Question about GE 25952 Cordless Phone
Handset won't charge
When I put the handset from the base unit into the base unit, the charge/in use light comes on, but there is an intermittent click sound (ever minute or two), and the handset never charges, never comes up with anything on its window. Has the handset merely died? Resetting the base and replugging the handset's battery have no effect.
  • 24 Answers
Well, it is possible it has a bad cell in the battery, never reaching full voltage. check the battery with a volt meter if possible for 3.6 volts. otherwise trial and error may solve it, but batterys are getting to cost as much as phones nowdays.
Posted on Sep 06, 2009
The in use/charge indictor light does'nt come on when i put phone on it. I just brought a new battery.
Check your connections on hand set and base. Wiggle the handset on base to see if handset starts charging... If it does.. clean your connections or you have loose solder connections either in hand set or Base Unit.. Give that a try..
Chris
Sep 03, 2011 | Uniden Cordless Phone
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
I have put new batteries in my diverse 4016 phone on the base but it will not charge.can you please sugest what the problem maybe' thanking vou ...
It looks that the handset is not charging from the base unit: if you have a multimeter you can check that you have a voltage slightly higher than your battery pack voltage on the base unit. Make sure the contacts are clean and If you have no reading, then the charger on the base unit is very likely defective.
If you do not have a multimeter, check and clean the (two) contacts on your handset and base unit to ensure proper electrical contact and that you see the charging indicator displayed on both the base and the handset.
If that does not work, to assess if the issue is with the handset, swap the phones from the base and the stand-alone charging station and repeat the test: if it works, swap the batteries between the handset to see if it makes any difference. If it works, then the issue might be with the original base unit handset as you have now 'tested' the new battery on the alternative handset. To summarize, it is a test by trial and error swapping.
Hope the information is of assistance.
Sep 26, 2010 | GE 27851FE2 Phone
Uniden XS 1210 cordless phone won't connect to base unit
try connecting both phones via the base that is working and see if they recognize each other. Let me know if that works.
Jul 21, 2009 | Uniden Cordless Phone
Sony SPP-A946 base unit intermittently charges the hand set.
Clean the contacts on the handset and base that charge the battery.
AL
Mar 17, 2009 | Sony SPP A946 Cordless Phone
Where is the page button on the base unit to register phone????????
if i'm not mistaken all you do to register the phone is put the handset into the base unit ... i believe the light flashes for a sec then it's registered... repeat that with all the handsets you have. it will not be registered if you have put the handset into the spare charging stand if that is included with your phone.
Robert
Sep 22, 2008 | Uniden Cordless Phone
ELBT595 Handset Not Turning On
Check the handset battery -- if there is a slight "bulge" on one side (ie: not COMPLETELY flat) then the problem is with the battery. I had that problem and had to order a new one. That said, I just installed the new battery, and while it now charges, the handset won't connect to the base unit. The base unit works (tried the speakerphone), but there is not connection between base and handset.
Feb 18, 2008 | Uniden ELBT595 Cordless Phone
How do I add an extension handset to my current config?
IF it was a used handset it was likely registered to another base. I just switched bases (1line to a 2 line base). I had to "deregister" the handsets from the old base. I am not sure if you can deregister if the old base is not present? With the old base plugged into power I hit the "function key" at the bottom left of the handset and scrolled down to initial settings. Under registration is "deregistration". I selected that and it put the handset back to its default out of the box. Then simply hit the mute button on the New base and OK on the handset. Worked for all 5 of my old handsets.
Hope this helps
Jan 27, 2008 | Panasonic KX TGA270S Cordless Expansion...
Base does not charge handset
If all 3 handsets fail to charge on the base unit that leads one to the conclusion that the charger with-in the base unit has gone bad and I really don't know of any fix. Thank You. Jerry
Dec 28, 2007 | Uniden Cordless Phone
Base unit light blinking GE 27831
I had the same problem. Once I read the owners manual I found the charge light blinks to indicate that you have voicemail waiting to be retrieved via telecom provider. Much to my surprise I have a voicemail account I never requested.
Another mystery solved - I now know why I missed so many messages.
Dec 28, 2007 | GE 27831 Cordless Phone
GE 25952 Cordless Phone Logo
136 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
