Question about T-Mobile Wing™ Smartphone
Faceplate keypad I Dropped my Tmobile wing and the keypad snapped out those on the right side of the face plate , Tried to fix them back but didnt work , How Can I find a guide to open the whole faceplate and fix them there? Thank you .
  • Anonymous Mar 30, 2014
    a lot of dirt under face plate touch screen won't work with stylus or finger
    New Friend:
  • 51 Answers
I would recommend for you to bring it to the t-mobile store before any more damaged. Good luck to you..
Posted on Jan 21, 2008
ReMove faceplate
Remove the Outer Case Panel on the side by removing the screws on the back that holds it. Now once one side of the case is removed, look down the front on the metal part of the case. You will probably see the plastic catches or hinges from the face plate, push them in to release them and you can remove the face plate.
Apr 11, 2012 | E-Machines D2046 PC Desktop
Buttons on my sony CDX-GT540UI stopped working
Sony car radio cdxgt540ui buttons non responsive - remove four screws on reverse side of faceplate, pry open with fingernails starting at the top right or left corner of the face plate once opened remove board on the reverse side of the LCD there are small brackets holding the LCD use a needle nose to pry each bracket in straight position then remove LCD for ten seconds then place back on to board and been brackets back in place. After these steps the front buttons should work again this process worked for me.
Mar 16, 2012 | Car Audio & Video
When I load papers into the document feeder on top of my HP Officejet 7210 All-in-One printer to scan these documents, the PDF file (scan results) have a multi-color series of lines from top-to-bottom on...
  1. Remove all originals from the document feeder tray.
    NOTE: It might be easier to work with the automatic document feeder if the document feeder tray is removed first.
  2. Lift the cover of the automatic document feeder. Figure 1: Lifting the ADF coverc00222493.gif
  3. Lift the lid on the HP all-in-one, and locate the notch near the top right edge of the lid backing. Figure 2: Locating the notch near the lid backingc00222494.gif 1 - Notch 2 - Lid backing
  4. Place one or two fingers in the notch, as you lower the lid of the HP all-in-one. Keep your fingers in the notch until the lid is almost closed. Figure 3: Inserting fingers into the notchc00222495.gif
  5. Push against the top of the face plate with your thumb as you pull the bottom away from the right side of the HP all-in-one with your fingers. Use a slight twisting motion to help release the face plate on the right side.
    CAUTION: Do not pull the face plate all the way off yet. There is a plastic catch on the far left inside of the face plate that helps secure the face plate in place. If the face plate is pulled straight off, the plastic catch on the inside of the face plate might be damaged. Figure 4: Releasing the face plate from the right side of the HP all-in-onec00222496.gif 1 - Releasing the right side with a slight twisting motion
  6. Slide the face plate to the left until the plastic catch on the left side is not touching any part of the HP all-in-one, then pull the face plate away from the device. Figure 5: Removing the face plate from the HP all-in-onec00222497.gif 1 - Sliding the face plate to the left 2 - Pulling the face plate away from the HP all-in-one
Cleaning the rollers or separator pad Follow the steps below to clean the rollers or separator pad.
  1. Once the face plate of the ADF is removed, use the blue-green handle to lift the pick assembly. Figure 6: Blue/green handle and the pick assemblyc00222498.gif 1 - Blue-green handle 2 - Pick assembly This allows access to the rollers and the separator pad. Figure 7: The rollers and the separator padc00222499.gif 1 - Rollers 2 - Separator pad
  2. Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
  3. Use the damp cloth to wipe any residue off of the rollers or the separator pad.
  4. If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
  5. Use the blue-green handle to lower the pick assembly.
Reattaching the face plate of the ADF Follow the steps below to reattach the face plate to the front of the automatic document feeder.
  1. Hook the face plate onto the left side of the HP all-in-one so that the plastic catch on the far left inside of the face plate catches on the notch on the front of the automatic document feeder. Figure 8: Hooking the face plate into the left side of the HP all-in-onec00222500.gif 1 - Notch 2 - Plastic catch
  2. Line up the right edge of the face plate with the right side of the HP all-in-one, and then press on the right side of the face plate until it snaps securely into place. Figure 9: Snapping the face plate into the right side of the HP all-in-onec00222501.gif
  3. Place your hands towards the center of the face plate, and press until the center of the face plate snaps into place. You should hear two clicks; one when the left side snaps into place, and one when the right side snaps into place. Figure 10: Finishing re-attaching the face platec00222502.gif
  4. Close the cover of the automatic document feeder.
  5. If you removed the document feeder tray, reattach it.
Dec 07, 2010 | HP Officejet 7210 All-In-One InkJet...
