Question about Hotpoint Ultima WF860 Front Load Washer
Child lock button is stuck
I have an ultima wf 860 the child lock is on the machine and the button is not working . i cannot switch it off .therefore i cannot use the machine at the moment
  • 89 Answers
Hold the button in for about ten seconds this should unlock the panel
Posted on Sep 06, 2009
Testimonial: "thank you so much ! your advice worked ! with two babies at home i was getting so desperate . thanks again ."
My machine is stuck on rinse hold and child lock
Try unplugging for 5 min and plug back in.
if not working still order new interface stuck button sounds like
someone has been hitting buttons to hard or soapy water spilled on pannel
Mar 08, 2015 | Hotpoint Ultima WT960P Washer Front...
Hi,how can i reset the language on my wmd960 hotpoint ultima,thanks
1. Switch on the power and when the language is displayed - press the child lock+ temperature+ spin buttons simultaneously for about 5 seconds. Release the child lock button when other languages appear. Scroll down using temperature button-until English is dispalyed. Select using child lock button.
Jan 14, 2011 | Hotpoint Ultima WF860 Front Load Washer
Can a HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN washing machine run off a cold fill only
The simple answer is yes, via a Y piece if it is a hot and cold fill model
The fitting is available from B&Q, or a plumbers merchants
Aug 13, 2010 | Hotpoint Ultima WF860 Front Load Washer
Child lock stuck on
1st try pulling the mains plug out for an hr to see if this will reset the main board.. failing that its either a faulty console board or the board has dislodged from panel at rear so when you are pressing the button you are not making contact with the switch itself.. good luck
Mar 20, 2010 | Hotpoint Ultima WF860 Front Load Washer
Wf 860 error code f05 psi switch jammed on full - machine had not emptied water. Is this faulty switch or blocked pump etc?
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
Check for blockage first.
Feb 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
WF 860 Has F05 Wont drain
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Jul 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wf 860
Taken from another post - just happened to me 5 mins agao so not fixed yet!......now showing F-01 (motor triac short circuit).....
F-08 heater relay stuck check pressure switch, heater and module connections poss pressure switch fault
Good luck and let me know if/when it's sorted as may give me an indication of costs etc
Sep 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima 840
hold child lock button down for 2 seconds you will then hear a beep done.
Jun 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wash/dryer wf860
Press "end of cycle" button for over 5 seconds, the child lock comes off. Press it again and the child lock comes on, this works for Hotpoints, you could try, no harm.
If it works, pl rate me.
Nov 28, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
252 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
