Question about Panasonic TH37PX60 37 in. Plasma Television
Removal of tv stand
I am trying to remove the pedestal base from panasonic tv. There were 2 large bolts that appeared to hold it in place but when I removed them nothing happened. Not sure what to do next.
  • 92 Answers
The stand is usually held in by 4 Philips scres on the rear of the TV.
The stand itself has 2 "Arms" that point upwards, about 4 inches, they go up into the base of the TV, screws then go in from the rear of the set, low down, to secure the legs in place.
The stand, swivel mechanism and "arms" all stay together.
Good Luck, I hope it helps.
Posted on Sep 07, 2009
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
How to remove the Base from a Sharp LC 46D64U TV
No.
Stand or base on any model of TV should be removeable without taking the back panel. How to Remove Pedestal Stand from Your TV YouTube
Oct 31, 2016 | Sharp Televison & Video
Remove pedistal base from 24h898 aoc envision tv
You need to remove the cover that hides the 4 screws that hold the stand to the monitor. There are 3 pieces to the pedestal base. The base plate, the pedestal, and the screw cover. To remove the screw cover, look on the back where the pedestal attaches to the monitor. There is a cover just above the pedestal. Pinch the top left and top right sides (about one inch from edge) to unclip the cover. Remove the 4 silver screws (2 on each tab) and put them in a ziploc bag to avoid losing them. Tape them to the pedestal/base and cover.
Jan 18, 2014 | AOC 24 Envision L24H898 1080p Widescreen...
I need to remove the stand from my Toshiba 37HL67 so I can mount it on the wall. Can you help me. Auburn Abenton716@aol.com
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface.
Note:
Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand a way from the TV (Remorve 5, 4mm or 5/32" Allen Bolts from back of TV.)
For Mordels
26HL67
32HL67
32HL67U
37HL67 = My TV
42HL67
Herb
Sep 22, 2011 | Toshiba 37HL67 37 in. LCD HDTV
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Note: Extreme care should always be used when removing
without tools.
3) Remove the four screws shown in the diagram below. This will
4) Once you have removed all four screws holding the pedestal
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
Can't remove the base/feet - i want to mount on the wall. if there are screws, we can't find them - tried allen wrench, phillips, etc., no luck. thank you
See page 5 of the owner manual:
without tools.
http://www.tacp.toshiba.com/tacpassets-images/models/47HL167/docs/47HL167_om_e.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 18, 2010 | Toshiba REGZA 47HL167 TV
How can I remove the the stand so I can mount it on the wall
1)Carefully lay the front of the unit face down on a flat,
2)Remove the jack pack cover on the back of the TV to expose
without tools.
3)Remove the five screws shown in the diagram below. This will
4)Once you have removed all five screws holding the pedestal
5)Now you are ready to install the wall mount brackets
I hope this helps and good luck!
Feb 28, 2010 | Toshiba 32HL67 32 in. LCD Television
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
without tools.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Remove stand on a Sony KV-35V75 television
I have not known of any Sony tube TV thay was attached to the stand in any way with exception of they had a cloth strap in the center in the back at the bottom of the TV that buckled into a pocket on the back of the TV, but nothing in the front, usually the TV just lifted straight up or slid back about 3 inches then lifted up, that is all I remember on that other than the TV is very heavy and maybe it is just stuck from being on the stand for a long time. Good luck!
Dec 27, 2009 | Sony KV-35V75 35" TV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Panasonic TH37PX60 37 in. Plasma Television Logo
1,064 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
