Question about Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher
Loud noise maytag quiet 300 series dishwasher making a loud grinding and screaching noise, sounds like plastic gears grinding on each other
Check for bones/glass/ceramic from chipped plates in the food chopper (for lack of a better term). You'll need to disassemble the entire lower arm unit.
Posted on Oct 06, 2009
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    Grinding noise in chopper, Maytag 200 Quiet series
    Please let me know what you did to fix this...I am having the same problem with ours. I noticed a recall on the same model just with a plastic tub. Thanks..
    alisiajan@gmail.com
    May 24, 2010 | Maytag Dishwashers
    Our Quiet Series 300 Maytag Dishwasher is LOUD
    few things move on these but the jets and the discharge pump. Are there rotating jets that are removable, if so remove them and clean them it might just be dirt. if you cant find the fault then yes! a repair man could sort it out.
    Jan 10, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
    Maytag Quiet Series 300 Dishwasher will not turn off after it com
    MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
    Apr 05, 2009 | Dishwashers
    Maytag dishwasher legacy 300 quiet series
    Check for foreign objects like glass or plastic at the grinder blades. Some dis assembly will be required. See appliancepartspros.com for diagram.
    Mar 22, 2009 | Maytag 24 in. MDBH955AW Built-in...
    Loud noise during cycle MDB6600AWB Maytag Quiet Series II
    look for odjects in the pump cutter ie glass plastic or the cutter is bent or a rushing sound could be motor bearings
    Dec 24, 2008 | Maytag 24 in. MDB5600A Jetclean II...
    Maytag quiet series 300 model mdb5601aws making noise
    sounds like the macerator is bent out of shape from something going through the pump. Get a impeller kit and replace all the parts and you should lose the grinding noise. I can look up the part number if you want
    Nov 25, 2008 | Maytag 24 in. MDB5601AWS Stainless Steel...
    Grinding noise for maytag quietseries 200 usually when it first starts up
    I had the same problem with my Maytag Quiet Series 1 dishwasher until I read the comment left by the guest on June 1, 2008. I tried his suggestion about the rinse cap adjustment and WOW it WORKED. No more growling noise. Thanks you saved me a service call.
    Apr 06, 2008 | Dishwashers
    Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher Logo
    830 people viewed this question
    Top Maytag Dishwashers Experts
    Charles T Nevin
    Charles T Nevin
    Mike
    Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
