Question about Kenmore 24032\24036 Top Load Washer
Washer suddenly wont spin
A load of clothes was on the spin cycle when I noticed the sound suddenly changed. When I went to check it out, it was not spinning. I depressed the lid switch with my finger and it clicked and what I think was the motor started to run, but it still wouldn't spin.
  • 89 Answers
You need to check the motor coupling first you remove the two screws on the front panel they are located one on each side either on th front or back corners you will see two metal clips remove them then unplug the lid switch now you can remove the housing the coupling is at the bottom between the motor and transmission remove the two clips from the pump use a large screw driver to hold pump out of your way next remove the two screws and clips from the motor the motor should come off you will see the coupling check it it is more than likely broken
Posted on Sep 06, 2009
Clothes are still wet after full spin cycle
Possible that the SPIN Speed is too low, check the drive, the RPM of the motor. Check for friction of the spindle , check for free movement of the drum. If you notice a change then you will need to reset the mechanism. If the motor speed is low check the capacitor.
Jan 24, 2013 | Hotpoint WMA64 Front Load Washer
Wont drain
First Try Unplugging the washer for 15 minutes. Sounds like the pump is the issue. Was it a normal load of clothes or a Bath rug or blanket?After you plug the unit in try to select rinse/drain Or drain/spin.
If it starts try to cancel the cycle. The washer should drain the water out for you. Pls update when you can.
Sep 01, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer top load all cycles normal but when in the rinse/spin cycle notice it does not seem to spin fast enough to remove water from clothes and the are wetter then normal
There could be a number of reasons My best guess is that it will reduce the spin speed if it thinks it can't drain properly. Check that all the pipes/ filters etc are clear and that it can drain all the water out. Also it wont spin fast if the load is unbalanced. Does the spin speed change according to loading or is it low all the time? It may have a motor control problem, but that seems unlikely if it's working normally other than the spin.
Jan 13, 2011 | Washing Machines
The washer is not spinning well...Clothes are partly wet when cycle is completely off...it used also to leak at one time where we can see some water when the cycle is complete...
Hello, when the clothes are partly wet when cycle is complete then check these.
1. Motor coupler
2. Spin cycle
MOTOR COUPLER; To test the motor coupler, restart the washer in it's spin cycle,let the machine runs for a minutes and then open the lid and notice if the tub is spinning: if it's spinning when you lift the lid that means the coupler is fine and if it doesn't spin that means you have to replace it.
SPIN CYCLE: If the washer doesn't reach it's proper spin speed,the cloth may be wet at the end of the cycle,check to be if the load is properly balanced and run a spin cycle again,if the clothes are still wet, you may have a worn or loose belt which you have to replace.
Thanks
Jun 10, 2010 | Maytag LAT3600A Top Load Washer
Washer wont work
This sounds like the lid switch went bad. If you put it back on the wash cycle and it agitates, but will not pump out and spin, more than likely it needs a new lid switch. If this helps, please rate my answer. Thank you. If it doesn't help, we will take it further and try and get you fixed up.
Jan 06, 2010 | Roper RAS8445KQ Top Load Washer
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Washing machine works, but wont do spin cycle- clothes sopping wet but clean
first off check to make sure its spinning at all. although the waters draining is it really spinning? are the clothes stuck to the side walls as if they had??if so i would tip machine back and look on floor and around the inside of cabinet approx 12 in. from ground level looking for oil,( transmission oil) . if present youll need a new transmission and clutch assy
Mar 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
No longer spinning/loud noise
Did all the standing water pump out?? If sou you may have broken a drive coupling
Jan 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer spin problem
Ok so your having problems with the washer spin problem. Well there mightbe a sound that it is making like a jumpoing sound. Well when you here that open it and you might notice that all the clothes are on one side. That means that you put too much clothes in the washer, and it can't handle it. So open it and take out some clothes and restart it. I hope i helped you problem's. Thank you for taking your time to read my article.
Feb 12, 2007 | Whirlpool LTE5243D Top Load Stacked...
Kenmore 24032\24036 Top Load Washer Logo
21 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
