Question about Texas Instruments TI-83 Plus Calculator
Error invalid dim
When typing in anything under the y= then I push the graph button it says "error invalid dim"
  • Texas Instru... Master
  • 7,993 Answers
Reset memory to default, the error will disappear.
[2nd][MEM][7][2][2] Defaults set.
Hope it helps
Posted on Sep 08, 2009
I can't graph anything
INVALID DIM error message may occur if you are trying to graph
a function that does not involve the stat plot features. The error can be
corrected by turning off the stat plots. To turn the stat plots off, press
2nd, stat plot , and then select 4:PlotsOff.
Mar 23, 2012 | Texas Instruments TI-84 Plus Calculator
Error message invalid dimensions
y , and then select 4:PlotsOff.
Jan 19, 2012 | Texas Instruments TI-84 Plus Silver...
Getting ERR: INVALID DIM when pressing the Graph button
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.If the message appears in another context, it sure would help knowing the context of the error.
May 12, 2010 | Texas Instruments TI-84 Plus Calculator
When trying to graph anything, ERR: INVALID DIM appears..
The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-84 Plus Silver...
I get the error message ERR: INVALID DIM with
If you are in the stat mode and entering points in list 1 and list 2, it could be that one list is longer than the other.
If you are just trying to graph from the y= screen, one of your plots is probably turned on. The easiest way to fix this is to press the 2nd button the the plus button, then 7 and then 1 and then 2. This will reset to factory settings.
Jul 24, 2009 | Texas Instruments TI-83 Plus Calculator
My ccalculator won't graph anything. I get the error messge Inval
Press the 2nd button, then the plus button, then 7, then 1 and then 2. This will reset your calculator to factory settings
Jul 23, 2009 | Texas Instruments TI-84 Plus Calculator
My calculator will not graph anything. I am getting the error message. Invalid Dim. What dod I do?
Press the 2nd button, the the plus button and then 7, then 1 and finally 2. This will reset your calculator
Graph and trace buttons don't work
This is probably because you have the stat plot on. You would need to go to y= and then go to the top where it says stat plot 1 and un highlight it if it is highligted. That should fix your problem.
Sep 16, 2008 | Texas Instruments TI-84 Plus Silver...
Error: Invalid Dim
this happened to me as well. i looked it up and heres what i found:
http://www.prenhall.com/divisions/esm/app/graphing/ti83/faq/faq.html
basically you have a stat plot on so to turn it off, press 2nd and then the Y= button to get to "Stat Plot"
one of them is turned on so press enter and select OFF. this should fix the problem!
Sep 18, 2007 | Texas Instruments TI-83 Plus Calculator
Invalid DIM
Just passing by, make sure you aren't zoomed in or panned away from the axis when you look. Check to see if there is some way you could be referencing a matrix. I can pull up a similar error by trying to pull a value out of a non-existant slot. I got my first TI 2 days ago, so I probably don't know as much as you.
Aug 20, 2007 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
536 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
