Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
La 135 won't start
My LA 135 less than two years old suddenly developed power problems which degenerated into starting problems. When it did run it smoked and coughed. When I engaged the mower the noise and vibration were horrendous. I've drained the old fuel and put in new. No change. I repalced the spark plugs, nio change. I had such great luck with the Kohler in my L110, but this Briggs and Stratton is an embarrassment for both companies.
  • 69 Answers
If it was black smoke, then you're getting too much fuel in the system, which could be a lot of different things...air intake restriction, float in the carb, choke cable, etc.
Posted on Sep 09, 2009
Bloqueada con las luces parpadeando
return it to place purchased if only 3 days old should work for years .
Jul 09, 2015 | Singer Futura XL-400 Quartet 4-in-1 Sewing...
Solar outside temp. unit has started losing power
If the rechargeable battery is two years old, it probably needs to be replaced
Jan 29, 2013 | La Crosse Technology TX61U-IT Solar...
Cambie revelador a una minolta di 3510 hice todo el procedimiento de rutina y le di F8 y en la mitad del proceso dice que hay un error y saca el f33 salgo del modo de servicio y apago la fotocopiadora y la...
. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Sep 23, 2011 | Minolta DI2510 Black and White Copier
12 month old Westinghouse 42inch, screen is out, audio fine, what the can i do, can i get it fixed?
The usual cause of this problem is the backlight power supply going out. We do repairs on most Westinghouse products. Which model do you have? The repair should run less than $49 plus return shipping. If you need more information or to setup repair service for this unit contact us at :
tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
Jan 13, 2010 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Battery does not get charged fully... and does not support load of computer in backup mode...
hello,
If the battery backup unit is over 2.5 years old then you will need to replace the battery. Go to your local electronics parts house or battery distributor. They will have the gel cell battery you need in stock. These units are just like small car batteries, after a few years of use they will break down and not hold a full charge. When this starts to happen the battery life is about to be over, it will hold less and less charge until one day no power at all and then the UPS will not power on. The UPS have a monitor circuit that will prevent them from powering up with a dead or missing battery. The replacement battery should run less than $20.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 05, 2010 | APC Back-UPS CS 500VA UPS System
System unavailable in xerox pro 255 :(
esto lo puede dar el cartucho de copia mal insertado q produce arcos de la fuente de alta y la desconecta dando error 9060, tal vez el corotron roto del cartucho de copia.... otro padrenuestro
Oct 08, 2009 | Xerox WorkCentre M-24 Color Copier
Compressor will not engage.the engine runs fine but i can not get any high pressure.happenned suddenly while it was running.i have checked the wand for clogs.also,where is the unloader and how do i unstick...
PRIMERO DEBES DE PURGAR EL SITEMA CONECTA LA MANGUERA A TU TOMA DE AGUA Y SIN ENCENDER LA MAQUINA ACCIONA LA PISTOLA PARA QUE SALGA TODO EL AIRE DESPUES SIN SOLTAR EL GATILLO DE LA PISTOLA ENCIENDE LA MAQUINA
Oct 06, 2009 | Karcher 2500 PSI Pressure Washer
I-Inc iF191D wont stay on
You have a blown power supply. If it is less than a year old its under warranty, send it in for repair. If it is out of warranty our site can show you how repair the internal power supply. Our site is :
www.ccl-la.com/badcaps.htm click on the link at the bottom for monitor repair.
Buddy
Corporate Computer
www.ccl-la.com
Sep 24, 2009 | Hannstar I-Inc iF191DPB 19" LCD Monitor
Monitor goes black but green light on
i think this is the power supply i have same product and problem. i have completely dissembled the monitor and found taht there are three boards power/ input/ video conversion. there are four wires on the right side that go to the inside of the screen. well if you find where to get a new psu the me know
Nov 01, 2008 | Westinghouse L1975NW Monitor
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
936 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
