Question about Philips Magnavox 51MP392H Rear Projection Television
Picture not as sharp as it used to be - Philips Magnavox 51MP392H Rear Projection Television
  • Philips Master
  • 8,617 Answers
Replace the coolant in the CRts very common problem with Phillips / Magnavox Tvs.
Posted on Sep 07, 2009
Color is grate on my Sharp 26" TV. However night scenes have become almost too dark to see. I have tried to adjust the settings but no improvement. Is this a fixable problem? Using Comcast Cable a
Check 'brightness' and 'contrast' settings in (usually) 'picture' menu. Use a recording (DVD etc.) of a dark scene to adjust the picture. My TV (not Sharp) has several pre-programmed picture settings. If yours has that, maybe one of them will be good. Otherwise, use manual settings.
Oct 18, 2014 | Sharp Televison & Video
Sharp blu ray Make the picture zoom
Download the manual to your player, and refer it for details. To download it, click here.
Jun 01, 2012 | Sharp BD-HP21U Blu-Ray Player
Sharp AQUOS 65" LCD, No Picture Menu Access
change picture mode from (STANDARD)or other modes and put tv in CUSTOM then you will be able to change the contrast
make sure all cables are in
Dec 15, 2009 | Sharp Aquos LC65E77UM 65 in. LCD HDTV
Sharp model lc19sb25u sound and no picture screen
Part called main unit failed and require replacement. part number duntke352fm02.
Oct 08, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
No picture from cable box to tv
If you get on screen menues using the Sharp Remote then you have a main board that is defective. If you just bought it new you are in luck as the warrenty on that unit is a lease 1 year parts and 1 year labor. Contact Sharp Customer Service and should be able to refur a Sharp Auth. Repair facility to get you taken care of. In the mean time, If you got on screen menues then you can go to any one of the other video inputs and see if you get a picture.
If you DO NOT get onscreen menues with the Sharp remote then you are out of luck until a service repair facility looks at it.
Hope this helps,
Skyassoc
Jun 19, 2009 | Sharp Aquos LC-32D40U Television
AR-M350N Sharp Copier
Yes, it is possible. You need to use the software for your Sharp copier to scan the colored picture. Once you have scan it, you may use or send it to any email address.
Oct 21, 2008 | Sharp AR-M350N Copier
Picture not HD quality while watching HD channels
Make sure you are using an HDMI video cable for optimal picture quality. Also, you must be using an HD reciever.
Jun 12, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Picture adjustment questions
*The brightness control setting determines how bright your picture will be. *The contrast control sets the gain of the video circuit. This determines the difference between dark and light scenes. Low contrast settings make the picture "hazy". High contrast settings make the picture more distinction between dark and light scenes. *The sharpness control determine the frequency response of the video circiut. High sharpness settings give better resolution but also shows more noise in your picture. Lower sharpness settings smoothe out the picture removing noise but also fine detail. It needs to be set for the best all around picture. *Picture Enhancement is pre-set adjustments which give you different picture qualities. You just select the one you like. Stargazer
Mar 03, 2007 | Zenith B25A02Z TV
Philips Magnavox 51MP392H Rear Projection Television Logo
75 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
