Question about Price Pfister 532-7PCC Marielle Pull-Out Kitchen Faucet with Matching Soap...
Plumming Water leaks from the top handle modle#53470ss
    Problem Solver:
  • 12 Answers
Its the rubber washer. replace it and all will be fine!
Posted on Sep 08, 2009
Pool filter leak
If you can put some food coloring in it so you can see the leak better and you find a crack in internal or external on both fitting; may be find the parts are warn down some and may need some plumming tape put on them or replaced.
Sep 18, 2013 | Pentair Garden
Plumming brass nipple leaking water
Are you installing nipple in top of tank-type water heater?
Did you use 6 wraps teflon tape?
Is the nipple IP iron pipe tapered thread? Or is it straight thread?
Why are you replacing nipple?
Was old nipple leaking?
If previously sealed pipe connection to water heater has started leaking, then it implies the tank is rusted, and water heater needs to be replaced.
http://waterheatertimer.org/Leaking-water-heater.html
Have you checked the anode rod.
http://waterheatertimer.org/Replace-anode-rod.html
Why are you using brass instead of pex-lined di-electric nipple, available from box store?
http://waterheatertimer.org/images/IMG_1879-di-electric-nipple-800.jpg
Sep 11, 2012 | Water Heaters
How do I tighen the door handles on my GE Modle Profile Performance side-by-side refrigerator?
with a small flat blade screw driver stick between the handle and the door trim on top and push it up and on the bottom push it down and you can access the screws in the handles and tighten
Jul 11, 2011 | Refrigerators
Leaking around the top, tightened the handle, leaking down the sides to the base from top ring
hi . there should be an o-ring or a piece of dirt under the top . cut water off and take handle off clean and put back together it should be fine. have a good day.
Feb 09, 2011 | Kohler Fort© Single Lever Handle Kitchen...
All the lights come on but the machine does not wash
The problem could be 1) The inlet solinoid in line with the main water inlet faulty this acts as an electrical tap controling the inlet water. 2) The triggering of the anti flood system (polysireene float and micro switch at the base of washer) due to water leak / spill (this device causes the washer to stop until the leak is cleared.3) Water pressure to low.
Jun 01, 2010 | Baumatic 23 in. BDW5 Built-in Dishwasher
Faucet is leaking from the cold water line inside the faucet. it is a danze lazio pull out kitchen faucet
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
Mar 30, 2010 | Danze D403412 Melrose Single Handle...
My refrigerator is leaking water from the back GE Modle # GSS22WGPEWW
If you moved it recently, the line to the Ice maker valve may have loosened a bit, also could be the drip pan has moved and water is dripping out on to the floor during defrost. Last the drain hose has came loose from the holder up top and water is just running down it.
Jul 30, 2009 | Refrigerators
Washer leaking some after everything is done washing? why ?
The most common source of leaks from the bottom on a regular basis is a bad pump. Add a little water into the unit. Pull it forward and tilt it back about 45 degrees resting the top against the wall. On the botom center towards the front, you should see a white plastic looking thing. This is the pump and usually where the water leaks from. You can get a replacement on from the manufactures web site or from local appliance parts stores.
May 31, 2008 | Whirlpool GSC9455 Top Load Washer
Water and clearen not coming out.
If the modle is an old modle the heater could be blocked,or if it a new modle try taking of the of the handle and ad a small shim to the bottom of the handle plunger to make it a little bit longer ,the plunger might not be reaching the valve,
also unscrew the clear cap which which is on top of the red spinner to see if the white filter under the spinner is clean and free from debris.
when you put the cap back on make sure its not to thigt and the spinner move freely, if the suction is poor make sure the red lint filter in the clean water tank is clean
Oct 20, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Price Pfister 532-7PCC Marielle Pull-Out Kitchen Faucet with Matching Soap... Logo
100 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
