Question about Black & Decker ASI300 Air Station Inflator
Not producing much air volume
The compressor is not producing much air volume and will not fully inflate...ha sbeen working fine until now...
  • 2,176 Answers
I have checked on t his tool before and they don't offer replacement parts as of that date. I would suggest going to Dewaltservicenet.com and typing in your model number for a copy of the owners manual and they also have a toll free number that you can call for assistance.
Posted on Sep 09, 2009
I replaced the air shocks on my Olds Silhouette with no problem and thought the problem I had (van sitting very high in back) was solved. Rode great first week or so afterwards. Now it is back to shocks...
Check the bleed port on the controller, it may be plugged with dirt. or the controller may have failed. A full funtion scanner would help find the problem.
An other option is to by-pass the auto- leveling system and install a manual scrader valve in the air line, this would allow you to add and remove air with any source. They are availble at most autopart stores.
May 12, 2011 | 2000 Oldsmobile Silhouette
I have an compair hv11 hydrovane compressor. everything works fine until the unit is switched off, then a mist pours out of the air intake side until the air is fully discharged. any ideas,
Hi, my name is John. Welcome to FixYa. You need to bleed the water from tank. Loosen the valve at the bottom of tank until all water is out. I bleed mine daily. Thanks for choosing FixYa....John
Nov 26, 2010 | Air Tools & Compressors
The compressor quit is there a place to manually inflate the air bags until i get the replacement compressor
You will probably be able to find an air inflation port mounted on the rear axle near where the bags are mounted. Make sure the kill switch for the bags has not failed keeping power from going to the compressor.
Sep 24, 2009 | 1997 Ford Expedition
The air conditioner is running fine but is not cooling
I have to ask this. If it's running fine, but not cooling, then it's really not running fine is it? ha-ha Sorry. Are you saying it's not cooling enough? Does compressor stay kicked in, or does it cut out early? Fan working o.k.? Give some more details and we'll see if we can help.
Aug 17, 2009 | Dometic Rooftop RV Air Conditioner
Air suspension does not inflate air compressor does not kick in suspension fully delated
have to check the compressor run-check-check the fuse or relay switch that drives the compressor
Aug 12, 2009 | 2002 Oldsmobile Bravada
Air conditioner blows hot air fully charged with
compressor or receiver/dryer or condensor may need to be replaced. Further testing will have to be done. Look into your sight glass and see if there is any bubbles in the glass, or if glass is extremely foggy. If so, you may have air in the system. Check to make sure you are getting power to the compressor.
Jul 20, 2009 | 1995 Lincoln Town Car
Craftsman 30'' mower front tire off rim can't put back on
hello...is the tire loose but still on the rim...the sidewalls no longer engage the rim tight to hold air but still aroung the rim loose....If that's the case, get a jack, can of fix a flat, and a small ratcheting hold down strap.....jact the tire off the ground.....wrap the strap around the tire and ratchet it tight to get the beads of the tire to touch the rim....then commect the fix a flat or, if you have ,,,air from compressor to inflate the tire,,,,might have to work it a little to get the tire to reseat on the rim....this should work for you....once the tire is seated on the rim....stop inflating the tire until you remove the strap or you migh have a problem getting it to release from the tire if fully inflated....
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Rear air ride shock over inflate and will not deflate
I would recommend going to strutmasters.com and taking a look at the conversion kits. these convert you from the airbag to a powder coated American made steel coil spring that is guaranteed to last the life of the car. Airbags and compressors are constantly having to be replaced. Also something alot of people don't know is that theses air suspensions are not meant to be in temperatures above 90 Degrees or below 40 Degrees. That is most of the world. The temperature will cause you to replace alot of bags. and typically when your replacing a bag you are going to have to replace the compressor to because the bag had a hole or small crack in it causing the compressor to over work and it will die. I posted the link below so you can take a look http://www.strutmasters.com/lincoln-suspension-parts-s/1.htm I hope I was of some help Good Luck!!!
Jan 30, 2009 | 1994 Cadillac Fleetwood
Black & Decker ASI300 Air Station Inflator Logo
277 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
