Question about Fuji DX-10 Digital Camera
Card is write protected it wont format in camera or and computer it is 64mb card it has pics on it so works ok
    Brigadier General:
  • 11,967 Answers
Is the slide switch on the side of the card in the locked or unlocked position?
Posted on Sep 07, 2009
Cant get past 'card not initialized', even though I've used it in this Fuji finepix jx500 camera before. it erased pics when i hit format, but that's all.
Make sure that you do a format in your computer before you reinstall your card,check to see which format you require some want fat 32 others may require a different format.
Apr 19, 2014 | Fuji Film FinePix JX500 14 Megapixel...
When i try to take a pic, the words "WRITE PROTECT" appears on my screen & wont let me take a pic, can you tell me why this is?
Try to format your SD card on your computer, you should be able to uncheck the write protect option, in the format menu.
Hoping for a Windows-based computer, Start > My Computer > under "devices with removable storage" right click on your SD card, choose format, options should appear.
Hope this helps...
Jan 07, 2012 | GE A1455 Digital Camera
Nikkon coolpix L1 After downloading memory card .. then putting back into camera. Reading says "cannot read memory card." Checked card out at store verified that it is good. Why does it not work in my...
A couple things you might try.. remove the card carefully and check the position of the "lock" tab. Make sure it is fully in the unlocked position - not locked or a point between the two positions. Reinsert and try again.
It sounds lie you're using a card reader to download the pictures - try formatting the card while in the card reader via computer. The card should be completely empty when the format is complete. You can even try copying files to and from the card to make sure its ok and format again. When complete, try again in camera.
If the problem persists, check to make sure the card is on Nikon approved memory card list for use with the Coolpix L1 (provided below):
The following is a list of approved memory cards for the Coolpix L1 digital still camera. These cards have been tested and approved for use with the Coolpix L1.
The L1 uses SD (Secure Digital) memory. Sandisk:
  • 64MB, 128 MB, 256MB, 512MB, 1 GB, 256MB*, 512MB*, 1GB*
Toshiba:
  • 64MB, 128MB, 256MB, 512MB, 1 GB, 128 MB*, 256MB*, 512MB
Panasonic:
  • 64MB, 128MB, 256MB, 1 GB, 256MB*, 512MB*, 1GB*
* - Cards rated for 10MB/s (high speed) Other cards have not been tested. For more details on the memory cards listed above, please contact the manufacturer.
The list came direct from Nikon Support. Other cards may work, but only those on the list are approved. Successful use of other cards can not be guaranteed.
I hope this helps!
Sep 30, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Card protected
Use a separate card reader to download your pics. Then, you can format the card in the camera to get it to work properly.
Mar 25, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
My Canon PowerShot A430 does not want to unprotect one image. I have tried to go to erase all in the menu, and I have tried to got to protect to see if it will reverse the protection but it does not do...
Reformat the SD card with your computer. This will delete all data on the card. Do you use a usb cable to upload pics to your computer or put the SD card in a media slot? Either way, find the drive that corresponds to your SD card or camera in "My Computer". Right click on it and select 'format'. A new window will open with a check box for 'quick format'. Check the box and click OK. A prompt will appear stating all data will be erased. Click OK. In a few seconds, the card will be reformatted.
Oct 06, 2009 | Canon PowerShot A430 Digital Camera
The camera is locked and i'm unable to make video or take pictures. The screen shows me "write protect"
remove the memory card and connect it to a pc using a card reader and check if it is working or u have a same problem
Jul 15, 2009 | Olympus Stylus 1020 / µ[mju:]1020 Digital...
When I go to take a pic, it won't let me because it says "write protect"
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup- right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Apr 20, 2009 | Olympus Stylus 740 Digital Camera
My camera says write protect and won't let me take pics
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Feb 07, 2009 | Olympus Cameras
Can't make any photo or preview
Jan 04, 2009 | Olympus Camedia D-425 / C-170 Digital...
CAN'T EDIT OR MAKE ANY PICS
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect image and the card can be used again.
Fuji DX-10 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
