Question about Samsung SyncMaster 912N 19" Flat Panel LCD Monitor
The magicbright screen appears in the left lower corner of the monitor, the checkmarks cycle rapidly through the 4 settings, and the brightness changes rapidly. This started a few weeks ago and is intermittent. What do I do?
  • sstefan Sep 07, 2009
    Helpful. yes. I will try the suggestions. If no luck or a major problem, new computer. SGS
  • Hilda Andrews
    Hilda Andrews Dec 22, 2013
    disable magic brite from my computer asap
    President:
  • Samsung Master
  • 2,923 Answers
The magic bright screen should show up once the magic bright button is pressed on the control panel. The magic bright button (is a sensor) is very sensitive. Make sure that there are no objects hitting any buttons on the control panel.
The control panel uses a sensor behind the smooth plastic bezel to register when your finger touches a 'button'. Clean the buttons or the sensors using a soft brush.
Try to power cycle the SyncMaster. Disconnect it from the outlet and from the computer. Leave it disconnected for about 30 minutes then turn it back on.
If you get the same problem, then there's a problem with the sensor and needs to be serviced. If the SyncMaster is still under the warranty period, contact the manufacturer for repair.
Hope this helps and have a great day!
Posted on Sep 07, 2009
    Brigadier General:
  • 8,619 Answers
Hi
This issue happens when the inverter in the monitor is broken; it occurs mostly due to filter caps gone bad (capacitors with a bulging on top). It can be that one of the backlights in the monitor is broken. This would result in parts/half the screen being much dimmer than the others/half. LCD Monitors wear in light intensity over time, but when it happened suddenly and is very noticeable, it's probably the inverter that has gone bad. If you have warranty then you can use that and get this fixed. If not, then a complete inverter replacement can be quite expensive and it’s good to buy a new monitor. But if it's due to faulty caps, it's an easy and quick fix for any electro technician, replacement caps are just a couple of bucks. You can contact a authorized local repair shop as it might be a cheap fix.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Empowering Technology screen keeps popping up...can't get rid of it
Go to start,type in Msconfig and press Enter.You will see a box with a section labelled Startup.Click on that and look for Empowering Technologies in the list.Any with that description,remove the checkmark and the go to lower right corner of the box and click apply then ok,then restart your computer.That should fix your problem..good luck :)
Sep 01, 2014 | Acer T232HL 23" LED LCD Touchscreen...
Tip
How to disable/enable email scanning in Trend Micro AntiVirus plus AntiSpyware
1.Open the Trend Micro AntiVirus plus AntiSpyware main console by doing any of the following:
Click Start > Programs or All Programs > Trend Micro AntiVirus plus AntiSpyware > Trend Micro AntiVirus plus AntiSpyware.
Double-click the Trend Micro AntiVirus plus AntiSpyware icon on the lower right corner of your screen.
2.On the left panel, click Virus & Spyware Controls. Under Protection Against Viruses & Spywaresection, click Settings.
3.Under Check for the following threats section, put a checkmark in the checkboxes for Threats in incoming mail and Threats in outgoing mail to enable mail scanning. To disable it, remove the checkmarks.
4.Click OK to save your settings.
5.Close the Trend Micro AntiVirus plus AntiSpyware main console.
on Mar 07, 2010 | Trend Micro Antivirus + Antispyware 2009...
Tip
How to disable/enable email scanning in Trend Micro internet security
1.Open the Trend Micro Internet Security main console by doing any of the following:
Click Start > Programs or All Programs > Trend Micro Internet Security > Trend Micro Internet Security.
OR Double-click the Trend Micro Internet Security icon on the lower right corner of your screen.
5.Close the Trend Micro Internet Security main console.
on Mar 07, 2010 | Trend Micro Internet Security Pro 2009 for...
Won't stop cycling through brightness settings
sounds like it might need a cleaning. are the buttons hard to push or are any of them giving you a different feeling then the rest?
Aug 13, 2017 | Samsung SyncMaster 2233SW Monitor
Ipod touch 2g very dim
Follow these instructions to brighten the screen.
1...Turn on I Pod
2...Slide to unlock
3...Touch "Settings"
4. ..Touch "Brightness"
5...Move the "Slider Bar button" to the Right to Brighten the Screen, Left to lower the Brightness, once you have the desired brightness on the screen you will then touch the "Settings" tag at the left corner of the Ipod to take you back to the "Settings" screen.
6.Push the button on the screen at the bottom of the player to return to the Main Screen and you are finished.
Please rate me for this Free Answer.
Dec 19, 2010 | Apple iPod touch
How can I lower the brightness of my screen in my Dell 1525 lapto
Sometimes the brightness is on the arrow keys hit the Fn or function key and press down on the arrow to dim the light or press up on the arrow key to increase brightness
Jul 28, 2009 | Dell Inspiron 1525 Laptop
How to use buttons on front of Monitor for vertical Horizontal settings
Oldie, The first thing to do is set the monitor resolution, color depth and monitor refresh rate to what you want then adjust the monitor accordingly. Adjust resolution, color depth and refresh rate for Windows 2000/XP: -Right click any clear spot on your desktop and select properties from the menu that appears. -From the Display Properties box that appears click on the Settings tab. -In the screen resolution section (lower left corner) experiment with the resolutions and see what you like. -The color quality box should be set to the highest (most colors) color setting listed. -Click on the advanced button in the lower right corner. -In the next window click on the monitor tab. -Typically you would want to set it at 70 Hertz or better. The higher the setting the less flicker you will notice, however, there is always a trade off. I would start with 70 Hertz and gradually move up; at some point your monitor will reach a setting it can?t support. If the screen blanks out Windows will reset back to the previous settings as long as you don?t hit any keys. -click the OK button twice. More to follow?.
Mar 14, 2007 | ViewSonic E790 Monitor
Samsung SyncMaster 193V magicbright
hold the menu button down until the menu disapears again
Mar 11, 2007 | Samsung SyncMaster 193V 19" Flat Panel LCD...
Monitor Screen Bright with horizontal white lines
I have an emachine 17" Flat Panel Monitor and I accidently touched the Standby Mode on my keyboard and now my menu won't work right. I can't adjust the color enough. If there is anything I can do to fix my problem it would be appreciated.
Thanks
Oct 08, 2006 | E-Machines 17F2 17" CRT Monitor
Samsung SyncMaster 912N 19" Flat Panel LCD Monitor Logo
888 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
