Question about Mitsubishi WT-42311 42" Rear Projection Television
It wouldn't turn on until you unplugged it and recently when you press the power button the light flashes twice, you hear a click, but it doesn't turn on . Just wondering if it can be repaired cheap or thrown away
  • Mitsubishi Master
  • 5,568 Answers
It is highly likely that the main power supply has failed; your description points to this.
The main supply is normally on separate board, recognizable by the larger components on it and it will be related to the incoming AC line. Look for cylindrical parts mounted 90 degrees to the board as well as larger (inches) blocks, these are chokes and transformers. The supply is typically connected with plugs and jacks and not tough to remove.
If you can locate the board, look for an assembly number and contact the mfr. with that and your model/serial number and inquire about replacement or repair cost.
If you must buy a new one, look for smaller companies that offer repairs on supplies since it makes sense to have a sapre around for the next time.
Posted on Sep 06, 2009
HOW TO CHANGE LANGUAGE ON JABRA MINI BLUETOOTH
Turn off headset, press and hold power button till light flashes blue and red continously.
Release power button and press it twice. You will hear a Chinese voice prompt.
Press twice again to hear English voice prompt.
Press and hold till it turns off.
Turn it back on and connect to phone.
Oct 12, 2016 | Jabra Solemate Mini Portable Bluetooth...
I am trying to unlock the region code for Sony BDP-S5100 with the URC7740. The hack program refers to "press and hold the &#147 key. Where or what is "&#"?
I would have to guess, that is probably not the correct remote. I feel I must inform you, trying to upgrade your firmware, from an unsavory hacker, can turn your unit into a brick(doorstop). IMO, proceed with caution.
Jan 14, 2015 | One For All URC 7740 Remote Control
Bdv e3100 region free
try this
1. Press DVD
2. Hold the magic button until the DVD button flashes twice.
3. Press 0533
4. Hold the magic button until the DVD button flashes twice.
5. Press 994
6. Press Magic Key (don't hold)
7. Press 1891 (this sets key 1 - the DVD button flashes twice)
8. Hold the magic button until the DVD button flashes twice.
9. Press 994
10. Press Magic Key (don't hold)
11. Press 2552 (this sets key 2 - the DVD button flashes twice)
12. Hold the magic button until the DVD button flashes twice.
13. Press 994
14. Press Magic Key (don't hold)
15. Press 0953 (this sets key 3 - the DVD button flashes twice)
16. Hold the magic button until the DVD button flashes twice.
17. Press 994
18. Press Magic Key (don't hold)
19. Press 2214 (this sets key 4 - the DVD button flashes twice)
20. Hold the magic button until the DVD button flashes twice. .
21. Press 994
22. Press Magic Key (don't hold)
23. Press 0795 (this sets key 5 - the DVD button flashes twice)
Done - the remote is now programmed and ready to use
Oct 16, 2013 | Sony BDV-E3100 5.1 Channel 3D Blu-ray Disc...
Power but not printing
Hi Linda,
Did you check if the printer is able to scan or does it makes photocopy? if the printer doesn't respond to any input follow below steps.
  • Power Drain:
  1. Turn the printer OFF using the power button.
  2. Disconnect the power and USB cable from the back side of the printer.
  3. Press and hold the Power button for 30 seconds and release the button.
  4. Connect the power cable and try printing.
  5. If the above steps didn't work try below.
  • Partial Reset: Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button. If you still see the issue try next level of reset.
  • Semi Full Reset:- Remove the ink cartridges; Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
Feb 07, 2012 | HP PSC Photosmart 2355 All-in-One Printer
I have requirement of region code cracker for sony 3d E370
hi,
To make your BD player you need One for all universal remote control
Full procedure for a oneforall remote is as follows:
1. Press DVD
3. Press 0533
4. Hold the magic button until it flashes twice.
5. Press 994
7. Press 00189 (if your oneforall remote uses 4 digit or 3 digit codes, use less leading zeros)
8. Press 1 ( this sets it to key 1 - it flashes twice )
9. Hold the magic button until it flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until it flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until it flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until it flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079
28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDV-E370 region free:
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it.
2. Press 1, 2, 3, 4, 5 on the oneforall remote. The 24p light will start flashing. (Centre light)
3. Put the player back into standby with the Sony remote.
4. Hard reboot machine (remove power)to prevent the 24p light flashing indefinitely.
5. Next time you turn on the player it will be region free for DVD playback.
ok
Aug 08, 2011 | Sony Televison & Video
I bought a Sony BDV-E570 in US and it came locked for region 1. As I live in Brazil, I need to run region 4 dvds. Do you know how to unlock it? Thanks
NO LIABILITY IS OFFERED HERE!! THIS IS A HACK!!!
1. Press DVD
3. Press 0533
5. Press 994
10. Press 994
12. Press 00255
15. Press 994
17. Press 00095
20. Press 994
22. Press 00221
25. Press 994
27. Press 00079
This worked for me, but obviously I accept no liability for anyone who tries it on their machine.
