Question about Kenmore Dryers
Dryer doens't heat - Kenmore Dryers
  • 304 Answers
Model Number is always helpful
Unplug unit and turn off gas if gas model. Check to be sure you have 240 Volts at wall outlet.
Most parts likely to fail on electric dryers are inside the rear cover. Heater is on right inside can, safety thermostat on lower left of can, High limit thermostat (non-resettable) higher left of can. On the blower housing to the left are the operating thermostat and, in some models, a thermal fuse (white plastic). ALL can be continuity checked easily. Always disconnect wire on one side of what you are testing. One will likely be open. Replace the component that fails the continuity test.
The thermal fuse or high limit thermostat failure generally points to a reduction of air flow due to SOME blockage either inside the dryer or in the vent pipe leading out of the house. If you find either of these parts bad be sure to check the vents after replacing parts to ensure the same parts won't fail again.Heater replacement sometimes requires lifting of top. Under the lint filter cover there are two screws. Remove them WITHOUT dropping them into the vent or you may cause a more serious problem. Insert a putty knife between the front and top about 2 inches in on both sides. This will release the top for raising.
Posted on Sep 07, 2009
My electric dryer won't dry clothes. Doesn't get hot, what's wrong with it?
how is the lint filter maybe it is too full of lint and the dryer will not heat up to protect you from burning doen your house when the lint filter gets too hot and catches fire. Just a thought
Oct 28, 2014 | Dryers
Have a whirlpool dryer, le9380xtwo, it gets hot and shuts doen, i checked the system and the system throstate, opens up, when it cools down it makes contact again, i think it is the cycling themostate to...
The cycling thermostat is supposed to shut down when it reaches a certain temperature, cool down and then make contact again when it cools down and starts the process all over again. What exactly is wrong with the dryer?
May 30, 2012 | Whirlpool Dryers
Hello I have a MAYTAG NEPTUNE DRYER Model# MD5500 (MDE5500AYQ) . The console panel lights up.You can load up a cycle on the display but the unit won't start. It Just beeps or locks up.So I checked the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 30, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I installed a new belt and rollers on my dryer. Closed up the machine and loaded the dryer with clothes. The dry is not spinning but when I removed some clothes and left only a very small load it now...
I would make sure the rollers did not come off, I would as make sure it was the correct belt. If all that checks out there is a diagram on the side which shows how the belt is ran. I hope this helps Tim
Aug 03, 2010 | Dryers
The oven burner element doen not ignite. The
more then likely you have a bad ignitor( although its glowing, its not powerfull enough to ignite the gas. bery common issue with all gas ranges. easy enough repair, depending on model the ignitor is only held on by perhaps 2 screws anda coulple of wire nuts, parts problably 50-90 dollars
Jan 27, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Dryer power problems
Yes, all dryers have a belt that turns the drum. Chances are the belt and heat problems are 2 separate issues.. The belt turns the drum from a motor mounted inside the unit, your electric dryer has a heater element/coils that heats the drum your clothes are in. The belt could be bad and heat element also but both at exactly the same time is rare. Try unplugging the unit for about 5minutes and see if it resets. My washer does that sometimes and I have to unplug
Aug 07, 2009 | Whirlpool WED6400S Electric Dryer
WHIRLPOOL DRYER 5-6 YRS OLD
Navy 2nd Class Diver 1969-73
The Ignitor is fine? So, it heats on some settings and not others?
The OHM Meter test for continuity.
Some parts give a reading of a certain amount of OHM's but, most the time all you need to know is if you get any reading on the meter at all. This shows there is no break inside the part. You can check the ignitor this way also the solenoids on the gas valve.
If the ignitor glows red then shuts off and does not ignite the gas, this could be the sensor or the solenoids. The sensor located close to the ignitor, will detect the glow from the ignitor and send power to the solenoids on the gas valve.
Jan 26, 2009 | Dryers
Dryer Timer
Order a new one from any number of suppliers such as http://www.mcmelectronics.com/ they carry a full compliment of replacement parts. You will need to provide them with the brand, model number etc.. Hope that helps... ( I've doen the same thing myself and it was easier just to replace it than to try to reassemble it correctly)... Enjoy !
Aug 18, 2008 | Whirlpool LER5636P Electric Dryer
Once the dryer has started the drying process the gas comes on like it suppose , then after reaching tempture it shut doen not to come back on the glow plug come on but it will not light, so the dryer can...
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
