Question about Dryers
My whirpool le688 had a clogged vent, it got hot and now there is no power
  • 89 Answers
Remove the back from the dryer at the bottom near the blower housing you will see a small white fuse you will need to replace it make sure you clean the vent good then check and make sure you have good air flow
Posted on Sep 06, 2009
Water pooling and freezing in lower freezer, whirpool gold french door? How do I rmove liner in fridge to follow line?
Sounds like a clogged drain. Remove food, remove bins and shelves. Remove ice maker if freezer is in the bottom. Remove back panel. .melt ice on drain pan and run hot water into drain.
Feb 14, 2015 | Whirpool Refrigerators
Dryer gets really hot but clothes are still wet
Sounds like the vent is plugged up, that's a fire hazard take it apart and clean it out..
Apr 05, 2014 | Whirlpool Whirpool 3.5cu ft Top Load...
My whirpool is not getting hot enough to dry the clothers
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum. Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Feb 13, 2011 | Whirlpool Dryers
My Whirpool dryer stopped working after I just finished a load and tried to start the next one. The power source is working and the vent is not clogged. Where do I locate the belt?
If it's not working at all, the first thing to check is power. You should have a dipole 30 amp breaker and you have to make sure that both legs are hot going to the machine. Remember that it's possible for the breaker to appear to be okay but one leg has tripped. Inside the unit you need to be able to check for continuity on the thermal fuse(s) and across the heating element. The door switch could have failed as well, which would not allow it to tumble or heat.
Dec 02, 2010 | Whirlpool Dryers
Electric Whirpool Dryer doesn't stay hot
Check the vent for obstructions if all is clear do an ohm reading on your heating element. For video instructions go to www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | Whirlpool Dryers
My whirpool dryer is overheating what is causing the problem
Is that a Gas or Electric dryer? Kindly mention the Make and Model so that i could assist you in a better way.
Thanks!!
Oct 13, 2009 | Whirlpool Dryers
My whirpool dryer won't power on.
First check your power. The most common cause of this is the white plastic thermal fuse, located on the exit chute. These blow whenever air flow (plugged or restricted venting) is improper, or if the unit is running too hot. They also wear out from age. Hope this helps!
Jan 01, 2009 | Whirlpool Dryers
Tumble dryer not giving heat
is the drum turning?if the drum is ok sounds like the thermo fuse on the heater box failed,most of the time it's from a clogged dryer vent hose or wall vent,let me know what you find-mike
Nov 13, 2008 | Dryers
Whirpool Dryer......
GAS or Elect. does not make a diffrence 95% of drying too long problems are from a clogged vent try to run a normal load with the vent off the the back letting the hot air into the house if it drys normal then you need to clean out the venting going to the outside If you are worried about the lint blowing inside you can put an old pantiehose over the vent to catch the lint dust
Jan 21, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
43 people viewed this question
Top Dryers Experts
