Question about Coleman Heating & Cooling
Coleman air condition compressor will not come on
Have a 1993 wilderness travel trailer with a coleman a/c unit. The compressor will not kick on. Checked out thermostat. Did not have 12volts on legs to thermostat with just the fan running, but could make it kick on by touching both legs at the same time and getting twelve volts at the control board in the ceiling. If the overload switch on the compressor is bad, would the compressor still work by doing this? Or would this just be a bad thermostat.
  • dchuffman Sep 07, 2009
    I did not jumper the leads at the t-stat. I jumpered the leads on the circuit board. The instructions for
    testing were with the FAN ONLY position you should read 12vdc between terminals GH and B at the Low Voltage Terminal strip. I Only had 7 volts so I jumpered the terminals GH and B and got 12 volts
    and the compressor kicked on. I am just trying to figure out if a new t-stat will fix the problem or if the overload switch was blown.
    i went back and tried to jumper at the t-stat, but the compressor would not come on. but if i go back
    to the control panel and jumper pass the relay the compressor comes on. does this verify it is the control board and/or the t-stat.
    Top Expert:
  • Coleman Master
  • 76,102 Answers
If the thermal limiter was blown the compressor would not run, if you jumper the compressor leads at the T-stat does the compressor run? if so the thermostat is the problem, but it is more likely the problem lies in the control board at the compressor itself, but try the T-stat 1st and keep your fingers crossed that is the problem.
Posted on Sep 07, 2009
  • yadayada
    yadayada Sep 07, 2009
    if u can't jumper the wires at the thermostat and make the compressor run then the board is defective.
  • yadayada
    the control board is defective.
I have a 2010 30' cougar travel trailer, we have never used the air conditioner which is a coleman mach model, when I put it on auto and cool it blows cool air but never gets cold am I suposed to
Check the temperature of the air coming out the vent If it's more than 10 degrees below the air going in it's ok. If it's the same temperature, the condensing system may be not working. The compressor may just be a quiet one!
May 18, 2012 | Coleman Mach III Air Conditioner
DOES MY COLEMAN ROOTOP HAVE FILTER ON THE OUTSIDE (ROOFTOP)
You dont have a filter on top unit but you need to have your fan impeller and condensing coil clean regularly about once a year and more when your on dusty area.
Aug 21, 2009 | Dometic Rooftop RV Air Conditioner
Compressor will not start but the fan runs on RV air condition unit Mod 7332B896 Coleman
If you can hear compressor try to start, then kick out, then I'd say capacitor needs replace, but if you don't hear anything (moan or groan) from compressor, then I'd be looking at a new relay, or at least testing it.
Jul 30, 2009 | Dometic Rooftop RV Air Conditioner
I have a Coleman 6770 A Series roof air on my trailer. It won't blow cool air. Is this a compressor problem? And if so, would it just be cheaper to replace the whole unit than to try and repair this one?
Before the compressor is condemned, is it running at all? Is it getting the proper voltage? If the compressor will run and still does not cool the system could be low on refrigerant.
A replacement compressor is normally more economical than replacing the entire unit. It could be something as simple as a open thermostatic control.
Jul 03, 2008 | Coleman Heating & Cooling
Coleman airconditioner
Try testing the capacitor (there may be 2 ) If the start windings can't kick out it will blow the breaker.
Jun 23, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach 3 Rv air conditioning
Dirty coils might be your problem. You might have a refrigerant problem as well. Try cleaning it first then have a tech put gages on it. Doesn't sound too serious
Jun 12, 2008 | Heating & Cooling
COLEMAN TSR MACH 3 COMPRESSOR
I would check the thermostat based on what you said it could be out of calibration
Jun 11, 2008 | Coleman Mach 15 Air Conditioner
Coleman tsr mach 3 RV Air Conditioner
I don't think you need a new one just a good cleaning and service. The unit has a liquid high temperature line near the compressor with a fan blowing outside air across it this coil gets clogged over time with air-borne dirt and pollen and leaves and such and must be cleaned regularly or the unit will be unable to remove the heat from the coil and during the peak demand (3pm) the circuits that protect the compressor and the trailer wiring from being overloaded and burning or melting will trip. From what you have described it sounds like the RV is working as it should with a condenser coil that needs to be cleaned. GL and happy camping!
P.S. I've only serviced the occasional RV unit but in those cases I laid a piece of plywood on top of the Rv for work platform removed the retaining screws from the top cover and used a spray bottle with a good heavy foaming cleaner a shop-vac and a brush to get the job done.
Jun 11, 2008 | Heating & Cooling
Roof top motor home coleman air conditioning unit
What is outside (ambient) temperature. When was entire unit last cleaned? (evaporator coils, & condensor coils)
Jun 04, 2008 | Coleman Mach III Air Conditioner
Heating & Cooling Logo
70 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
