Question about Kenmore HE2 Plus Front Load Washer
F21 code - Kenmore HE2 Plus Front Load Washer
    President:
  • 1,776 Answers
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller will spin freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump, drain line, or a jammed impeller. Hope this helped and best wishes.
Posted on Sep 06, 2009
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Flashing display 7 mins into cycle. Water drains away and eventually display goes blank. Help?
Do you get an F21 code or some other code.
An F21 code means the water is not draining away properly. There may be plugged pipe.
Here are some tips to help you:
1. Check to make sure the washer's drain pipe is draining properly.
2. Check the drain hose to see if there are any kicks or clogs in it.
3. Check the washer for excessive subs. Sometimes excessive subs can also keep the water from draining.
Of course, the above tips are useful only if you have a F21 code. If you have other error codes, you'll have to look at the manual that came with the machine.
Feb 22, 2013 | Washing Machines
I have a Kenmore HE2Plus - it is 6 years old. All of a sudden two days ago I got up to a load of laundry not done, full of water and the code F21. We have gone through most all of your suggestions. At...
The Sd code appears when sud is detected but it may also indicate draining problem such as blocked drain filter or broken drain pump as signified by the long drain error code F21. The drain pump impeller may be broken or restricted resulting in poor draining or no draining at all or the drain pump motor is faulty. Since the drain hose and filter have been cleaned but the error code still persists, the drain pump likely needs to be replaced. Click on the link below for the detailed troubleshooting instructions.
Troubleshooting Error Code F02/F21 on Kenmore Elite and Whirlpool Duet Front Load Washing
Jun 18, 2011 | Washing Machines
I got a F21 error, went through and pulled out the drain filter. And tried to start again continued getting F21 error. Bought a new water pump and still getting the F21, also backfilled some water into...
sounds like you have covered all the bases --- the next thing that I would try is to simply unplug the unit from the wall and let is sit for a minute or two and then plug back in. if this does not solve your F21 code, then I would say that the problem is at the sensor or main circuit board.
let me know if you need further help with this issue,
c...
Feb 03, 2011 | Kenmore HE2 Plus Front Load Washer
Whirlpool washer wfw8300sw02 code F21 what does that mean
the F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
c...
Feb 03, 2011 | Whirlpool Washing Machines
F21 code flashes
Lets see what an F-21 is shall we? F21 Long drain Possible cause: Clogged filter, clogged/failed pump, suds detected by control.3a5b94a.jpgb4a897e.jpg55f108d.jpg
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What do you do if you get an F21 code on a Kenmore Elite HE 3t steam front load washer
The F21 error code is an indication that the unit has a too long of a drain out condition. If the control call for the unit to drain & the water does not drain out in 8 minutes or less the unit will stop & flash the F21 error code. I would recommend checking the drain pump & pressure switch circuit.
Mar 06, 2010 | Washing Machines
F21 error code on a Kenmore HE2 front load washer
Unscrew the pump, there is probably objects in the pump, I get that error every month or so, I find coins in my pump all the time, if too much stuff gets in there the code F21 or sometimes SD comes up.
Jul 24, 2008 | Washing Machines
Bosch Exxcel Washer F21 error code
got a bosch washing manchine it keeps coming up f21 error and i have no book 2 see wot it is can you help me by tellin me wot it is thanks
Apr 11, 2008 | Bosch Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
200 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
