Question about Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ...
The handle of the sprayer broke off and cannot be used. I purchased my faucet from Menards in Janesville, Wisconsin. How do I go about getting a replacement as it said it had a lifetime warranty? Also, why does the water shut off after you try to turn it on to run slowly to rinse something? It is very annoying to have the water slowly shut off when you are in the middle of something.
    Top Expert:
  • 12,650 Answers
Call the company most have an 800 number for their replacement parts they will ask for model no. or describe the faucet also most ship without charge
Posted on Sep 30, 2009
Replacing Sprayer on Kitchen Sink?
Should be able to purchase sprayer head only at any store that sells taps and hardware to go with them. I got a replacement at a plumbing store in Chatham Ontario.
Feb 09, 2015 | Moen 7310 Legend Single-Handle Kitchen...
Kohler sprayer with forte single handle, will not spray well. When sprayer is on the flow to faucet cuts off but there is only a small amount of water coming out the sprayer.
Check to be sure the hose isn't kinked somewhere below the faucet. If there aren't any kinks there is likely debris stuck behind the nozle screen, remove it and clean it- or your handle mechanism is broken. Replacement handles and hoses are fairly inexpensive if you need one they're easy to find at most big hardware stores or on Amazon
Sep 05, 2013 | Kohler Kitchen Faucets. Forte 1-Handle...
Sink sprayer hose makes noise
hello, you may have a air pocket in the line try shutting of the water supply and then sqeeze the handle and slowly turn the water supply back on with the hose handle squeezed on till the air is forced out, hope this helps
Jun 07, 2010 | Moen 87530 Touch Control Single Handle...
Moen kitchen faucet set wsprayer can't shut sprayer.
there is always water pressure on the sprayer when water is on. if sprayer is leaking check if trigger is stuck in . best to just change the sprayer handle it comes off at the base of the handle
Jul 20, 2009 | Plumbing
Push button on sprayer cracked. Where can I purchase a sprayer only?
yes you can,just make sure you take it with you. Not all replacements will fit.you must have the same connector end. they come in a clip style and a screw type. make sure you know what it is you have,one or other before you purchase.
Jul 13, 2009 | Whitehaus Kitchen Single Handle Faucet...
New faucet, sprayer hooked up right, no water going into hose?
check the sprayer handle by disconnecting and blowing into it and pressing sprayer handle and/or for possible kink at main body or hose by disconnected sprayer point hose into sink and turn on water. If no water the the diverter in main body is not working properly and needs to be reassembled or replaced
Jul 01, 2009 | Price Pfister Marielle Kitchen Faucet with...
Sprayer leaking from inside handle mechanism
although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
Jun 05, 2009 | Price Pfister Marielle Kitchen Faucet with...
Kitchen Faucet Replacement
Option 1 ; Cap off the sprayer.  Option 2 ; Relocate the air gap as high as possible under the sink but then you have no drain under it in case it backflows (it is really a vacuum breaker ,  one way check valve) Option 3: Take back the faucet and get one of those that the spout is also the sprayer.
Jan 30, 2009 | Danze D316440RBT Fairmont Two Handle Wall...
Sprayer loosing presure
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)
Here are the instructions:
  1. Turn off water to faucet.
  2. Remove handle.
  3. Remove top cap.
  4. Turning spout back and forth gently lift and remove.
  5. Remove and replace diverter.
Hope this helps and please remember to rate this!
Dec 09, 2008 | Delta 2402 Classic Single Handle Kitchen...
Faucet/sprayer coordination
If you have a Delta faucet your diverter may need to be replaced. The diveter is located under the spout (see diagram)(this is not your faucet but works the same)
  2. Remove handle.
  3. Remove top cap.
Nov 15, 2008 | Delta 2402 Classic Single Handle Kitchen...
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
112 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
