Electrolux stacking wash dryer ,the wash mach. will not agitate in wash cycle .it sounds like its moving but when you look it just sitting still .all the other cycles work.this unit is from jan 08 ..so,if you advance the dial past the non agitating wash cycle it works like normal.
  • 35 Answers
The door switch needs to be replaced.
Posted on Sep 06, 2009
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Nov 24, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Washer will not go through spin cycle
it sounds like it could be the lid switch malfunctioning. the part should look something like this. d668319.jpg
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 29, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stacked W/D will not agitate during wash cycle
hi thanks for the question i dont know the model of your washer but i think yours is a direct drive no belt you have a motor drive coupling which is located between the motor and transmission replace that part thanks the appliance doctor
Mar 31, 2008 | Kenmore 98702 Stacked Washer/Dryer
Agitator very noisy while washing
There is a small roller that tightens the drive belt for the drum inside this unit. If it is loose it makes a squeaking noise. Tightening this may solve your problem. You will have to take off the back panel to do this repair
Jan 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Agitator always moving
The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
Nov 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
Top Washing Machines Experts