Mar 23, 2011 | Sony BDVE570 Theater System
How do you get BDP-S360 to play all regions?
hi,
to make ur player region free for dvd u should have a Oneforall universal remote wich acept 4 digit code
Firs of all u have to program the remote for the purpose. procedure is as follows
1. Press DVD
3. Press 0533
5. Press 994
10. Press 994
12. Press 00255
15. Press 994
17. Press 00095
20. Press 994
22. Press 00221
25. Press 994
27. Press 00079
The remote is now programmed and ready to use, to make the BDP-S360 region free:
ok
Jan 22, 2011 | Sony BDPS370 BluRay Player
I have a Sony BDP S370 and I would like to make it region free for my DVDs.
hi,
u can make your dvd for region free DVD play back. but for that you have to purchase an universal remote (ONE FOR ALL URC-7950). through this remote only you can make player DVD region free.
first of all u have to set( program) the remote for the same purpose.
Full procedure for the OneForAll URC-7950 remote is as follows:(preparing remote)
1. Press DVD
2. Hold the magic button until the Power key flashes twice.
3. Press 0533
4. Hold the magic button until the red led flashes twice.
5. Press 994
6. Press Magic key (don't hold)
7. Press 00189
8. Press 1 ( this sets it to key 1 - it flashes twice, if not repeat steps 4 to 8 )
9. Hold the magic button until the red led flashes twice.
10. Press 994
12. Press 00255
14. Hold the magic button until the red led flashes twice.
15. Press 994
17. Press 00095
19. Hold the magic button until the red led flashes twice.
20. Press 994
22. Press 00221
24. Hold the magic button until the red led flashes twice.
25. Press 994
27. Press 00079
The remote is now programmed and ready to use, to make the BDP-S370 region free
2. Press 1, 2, 3, 4, 5 on the OneForAll URC-7950 remote. The power light will start flashing. (blue middle light)
4. Next time you turn on the player it will be region free for DVD playback.
OK
Jan 13, 2011 | Sony BDPS370 BluRay Player
How to unlock region free on U.S sony bdp-s350
Sony BDP S350 bluray - unlocking to region free Yes, it is possible, but you'll need a programmable remote - most use the "one for 3/4/6/all". You can hack it by using the same code as for the bdp-s350. Follow the instructions exactly and it should work - mine does.
Programming the 7040 OneforAll remote to enable region free playback of DVD's on the Sony BDP-S350 Quote: 1. Press DVD 2. Hold the magic button until the DVD button flashes twice. 3. Press 0533 4. Hold the magic button until the DVD button flashes twice. 5. Press 994 6. Press Magic Key (don't hold) 7. Press 1891 (this sets key 1 - the DVD button flashes twice) 8. Hold the magic button until the DVD button flashes twice. 9. Press 994 10. Press Magic Key (don't hold) 11. Press 2552 (this sets key 2 - the DVD button flashes twice) 12. Hold the magic button until the DVD button flashes twice. 13. Press 994 14. Press Magic Key (don't hold) 15. Press 0953 (this sets key 3 - the DVD button flashes twice) 16. Hold the magic button until the DVD button flashes twice. 17. Press 994 18. Press Magic Key (don't hold) 19. Press 2214 (this sets key 4 - the DVD button flashes twice) 20. Hold the magic button until the DVD button flashes twice. . 21. Press 994 22. Press Magic Key (don't hold) 23. Press 0795 (this sets key 5 - the DVD button flashes twice) Done - the remote is now programmed and ready to use Quote: 1. Now to make your player region free use the Sony remote that came with the player to bring it out of standby and wait while HOME is displayed 2. Make sure there isn't a disc in the machine. 3. Now on the OneforAll remote press 1, 2, 3, 4, 5 (The blue 24p light on the player will start flashing) 4. Put the player back into standby with the Sony remote 5. That's it, the next time you turn on the player it will be region free for DVD playback If the blue 24p light doesn't flash then it hasn't worked, try a new set of batteries and start a fresh Good luck
Dec 02, 2010 | Sony BDP-S350 Blu-Ray Player
I HAVE A NEW SONY BDP-360 SONY BLU-RAY PLAYER AND I HAVE A DVD FROM AMERICA I CAN'T PLAY AS WE ARE IN REGION 2 AND IT IS REGION 1. ANY WAY OF DE CODING THIS SO IT CAN PLAY ALL REGION CODES. THANKS.
Yes there is a hack to make the DVD region free, as far as I know there is not one for the Blu-Ray as yet.
You will need your original remote and a 7040 OneforAll remote to enable region free playback of DVD’s on the Sony BDP-S350.
Programming the 7040 OneforAll remote.
1. Press DVD
3. Press 0533
5. Press 994
7. Press 1891 (this sets key 1 – the DVD button flashes twice)
9. Press 994
11. Press 2552 (this sets key 2 – the DVD button flashes twice)
13. Press 994
15. Press 0953 (this sets key 3 – the DVD button flashes twice)
17. Press 994
19. Press 2214 (this sets key 4 – the DVD button flashes twice)
21. Press 994
23. Press 0795 (this sets key 5 – the DVD button flashes twice)
5. That’s it, the next time you turn on the player it will be region free for DVD playback
If the blue 24p light doesn’t flash then it hasn’t worked, try a new set of batteries and start a fresh
Good luck.
Jan 23, 2010 | Sony BDP-S360 DVD Player
Mitsubishi WT-42311 42" Rear Projection Television Logo
119 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
