Question about Acer Aspire One A150-1006 Notebook
Flickering screen - Acer (laptop) 1690 series
I'd like to address a problem that started just 2 months ago:
Whenever I connect my laptop to AC power the screen just starts flickering away. It goes from AC mode to battery mode and back,... and then some more. It also seems it's not aware it's connected: I get the little outlet icon next to my clock when it's on AC mode - , but not the kind with the lightning bolt when it's out of power. This way it can take up to several dayst to fully charge the battery. Another problem I'd like to add: the battery depletes abnormally fast (< 25 mins. or so). This happens even when no other programs, aside from the background processes, are running. Even more curious is the fact that the battery manages to recharge in just under 30 mins. or less (???). By this I mean that the little icon mentioned earlier changes from 'outlet with lightning bolt' to 'just plain outlet' So what's wrong with my pc, and how can I fix it? (see specs below)
Aspire 1690 (nearly 4 years since purchasing date) ------------------------------------------------------------------------- 1,7Ghz (Intel Celeron) 1GB Ram Windows XP (Service Pack 2), Home Edition
  • Acer Master
  • 32,281 Answers
You have two problems and they are separate issues.
First your battery is nearly worn out. Rechargeable batteries have a finite number of charge and discharge cycles and as the battery ages the charge capacity will drop. When the battery is worn out, it may not charge at all or show it is 100% charged but when you remove the AC power the laptop will shut off because the battery is dead. A new battery is required to fix this problem.
Second when you connect the AC adapter into the laptop's power socket, and the screen flickers and the charge LED also flicks, it means the power socket is faulty or the power socket has a dry solder joint connection to the motherboard. If you hold the power plug in a particular position you should notice the charge LED will stay on without flickering as well as the LCD screen.
This fault can be repaired, but it requires the laptop to be dismantled completely to access the power socket. I suggest you get a quote first.
Posted on Sep 06, 2009
Acer Aspire Screen Strange unique Flicker
Yup well I am sorry to inform you but your screen is in fail mode this is a typical thing we see all the time...the "Driver IC's" are going flaky. It's the pixels turning red & grey that tips one off....
Feb 18, 2010 | Acer Aspire 6930-6455 Notebook PC
Aspire 1690 - Backlight on screen is failing Rose
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 08, 2009 | Acer AOA150-1690 Aspire Notebook
Wireless connection problem
if you are sure you didn't changed the password on the wifi router and it stopped working itself try restoring the system to the date it was working fine, but little caution all the settings/ programs installed after the restore date will be lost
Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
choose the date ie. bold and on which it was working fine and follow instructions
if you think the info given by me was helpful please do rate me
Further Queries are welcome
Regards
ltoso
Jul 07, 2009 | Acer AOA150-1690 Aspire Notebook
Acer Laptop Screen Flickering
The flickering screen indicates that it is a backlight problem with either a faulty inverter or inverter connection problem. The inverter is usually located at the bottom edge of the LCD screen, and may have one or two connectors (one for the video info. and one for the inverter power or a combined connector) attached to the motherboard under the case near the top edge of the keyboard near the hinges. Reseating these connectors may solve your problem.
Jan 29, 2009 | Computers & Internet
Screen Flickering on Acer 3680-2682
Ok we must remember when we setup any device on our PC, one of the many non PnP devices is and LCD Monitor, your PC should always be shutdown before installing a new Monitor. If you did not do this you could have damaged the I/O port on your PC. Not a definite, but possible! When you plug up a monitor or any serial cable while the PC is still on, it is of a low voltage which can casue some issues for you! Sounds like this one is yours!
Nov 21, 2007 | Acer Aspire 3680 Laptop
ACER Travel Mate 5520
it could be a vga driver fault check the driver in device manager.
if the device can not start, uninstall the driver and reinstall.
ONLY DO THIS IF YOU HAVE THE ORIGINAL DRIVERS!
Oct 28, 2007 | Acer TravelMate 2300 Notebook
Where is the cmos battery for an acer aspire 1690 laptop
Hi I have found you a service manual that should tell ya all. http://rapidshare.com/files/48828906/S.G_AS3010_5010.zip The BIOS in most lappy's are usually soldered I expect this to B the same. (I DL the manual to test link ..)
Aug 21, 2007 | Acer Aspire 1690 Notebook
Acer Aspire One A150-1006 Notebook Logo
566 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
