA
KT400; VIA KT400A; VIA KT600; VIA KT880; VIA P4X266A; VIA PM800; VIA
PT800; VIA PT880.
The following additional boards might possibly work with some High Density modules - but equally they might not:
SIS
649; SIS 651; SIS 656; SIS 661; SIS 748; SIS 750; SIS 755; SIS 756; VIA
APOLLO P4X400; VIA K8M800; VIA K8M890; VIA K8N800; VIA K8N890; VIA
K8T890; VIA K8T900; VIA P4M800 PRO; VIA P4M890; VIA P4M900; VIA PN800;
VIA PT800; VIA PT890.
As
a rule of thumb it seems safest to assume that no Asus or Intel boards
(with the exception of the 915) will work with High Density RAM.
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS...
(More)
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS your views on these boards as to building your own computer etc?
when i start my computer, first screen shows my graphics card details, then logo and then there is...
(More)
when i start my computer, first screen shows my graphics card details, then logo and then there is screen with memory testing, detecting drives etc. (the screen that we enter bios from), and this screen takes forever to load, good 10 minutes, it writes every single letter one by one. the windows starts ok, no problems there, also all my games and programs run smoothly, only this one screen. what could be a problem and how can i solve it?
hi i have hp d530 cmt DC755AV motherboard. i am facing problem with the audio. i want to know that...
(More)
hi i have hp d530 cmt DC755AV motherboard. i am facing problem with the audio. i want to know that is it necessary to connect the "speaker" leads of the casing with the motherboard for speakers to work. Actually the casing "speaker" leads are four pin but on motherboard space is for two pins only. what should i do for audio to work.
