Question about Lexmark Z715 InkJet Printer
I have the same problem
I am using Windows 7
.We have a kit that runs .WINDOWS 95/098. Will.this product be used with. WINDOWS 7?
If you mean CAN it be used with Window 7, then possibly yes. See link below or just Google Use windows 98 software in windows 7
Run Windows 98 programs in Windows 7
May 09, 2016 | Computers & Internet
Can Vista Home Premium be upgraded to window's 7?
      If you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version ofWindows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
      Upgrading from Windows Vista to Windows 7 - Windows Help
      windows.microsoft.com/.../windows7/.../upgrading-fro... Microsoft Windows
    Feedback
    windows.microsoft.com/.../windows7/.../upgrading-f...
    Microsoft WindowsIf you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version of Windows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
    How To Upgrade from Vista to Windows 7 Home Premium ...
Feb 08, 2016 | Computers & Internet
What operating system do I need, so that when I run my cursor along the menu bar a window pops up, rather than a small text box?
How do I get the Aero desktop experience? The following editions of Windows 7 include Aero:
  • Windows 7 Enterprise
  • Windows 7 Home Premium
  • Windows 7 Professional
  • Windows 7 Ultimate
Aero is not included in Windows 7 Home Basic or Windows 7 Starter. You can find out which edition of Windows 7 you have on your computer by opening System in Control Panel.
The edition of Windows 7 you're running is displayed under Windows edition near the top of the window.
You also need to use a Windows theme to display Aero graphics. If you are using an Ease of Access theme, some elements such as transparency and thumbnail previews will not appear. To view which theme you are using, open Personalization in Control Panel.
The theme currently in use is highlighted.
Dec 11, 2014 | Microsoft Windows XP Professional for PC
Is adobe photoshop elements 3 compatible with windows 7
I want to mention that Photoshop Elements 3 is not tested with the Windows 7.
If you have a windows 7 64 bit operating System then it may not even install in it. If you have a 32 bit Operating System then you can try to install it. However it may still not work even on a Windows 7 32 bit Operation System as it was not made and tested for this Operating System.
There is a probability that if you install the Windows XP mode on you Windows 7 operating system then it may work.
Check more about installing Windows XP mode here:
http://windows.microsoft.com/en-IN/windows7/install-and-use-windows-xp-mode-in-windows-7 Install and use Windows XP Mode in Windows 7
Regards
Anand
Aug 30, 2014 | Computers & Internet
Forgot my login password to Windows 7
What if you forgot windows 7 password by accident? How to crack windows 7 password by yourself? Try this
wonderful SmartKey Windows Password Recovery as soon as possible. The same as Windows 8 password recovery tips.
Step 1: Download and install, run the program on a unlocked computer.
Step 2: Burn a bootable CD/DVD/USB Flash Drive with the program.
Step 3: Reset Windows password by the burned CD/DVD/USB Flash Drive.
Now it has promotion until Jan 15th,2013
http://www.recoverlostpassword.com/promotion/christmas.html
Sep 08, 2011 | Computers & Internet
Forgot my windows 7, password. how do i fix it? acer aspire 1410
If you have a bootable CD/USB drive,some password tools can be burn to it and you can boot your computer from USB to run the software,so that you can recover/remove Windows 7 password from USB.
Such as Daos Windows 7 Password Recovery Tool,here I just list the simple steps:
Step 1: Download Daos Windows 7 Password Recovery Tool/Windows Password Rescuer
Step 2: Run it to burn to bootable CD/DVD or USB flash drive
Step 3: BIOS setting of your locked computer to boot form CD or USB
Step 4: Reset Windows 7 password on a friendly window after "Daos Windows 7 Password Recovery Tool" starts.You also can use Daos Windows 7 Password Recovery Tool to add a new user with administrator privilege to your Windows. With this New user account you can logon your locked computer directly. http://www.daossoft.com/windows-7-password-recovery/how-to-use-windows-7-password-recovery-tool.html
Jul 29, 2011 | Acer Aspire 1410-8414 Netbook
Forgot my windows 7 password
Forgot Windows 7 password? Do you have reset disk?
If the answer is yes, directly click "Reset Password" link to reset forgotten Windows 7 password.
If not, learn some ways from here:
http://www.isunshare.com/windows-7-password/forgot-windows-7-password-no-reset-disk.html
Jul 08, 2011 | Acer Aspire 3680 Laptop
I'm running windows xp professional how can i upgrade to windows 7 and which version of windows 7 is better for me
Hi, You can't do a direct update from windows xp to windows 7 you will need to perform a clean install. This means you should backup everything on your computer as when you install windows 7 this information with be deleted. I would recommend windows 7 home premium as the best windows 7 for most people as it has everything you will require. Windows 7 Ultimate is more expense but gives you nothing of note extra.
Hope that helps.
Nov 26, 2010 | Microsoft Computers & Internet
I just bought ASUS K61IC-x3, where is preloaded windows 7 home premium x64. Also I have 2 recovery disks from ASUS - windows 7 x64 and windows 7 x32. If I want to set up windows 7 x32, do I need to buy...
Windows 7 x32 recovery disk is used when you have to recover the Windows 7 x32 from a disaster. It works very well but when you want to install or setup Windows 7 x32you have to buy a new Windows 7 x32. Once it is setup and you use your system and you find that the Windows 7 x32 is making some serious problems then you use Window 7 x32 recovery disk. These disks are not the same.
Hope I answered the question.
Good Luck!
Jul 29, 2010 | ASUS K61ICX3 Notebook
Drivers
I will recommend that you download and run the free Windows 7 Upgrade Advisor. It helps find issues with your computer’s hardware, devices that might affect installing Windows 7. Go to the Windows 7 Compatibility Center find direct links to drivers, updates, and downloads.
Apr 04, 2010 | Toshiba Satellite A300-ST6511 Notebook
Lexmark Z715 InkJet Printer Logo
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