How to change from latch with face plate to drive in latch
How do I mount the Face Plate on the Latch?
Insert the latch into the faceplate opening, ensuring that the sides of the faceplate line up with the flat surface on the latch collar. Push flush with the drive-in collar. Then grasp the faceplate in one hand and the latch in the other hand and rotate the faceplate clockwise to snap in to the collar.
Nov 24, 2010 | Weiser Lock Powerbolt 1000 Lock
Tighten the outside faceplate of a qwikset dead bolt.
The inside face plate snaps on. To remove it remove the T handle and use a small flat head screwdriver to genty pry it off. Behind the cover you will find 2 screws to remove the lock halves.
Don't forget to rate
Mar 12, 2009 | Kwikset Professional Door Lock...
Faceplate
You can't take the faceplate off you have to buy a snap on cover. This makes the phone thicker but if you want a different look that is what you have to do. You can also buy phone stickers and decorate the front and back.
Nov 22, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Ice chute door
THE FACE PLATE OF THE DISPENSER ASSEMBLY SHOULD HAVE A SLOT ON THE BOTTOM CORNERS. INSERT A LARGE BLADED SCREW DRIVER IN THE SLOTS AND TWIST. IT WILL SNAP AND YOU WILL THINK YOU HAVE BROKEN IT BUT IT DIDN'T. ONCE THE BOTTOM IS RELEASED, PICK UP ON THE FACE PLATE TO DISENGAGE IT FROM THE TOP OF THE ASSEMBLY. IF YOUR DOOR FELL OFF, THE CHANCES ARE THAT A PLASTIC LOOP BROKE OFF THAT THE HINGE PIN SLIDES INTO. A FIX KIT HAS BEEN DEVELOPED TO REPAIR THIS PROBLEM. BEST TO BE INSTALLED BY A FACTORY AUTHORIZED SERVICER. IT CAN BE DIFFICULT.
I HAVE INSTALLED TWO OF THEM MYSELF.
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Faceplate DEH-P5500MP
dude im real good at this stuff and if u dropped it once ur lucky it still worked but if it dont work now ur definitely going to need a new one...
Jan 09, 2008 | Pioneer DEH-P5500MP CD Player
Faceplate
Found this on Howard Forums. Sorry no photos.
CHANGING HOUSING/FACEPLATE:
Take off your battery, unscrew the screws on the back of the phone with a T6 screw driver.
Pry off the back plate,lift up circuit board gently(be mindful of flex cable) remove the flex cable from mail board by lifting brown part by the connector,
Unscrew then next 2 set of screws(be careful of flex cable!) remove the LCD board from the faceplate.
Now put the LCD Panel into the new faceplate. Find the new back slide and put your sliding rails on.(you may also put the slide magnets on from the old housing) carefully thread your flex cable through the opening.
Snap the Back slider on and then screw in the screws, then take the keypad housing and screw it into the slide rails.
Reconnect the flex cable by putting the brown hatch up(gently with finger nail) gently feeding the cable into the connector until the white line is about to the end of the connector.
Then put the brown thing down and apply little pressure.
Put the mail circuit board back into the phone with the headset jack going in first.
Then snap it back into place.
Transfer your speaker over the the new back housing with the prongs facing up.
Then screw on the back housing.
Replace battery and your DONE!!!
Best of Luck.
Please RATE my solution BELOW.
Nov 25, 2007 | Kyocera Slider Remix KX5 / Sonic Cellular...
DUAL XD7500 CD PLAYER PROBLEM
This is what the manual says:
With the unit off, press OPEN to allow the front panel to slide
down. Gently squeeze the release tab located on the bottom
center underside and pull faceplate down and away from unit
to remove. To install, insert left side faceplate first, then push
right side to secure.
Tried it and couldn't get it out.
Sep 05, 2007 | Pioneer DEH-P44 CD Player
T-Mobile Wing™ Smartphone Logo
128 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
Edward Talavera
Edward Talavera
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
