Question about Refrigerators
Refrigertor part does not cool at all. Freezer part works until ice forms on the bottom then it cuts off. If you turn the refrigerator off for a couple of hours then it will start back working. Then the same thing starts all over again. It use to work for a couple of days now it only works for a couple of hours.
  • 4,059 Answers
Your evaporator coils are probably not being defrosted by the auto defrost system. check defrost timer, defrost heater, defrost thermostat. How to checkeverything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Inmost newer models the timer has been replaced by an electronic control board.If the heater and thermostat are ok it’ll be the control. Post your model number and I my can find a diagram to see what your model has.
You can turn the defrost timer till it clicksand everything shuts down. The heater should now come on. If it does, replacethe timer. If it doesn't, check the heater and defrost thermostat. Turn thetimer again till everything starts back up to end the defrost cycle.
Posted on Sep 06, 2009
Sub sero refrigertor forms ice on the back wall
Call for service. you most likely have a leak.
Jun 22, 2014 | Sub-Zero 650 / O Bottom Freezer...
Frig & freezer not cooling enough. Ice forming in back of bottom freezer.
You need to have the defrost cycle checked.( heater, limit stat, timer) If the frig can't defrost air can't move across your coils to cool properly. To temporarily get by until you can get a repairman, use a blow dryer to melt the ice build up. Once melted it will work normally for about 2 days till it freezes up again.
Nov 13, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer works, but has some ice forming and refrigerator not cooling.
The refrigerator half of a refrigerator/freezer does not produce any cold! The refrigerator is cooled by transferring air from the freezer to the fridge. The fridge temperature setting controls a flapper between the freezer and the fridge. There should be a fan which blows air from the freezer into the fridge (through the damper).
If the ice forming in the freezer is concealing the cooling coil and air can not move through the coils, then the overall result will be a warm freezer (even though there may be ice in one location) and a warmer yet fridge. This can be tested by unplugging the fridge and allowing a complete thaw. If the ice is the cause of the problem, then it should work for a short while until it freezes up improperly again
:o).
Jun 04, 2011 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
Freezer working ok but refrigertor not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 06, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fails to cool
is the condenser fan at the bottom of the refrigerator blower air is there ice build up in the freezer side behind the wall is the refrigertor running at all is the fan in the freezer working
Sep 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Forming ice in the freezer vent going to bottom
It could also be your defrost heater. Look in side your fridge at the adjustment knob. It is in a box attached to the ceiling of your fridge. Look under this and you should see a plastic screw. Turn this screw until the motor cuts off. Leave it off for about 30 minutes. If motor turns back on then the defrost timer is working. The defrost heater is in the back panel of the freezer. The defrost heater looks like a long tube that runs under the freezer coils and half way up both sides. If after turning the screw on the defrost timer and the fridge doesn't turn back on then it is the defrost timer. The time is inside the box the adjustment knob is on.
Apr 24, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer not freezing
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, you can try turning freezer to Warmer freezer allowing MORE air to refrigertor side.
Sep 05, 2007 | Frigidaire FRT17G4B Top Freezer...
Refrigerator/Freezer not cooling
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, by compressor Make sure compressor is running and not shutting off on overload.. u said comp. hot.. should be warm... Not hot check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 04, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
