Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Self defrosting not defrosting not cold in bottom of frig has top freezer
  • 4,070 Answers
How to checkeverything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. Inmost newer models the timer has been replaced by an electronic control board.If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicksand everything shuts down. The heater should now come on. If it does, replacethe timer. If it doesn't, check the heater and defrost thermostat. Turn thetimer again till everything starts back up to end the defrost cycle.
Posted on Sep 07, 2009
The freezer keeps defrosting.....starts to cool down then back in defrost mode again. Also the bottom of the fridge is not keeping things cold anymore. Could you please help me on what could be...
the defrosting mode could a problem with the defroster timer. as for the bottom one if the top is not cooling the bottom one wont either. the freezer fan is what also keeps the bottom frig cool. the defrost timer should be on the bottom frig close to the ligth.
Jan 19, 2011 | Whirlpool ET8FTEXM Top Freezer...
Refrigerator is cold in the freezer, but the top of the frig is not cold. Is there are fan to cool the top part of the frig?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 05, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer cold. Refrigerator very warmer.
Hi there. This should be a self defrosting unit. Check the defrost clock. It's usually behind the grill at bottom front of frig. or near the compressor. There is probably a little window on the clock motor where you can see it turn. You can manually advance the clock to put the unit into defrost mode. Check the defrost heating element. This is the usual problem. It is under shrouds where all the frost builds up. If element good, check defrost thermostat connected to element mechanically and in series electrically.
Thanks
Paul
Jul 12, 2009 | Kenmore 61042 Top Freezer Refrigerator
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer works, frig does not. Also ice build up in freezer coil
I just worked on a FF801W which is supposed to be very similar. The defrost heater in mine was of the glass tube type and located under the evaporator. There was a bimetal thermostat clipped to the top of the evaporator and a thermal fuse (sealed in a clear plastic tube) nearby. The connections were behind a little plastic cover (2 screws) in the back wall just above the evaporator.
Mine was iced up like yours and I had to defrost it with a hair dryer. All the defrosting parts in the freezer compartment turned out to work so I now suspect the defrost timer (down by the compressor). I've marked it and I'm waiting to see if it's turning.
Mar 23, 2009 | Avanti FF1101W Top Freezer Refrigerator
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Freezer cold but not frig. section
Switch off frig and let it completely defrost.
Jun 27, 2008 | Maytag MTF2155GRQ Top Freezer Refrigerator
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Duct from freezer to frig is blocked with ice, frig warm
give the unit a full defrost then unblock the drain hole. it sounds like the tiny defrost heater element may not be working and is therefore causing excess frost to build up on the freezer evaporator. also check door seals are not holled anywhere.
May 31, 2007 | Hotpoint HTR15BBMRWW / HTR15BBMRAA /...
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
174 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
