Question about Sony Video Cameras
Does a Sony CCD FX 425 have a tracking control when playing a tape in VCR mode?
5 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Sony Handycam Vision ccd-trv308
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Jan 22, 2008
SOURCE: SONY HANDYCAM CCD TRV-108
All of a sudden no picture appears on the screen when recording or playing back. It will play old tapes that have been recorded, but won't record any new pictures, just sound. Did I press something? It worked a month ago and hasn't been used since.
Posted on May 02, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony CCD-FX310 Camcorder how to adjust tracking
Sony camcorders has no tracking control for user.
I think video head is dirty / clogged. Put good quality video head cleaning tape in camcorder and check.
Its almost 15 years old camcorder.
Posted on Jan 30, 2009
SOURCE: Have a Sony CCD V9 camcorder. Stored it for years
Use a hairdryer to warm up the cassette area. My camcorder did same thing and this worked.
Posted on Apr 09, 2011
Video on my Sony VCR (SLV-780HF) goes gray after playing a tape a few seconds. What could be the problem?
The only real cure will be to clean the video head. If that doesn't work then I'm afraid that whatever recorded you EP mode tape was not set up well tracking wise. So other machines struggle to track the tape. Some VCR's will only playback SP or LP tapes and don't have EP mode. In which case you should check to see if these VCR's can play the EP tape and if they can't find one that can.
Dec 06, 2012 | Sony Televison & Video
When playing back vcr tapes on my magnavox ZV427MG9 A, i have a tracking problem with tapes recorded on slp. i get white streaks on the playback, and manual tracking does not help. tapes recorded on s
The VCR has at least four "heads" two are for 2 hr and two for 6 hour (sp and slp)
It is most likely one of the heads used in the SLP mode is slightly blocked with tape debris--heads need to be manually cleaned in the right way.
Jun 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
When i record and play back video i have no sound
If you are playing the tape in the camcorder, are you sure the volume control didn't get accidentally turned down or off? The control is the thumb wheel on the back of the camera below the viewfinder. See page 22 of your manual. If you are playing the tape in another VCR there is some other problem.
Apr 15, 2011 | Sony Handycam CCD-TRV12 Camcorder
When i chage the option of oFF to CAMERA nothing turns on and when I change the option OFF to VCR the screen just show strange symbol and SP and it does not work
just so you know, your camera model was included in the list for what we call the "ccd program". this program has ran for 5 years and unfortunately ended march this year. sony gave free repairs for cameras and camcorders affected by the defective ccd imaging sensor before the said date. issue with the camera shows a black or distorted screen in camera mode. but the you should still be able to see the indicators on the screen. when switch to vcr you should be able to play back previous recordings that you made. better to really make sure its a ccd issue, play a tape that you're sure contains a movie recording and play it, then set it to camera mode and see if you get just a black screen. if you try recording using a tape, you may see nothing but should hear the audio part. if this is what's happening we can be sure it's a ccd issue. if your camcorder just won't turn on in camera mode, maybe the power switch turned defective or it can be other parts of the unit that stopped working.if this is the case, then of course, your unit may require service to address the problem.hope this info helps.thanks:)
Aug 25, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
Jan 30, 2009 | Canon ES75 Camcorder
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
Why wont it play LP taped tapes?
Tracking is very sensitive on hi-8 tapes in LP mode. This recorder will record and playback in LP mode. It is however recommended that if you record in LP mode that you use the same camera to play it back, that it was recorded with, or you might have problems.
Also from what I can find online, the TR427 is just an video8 camera not a Hi-8 so if you are trying to play Hi-8 tapes on it, it won't play right.
Nov 03, 2017 | Sony Handycam CCD-TR427 Hi-8 Analog...
Sony VCR plays/recordes in EP mode but not in SP mode - need schematic
sounds like it needs a good cleaning, you will notice this problem in sp first when needs cleaned. however if you had done this I would go over it again and if not then change the video head
Nov 19, 2007 | Televison & Video
Vcr tape problem
It sounds like the tracking information is being lost for brief periods of time. Tracking is recorded at the lower edge of the tape, and if the tape is wrinkled or otherwise damaged in this area, playback will go out to lunch. A visual check of the tape would be in order. Have the heads been cleaned in these machines? This would be another area to check.... Also, there could be small differences in the tape path alignments, perhaps the control/audio head alignment is slightly different between the 2 machines.
Apr 28, 2007 | Panasonic AG-1980 S-VHS VCR
Video Cameras Logo
122 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
